Question about GoVideo Go Video DVD/VCR Combo
Why is my screen blank while audio is fine?
My DVDs' load fine and audio playback is immediate, but my screen shows nothing.
  • ssvis Dec 20, 2008
    This is a portable DVD player, so there are no cords to check.
    Scholar:
  • 145 Answers
These are the possibilities:-
1.Check the connections. you need to connect yellow cable to yellow jack(I assume you are using AV cable to connect)
2.Change settings of your DVD player accordings to your TV, like NTSC, PAL etc.
Please rate me if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Posted on Dec 20, 2008
Tip
How to rip commercial DVDs on Mac - for playback on wide screen TV via WD TV...
How to rip commercial DVDs on Mac - for playback on wide screen TV via WD TV Mini
WD TV Mini Media Player supports up to 1080i resolution for crisp HD media playback, besides this feature, it will never limit the size of your media collection, and you just need add more drives as you like. However there is no luck with commercial DVDs, even though you need not consider about the storage space, because these DVDs have strict copy protections, which WD TV Mini is unable to decrypt. To rip commercial DVDs to a compatible format with WD TV Mini on your Mac, what you will need is Pavtube DVD Ripper for Mac only. Go to find a step-by-step instruction as below.
First off, have a look at WD TV Mini Media Player supported media formats:
Videos:
AVI (Xvid, AVC, MPEG4), MPG/MPEG, VOB/ISO, MP4/MOV (MPEG4), RM or RMVB 8/9/10
Audios:
MP3, WAV/PCM/LPCM, WMA, AAC, FLAC, MKA, OGG, APE
You can free download Pavtube DVD Ripper for Mac here.
Step 1: Launch Pavtube DVD Ripper for Mac, and load DVD files to it
You can click "DVD folder" or "IFO file" to load DVD files directly from the DVD-Rom, DVD folder, or from an IFO image file.
Step 2: Select an output format for WD TV Mini Media Player
Click on the pull down menu of "Format" to a WD TV Mini Media Player supported format as output format. Here I select "Xvid AVI" as my choice.
Step 3: Set advanced settings
Click on "Settings" button, and you are allowed to adjust audio and video parameters on the popup window including codec, bit rate, frame rate, sample rate, aspect ratio, and audio channels. The user manual of WD TV Min tells us that when playback .avi (Xvid) video files, WD TV Mini supports up to 720*576 30fps or 720*480 30fps, so we need to follow the manual while ripping a DVD.
Step 4: Set destination folder
Click "Browse" button to specify where to export the output files to.
Step 5: Click "Convert" button to start ripping DVD
The following window will show you clearly about the ripping info, such as time elapse, estimated left time, generated file size, and estimated file size. In that way, you are able to manage your time and storage space in a proper way.
Once ripping work is done, you can click "Open" button to get the output files for WD TV Mini effortlessly.
Additional tips:
1. The ripping speed of this software is 1-2 times faster than the similar programs. Merge multiple files into one file is available.
2. Enable users to select specific subtitle and audio track to convert.
3. Guarantee audio-video in sync.
4. With exception of adding text as watermark, images, GIF animations, and videos can also be added as watermarks to realize the picture-in-picture effect.
5. You can use the "Trim" function to select certain DVD clips to convert. And you can also take advantage of the "Crop" function to remove black edges or change the screen size.
For more: http://www.pavtube.com/dvd-ripper-mac/
on Mar 31, 2010 | Audio Players & Recorders
Tip
How to watch commercial DVDs on your wide screen TV via WD TV Mini Media Player
WD TV Mini Media Player provides an easy and affordable way to play back your digital media on your wide screen TV.  It serves as a conduit between your TV set and USB drive storage, no matter it is a camcorder, a humble flash drive, or an external HDD. Simply connect WD TV Mini to your TV, plug a USB-connected storage into the player and you are ready to enjoy all your digital media in DVD quality playback.
Videos:
Audios:
From the above list we can see that VOB is a playable format for WD TV Mini Media Player, does it mean that WD TV Mini can play all kinds of DVDs – whether home made DVDs or commercial DVDs? The answer is WD TV can not decrypt copy protected commercial DVDs, so you have to rip them. This tutorial aims to show you how to make it possible for you to watch commercial DVDs on your wide screen TV via WD TV Mini Media Player. What you will need is Pavtube DVD Ripper, it not only rips, but it encodes too. Following is the detailed operating steps:
Step 1: Click "DVD Rom", "DVD Folder" or "IFO/ISO" to load DVD files into this program.
Step 2: Select subtitle and audio track
Click on the pull down menu of "Subtitle" and "Audio" respectively to select your needed subtitle and audio language.
Step 3: Select output format for WD TV Mini Media Player
Click on the drop-down list at the end of "Format" to choose an output format for WD TV Mini Media Player. Your selection should be in the range of AVI (Xvid, AVC, MPEG4), MPG/MPEG, VOB/ISO, MP4/MOV (MPEG4), RM or RMVB 8/9/10. Here I select "Xvid AVI" as an example:
Step 4: Click "Settings" button to adjust video and audio parameters
The user manual tells us that when playback .avi (Xvid) video files, WD TV Mini supports up to 720*576 30fps or 720*480 30fps, so we need to follow the manual while ripping a DVD.
Step 5: Click "Convert" button to start DVD ripping
Once finished, you can get the generated files for WD TV Mini via clicking on "Open" button with ease. Afterwards, just copy the output files to My Passport portable hard drive or other USB drive, and then connect WD TV Mini to your TV, plug your USB drive into the player and you are ready to enjoy the movies ripped from your commercial DVDs.
For more: http://www.pavtube.com/dvd_ripper
on Mar 29, 2010 | Audio Players & Recorders
Power comes on but it only shows a blank screen. screen shows nothing at all no menu, nothing. tv works fine.
Make sure the video/audio cable is plugged in correctly. Red cable into red socket, yellow into yellow and white into white. It is easy to put these cables in the wrong socket by accident and will cause no image to appear on your screen.
Jun 12, 2011 | Video Game Consoles & Games
This message appears on the screen after the ASUS screen. Then nothing. Help
In Most cases if a screen can display and shows signs that your laptop was loading then shows nothing later many times your windows may be corrupt or damaged so you will need to re-install windows on your laptop....i would recommend windows xp 2 and just after installing please try installing an anti virus immediately before any other program is added and don't forget to update the anti virus first. Please also give more information on what kind of message appears before the screen goes blank.
Apr 13, 2011 | Computers & Internet
Blank blue screen
check cmos setup if the hard disk is still detected,if not,replaced hard drive and reformat your system.maybe your hardisk is already busted so it doesn't work at all.
May 05, 2009 | Computers & Internet
Playback of dvds
is the country code different on the dvds than on the unit?
Nov 28, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Playback won't work
needs to be cleaned and possibly tension adjustments. most cases this will fit it but the video heads could need replacing.
Sep 14, 2007 | Sony Handycam DCR-TRV245 Digital-8 Digital...
Playback is distorted
This is either an internal connecter loose or a failing CCD Either way not fixable by the user. Contact Fuji customer support
Aug 04, 2007 | Fuji FinePix F10 Digital Camera
GoVideo Go Video DVD/VCR Combo Logo
43 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
