Question about Imperial C2036PS1-TW Kitchen Hood
Kitchen extractor fan
We have an Imperial kitchen extractor hood.
It is a pull out type extractor hood.
The fan does not work.
Any ideas?
    Problem Solver:
  • 16 Answers
Hi! most of the time this will be sticky switch normally located on the inside edge of the extactor unit behind the filter mesh!.hope his helps
Posted on Dec 20, 2008
Hi, my kitchen extractor fan seems to be blowing the smells back into the kitchen and not out, it sounds like it it working ok and the fan is going round.
Check the ducting outlet is not blocked on the outside wall or if it is ducted up through a ceiling then remove the hose fron the unit and check for blockages.With the hose off run fan to see that it is indeed blowing the air correctly.The other things to check are the filters.
Hope this helps.
Mar 26, 2010 | Kitchen Ranges
Faulty electrolux kitchen extractor unit
good day,
hope this link below will solve your problem.
kitchen
Jun 07, 2009 | Fat extraction holder Kitchen Hood
The light on my cooker hood comes on but motor dos,nt work it is a diplomat APP3440
It's probably a bad fan switch or a loose/corroded/broken electrical connector in the fan circuit. Another possibility (but not as likely) is the fan motor has failed.
Apr 21, 2009 | Imperial C2036PS1-TW Kitchen Hood
Kitchen extractor fan just started making a screeching sound and slows down and stops as if something is holding it back Not sure whats happening
the motor is going bad. soon wont work. only 2 things to do either 1 replace motor. 2 replace hood. motora are usually cheap. $10-50 ...
Nov 23, 2008 | Fat extraction holder Kitchen Hood
Baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Nov 16, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
The extractor on my Baumatic fan stopped working. Thsi was shortly after the light bulbs blew which I replaced and they work OK. Any suggestions as to how i can resolve this?
Sounds like it was the main fan motor - that caused the lights to blow in the first place.
Isolate from supply, and get the fan motor checked out. If it is burnt out (inside) you will need a replacement.
Hope this helps.
Jun 05, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Neff extractor fan not working
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Mar 20, 2008 | Whirlpool GZ7730XGS Stainless Steel...
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Imperial C2036PS1-TW Kitchen Hood Logo
940 people viewed this question
Top Imperial Kitchen Ranges Experts
Marvin
Marvin
Craig Butler
Craig Butler
Thomas Perkins
Thomas Perkins
Are you an Imperial Kitchen Range Expert? Answer questions, earn points and help others
