Question about HP Photosmart Pro B9180 InkJet Printer
HP L7780 all-in-one fails alignment test and will not print in black. I have done all the resets, put in new print heads and new cartridges (including a new black cartridge) and spent about 5 hours on the phone with HP. Nothing works. The printer prints its self test just fine...but in Magenta...no black, even though it is set to print all text in black.
  • 679 Answers
David I cannot get back on the que, here is my number, 945 426 8307
Posted on Dec 20, 2008
    Genius:
  • 2,120 Answers
You must replace both cartridges with new ones to complete the alignment.
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
"alignment failed" message. Prints
First, try power cycling the printer (Turn it off, wait 5 sec, turn it on). If this does not resolve the issue, try removing the cartridges and reinserting them carefully.
May 05, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro L7780 has stopped printing in black after changing yellow cartridge. Black is barely showing in spots. Have cleaned the heads and restarted twice and black cartridge is almost new, at...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 18, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Alignment failed refer to device documentation hp L7780
You need to remove the black/yellow printhead and dab it on a damp paper towel until you see a solid line of black ink on the towel when you press it. It won't pass the alignment until all colors work properly.
Nov 19, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
C6180 failed alignment test, will not print color properly
All colors need to be present to pass alignment. Usually what I see is the yellow is empty. You can blot the print cartridge on a damp paper towel to verify the inks are working and this also cleans the head.
Jun 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Generic black ink cartridge causing black ink to not print
Never mix dye and pigment inks/machines Head could be screwed Try copying many black text only pages up to 200 but run head clean after 50 or so Inkypete
Apr 20, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP L7780 all-in-one prints out of line
if the paper is coming out out-of-align, that suggest the one of the roller need to be replaced.
either call HP to ge a maint. ket or replace rollers. Cost is high compare to the price of the machine.
Jan 27, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Ink cartridge alignment problem
well, what i did, and it seemed to work, in the short run anyway. i took and threw my hp in the back of a waste management truck,  then i called amazon.com and i ordered a new epson printer,
Oct 26, 2007 | HP PhotoSmart C4180 All-in-One Color...
Alignment
I've seen this happen with clogged heads as well. If even one color of the color cartridge does not print, it will mess up the alignment page. I'd say take a damp paper towel, wipe the print head off. That the area on the cartridge where ink comes out. after wiping, do a "foot print" test. Gently but firmly, lol press the print head into the damp paper towel. You should see a blue yellow and red foot print. They should be about the size of the print head itself. Do this for the black as well. IF you don't see good foot prints, then take them to your local cartridge world and get them replaced!
Oct 19, 2006 | HP PSC 750 All-In-One InkJet Printer
HP Photosmart Pro B9180 InkJet Printer Logo
285 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
