Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
No water going into dishwasher?
Power on drains all clear no water going into unit at all, but pumps out water when manually filled
    Problem Solver:
  • 16 Answers
Either the isolation tap is in the off position or the fill solonoid is faulty on the water inlet pipe within the appliance. hope this helps!
Posted on Dec 20, 2008
Not finishing cycle
Is it draining out the water?? Dishwashers fill, spray, and drain more than several times during a cycle. After starting a cycle, let the unit fill, start spraying, and then cancel the cycle--listen for the drain pump activating and pumping out the water. If water is not being drained properly(within a certain time limit), the unit will error code out and stop. Also, make sure the filter is clear--if it gets clogged with "muck", enough water won't be sprayed onto the dishes properly, the pump will require too much energy to try to pump water, the control will sense this and shut down the unit to protect it.
Jul 25, 2015 | KitchenAid KDHE704DSS 24 6-Cycle/7-Option...
The dishwasher has been working perfectly until recently it's not draining and water is remaining in the basin of the unit.
need to be sure the filter in the base of the dishwasher is clear of anything that would keep it from draining such as a screen filter. also need to check the hose that drains to the sink is clear. from there it is most likely a pump or timer issue.
Dec 17, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Frigidaire FDP635RFR3 wont drain.
Theres a drain pump located at the bottom of the unit if you follow the hose from the pump then to the drain if your unit isnt draining you might have to call for service from a technician to have them change your drain pump. If the water is just sitting inside the unit and when u start the unit it should fill with water again.Also if you have a cancel function by pressing this you will make the unit drain if you dont hear anything when u press the cancel button you definetly need a pump
Apr 28, 2010 | Dishwashers
My bosch dishwasher will not fill with water. I have manually filled it but it just pumps it out when I switch it on.
the unit is going into drain mode. check your hose for leaks. when water leks in the base of the unit the float switch is activated and the unit will stay in drain mode until the water is removed. check float by removing side panel and look into bottom base for water.
Feb 25, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Not filling or draining
The drain motor (pump out motor) in line with the outlet pipe could be faulty. This motor must spin (to pump out water) in the drain mode. If AC (mains)voltage is across motor in pumpout mode and the motor does not spin indicates that the motor is open circuit and needs replacing. Has one of the 2 motor push on electrical connections dislodged?
Is the outlet pipe obstructed?
Jan 21, 2010 | Bosch SHU43C05 Stainless Steel Built-in...
Will not fill. Drain pump runs all the time.
Sounds like flood switch has been activated. They have a float in the base of machine, which will activate drain pump if a leak has occurred. Unplug from power- remove right hand side panel, check to see if any water in base. If so, leak has occurred. Clear water from base and test run to locate leak
Aug 08, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Bosch SHX46A02UC-21
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Aug 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Jun 01, 2008 | Dishwashers
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
139 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
