Question about Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter
I can not my headset
I instaled the software and i set up no passkey but my computer doesn't recognazi my device
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Insignia Master
  • 1,001 Answers
The buletooth headphone ensure clear speech within 10 meters and high-fidelity stereo music . Amazon com Charm sonic Bluetooth Headphones for Gym Runing Exercise Green...
Posted on Jan 12, 2017
    Scholar:
  • 145 Answers
1. There may be a switch on the headset. Please switch it on.
2. click Connect headset on the Bluetooth window
Posted on Dec 20, 2008
I am trying to hear my gameplay through my plantronics gamecom p90 headset i got the headset to work but i cant hear my gameplay through it
If your headset is the P90, turn the headset on. The light on the headset should start flashing red/blue. If it doesn't, start with the headset turned on, press and hold the call control button on the headset until the light on the headset starts flashing red/blue, red/blue. Follow the on screen instructions and let the PS3 scan for the headset. It will appear as "P90Plantronics" in the list of devices. If prompted for a passkey, enter 0000 (4 zeroes). Now go back to the Accessory Settings menu and then select Audio Device Settings. Select "P90Plantronics" as the audio input and the audio output device. You should be all set. If not, you can contact the Technical Assistance Group at 800-544-4660 x5538.
Good luck from Headsets Direct - 800-914-7996.
Aug 10, 2011 | Plantronics GameCom X10 Headset
What is passkey to pair plantronics headset with samsung phone
The passkey is something set by yourself in either one of the devices. It usually isn't asked for a Bluetooth headset
May 13, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Is h350 compatible with windows vista? i try installing one, i easily paired it with my compaq laptop windows vista os without asking any passkey. the problem is it would'nt work. i downloaded a bluetooth...
I've successfully paired this headset with Vista but only for Skype. In Control Panel set the Bluetooth discovery and it should pair OK but then you need to run Skype which will find the headset and ask if you want to use it. The solution is a bit temperamental because the microphone volume is usually either low or there is too much background noise.
Feb 01, 2011 | Motorola Mobility H350 Wireless Headset
Trying to connect jabra BT2080 to phone. says enter passkey?
  1. Bluetooth device A looks for other Bluetooth devices in the area
  2. In order to find other Bluetooth devices, Bluetooth device A must be set to discoverable mode. When set to discoverable, Bluetooth device A will allow other Bluetooth devices to detect its presence and attempt to establish a connection.
    You may set your discover setting off if you like (It is recommended that you turn it off when not using the Bluetooth). When the discover setting is off, no other Bluetooth device will be able to find it. Undiscoverable devices can still communicate with each other but they have to initiate communication themselves.
  3. Bluetooth device A finds Bluetooth device B
    Usually the discoverable device will indicate what type of device it is (Such as a printer, cell phone, headset, etc.) and its Bluetooth device name. The Bluetooth device name is the name that you give the Bluetooth device or the factory name that originally was programmed.
  4. Bluetooth Device A prompts you to enter a password (PassKey)
    With advanced devices (i.e. computers, smartphones), both users must agree on the Passkey and enter it into their device. The code can be anything you like as long as it is the same for both Bluetooth wireless devices.
    On other devices, such as Bluetooth headsets, the Passkey stays the same. Refer to the product's manual for the default passkey. Most often, the default passkey is "0000".
  5. Bluetooth device A sends the Passkey to Bluetooth device B
Jan 26, 2011 | Jabra BT2080 Bluetooth Headset
I need the passkey to install the bluetooth to my new phone, motorola H681
the default passkey for every bluetooth device is usually 1234. try it and let me know if it works. u have to pair it and enter the same passkey with your mobile/celfone.
Aug 07, 2010 | Motorola Mobility H550 - Bluetooth Headset...
Nokia BH-213 unable to Pired with Nokia E-63,it stopped suddenly
I also experienced the same problem. After trial and error I realized that the bluetooth device needs to be reset to fix this issue.You may reset the bluetooth device by deleting the pairings from the headset or reseting the headset. Switch off the headset, and press and hold the multifunction key for over 8 seconds. Start pairing the device again. It should work fine now with default passkey 0000
May 03, 2010 | Nokia Bluetooth-Headset BH-213 2600...
LG HBS 200 connection to the computer
the default passkey is 0000. try it and see if that works.
Feb 26, 2009 | LG HBS-200 Bluetooth Headset
Install bluetooth
Normal 0 Go to Control Panel and click on Sound.
Next click Bluetooth Devices.
Click Add button, lower left corner of the Bluetooth Devices window.
Insure batteries are installed.
Press the Connect Button on the Keyboard (Usually located on the under side of your keyboard) this allows Windows to see the keyboard so you can pair the keyboard to the computer.
On the computer choose My Device Is Set Up and Ready To Be Found.
Click NEXT.
The keyboard should appear in the Add Bluetooth Device Wizard Window.
Select your Keyboard and click Next.
When prompted, select Choose a Passkey For Me and click Next.
Windows will generate and display a Passkey.
Type the Passkey specified on the Bluetooth Keyboard
(do not use the keyboards keypad when typing the passkey)
No charters will appear on the monitor when typed, but if you make a mistake, you can backspace.
You must enter the Passkey within 30 seconds.
If you don’t enter the Passkey within 30 seconds, click Back and click Next again.
Once the Passkey is entered, the Keyboard should be connected to the computer.
Finish and follow any on screen instructiond.
Hope this helps. Bud
Jan 11, 2009 | Logitech MX5000L
Insignia disk does not read from Playstation3
if the headset is bluetooth then the ps3 should be able to connect with it while its in pairing mode form the settings menu. if the headset will not function without other software then the ps3 cannot use them. the ps3 will only read the select music, video, and game discs.
Jul 25, 2008 | Insignia Bluetooth Wireless Headphones...
Passkey for Motorola H550
Most Bluetooth headsets use 0000 (4 zeros) as the passkey when paring the device to the cellular unit.
Dec 18, 2007 | Motorola Mobility H550 - Bluetooth Headset...
Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter Logo
102 people viewed this question
Top Insignia Radio Communications Experts
Skyken
Level 1 Expert
woodzowl307
Are you an Insignia Radio Communication Expert? Answer questions, earn points and help others
