Mitsubishi WD-52525 swollen capacitors C9A37 and C9A38
Thanks for your insight. Finally, someone that knows what they are doing! Mitsubishi sucks!!!!
Now that you helped me find the problem, what is the solution. Do I have to replace the entire board? How much do you think it will cost?
email jberry11111@earthlink.net
cell phone 423 914-6090
  • Televison & ... Master
  • 3,497 Answers
Hey Jerry. Remove the board, get a solder vacuum so you can remove the original solder when you use the soldering iron.. do not leave the excess.. once you have removed the old capacitors, you can solder the new ones in... IF you cannot do this, there should be a TV repair shop in the area that will do it for you... let them remove and replace the capacitors...
-- Take a picture of the board before you remove it so you will know where everything plugs back.. Good luck!!
Posted on Sep 07, 2017
  • 192 Answers
SOURCE: electrical chasis cooling fan for Mitsubishi wd 52525
There are several Parts Houses that carry this part. The one I think that is the easiest to deal with is Andrews.
The URL is:
https://dealer.andrewselectronics.com
Can't find it there, reply to this post and I will respond.
Posted on Dec 15, 2007
  • 1153 Answers
SOURCE: Wd-52525 Replacement Attempt
Fuse F9A09
Posted on Mar 11, 2008
  • 5 Answers
SOURCE: mitsubishi wd-52628 flashing green timer light
If the power/timer led is the one blinking constantly
the most likely problem is two 3300 mfd caps and 1 to 8 1000mfd caps on the power board.
could be the DM board or caps on it as well.
Posted on Jun 17, 2008
  • 927 Answers
SOURCE: Continuous blinking light
Good Day, mossberg142;
No, replace those CAP's with original value. Good Luck,
big IRISH.
Posted on Sep 06, 2008
  • 41 Answers
SOURCE: Replacement Caps for Power board WD-52525
You can check out www.tritronicsinc.com just look for correct values VOLTAGE, VALUE, TEMP 100C or call 800-638-3328
Posted on Dec 21, 2008
Try to find the power board of MITSU 52525 as described by a comments posted on Feb 21, 2008. But after I opened the back lower cover and metal frame, I found the whole I/O connector modules are very...
Thats a difficult chassis to work on without proper instructions. The V26 Power repair kit from www.tvrepairworld.com has the replacement capacitors and the CD with detailed instructions. There are 8 capacitors on that board which usually fail the kit has all 8
Jan 01, 2010 | Mitsubishi WD-52525 52" Rear Projection...
3-5 error code on mitsu wd-52725(chassis fan failure)
Check the power PWB pico fuse F9A09 and if thats good check the following capacitors all on the power pwb.
Power Supply
C9A52 1000uF 16V
C9A59 1000uF 16V
C9A61 1000uF 16V
C9A62 1000uF 16V
C9A39 2200uF 35V only some versions
have this cap.
C9A40 2200uF 35V
C9A37 3300uF 16V
C9A38 3300uF 16V
Feb 28, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Dec 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Wd-52525 HDTV Stutis light constant red
Good Day, barryspiegle.
You and a million others are having this problem. Are you handy? Did you say; yes/kind of?
HERE IS THE SOLUTION FOR THAT PROBLEM AND THE ONES YOU WILL HAVE IN FUTURE:
Replace C81A2,C81A3, C81B3 AND C81B4 (1000uFD, 16 V) On DM PCB.
Replace C8F19, C8F21, C8F22 and C8F27 (1000uFD, 16 V) On FMT PCB.
Replace C9A51, C9A52, C9A61, C9A62 On power PCB.
REPLACE ALL WITH (680uFD, 16V, 105c), part number 181P734030.
Replace C9A37 and C9A38 ON POWER PCB. (3300uFD, 50 V).
Good Luck, big IRISH.
ps; Three boards on left side of TV and about 2.5 to 3 hours of repair time.
Aug 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 Capacitors
Try MCM electronics. You need two 3300mf/25 capacitors. C9A37 and C9A38. Get the high temp caps 105 C
Dec 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
No picture
you can check this first before you replace lamp. F9a09 and c9a37, c9a38
Dec 07, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Capacitor assistance required.
ok people lets not make this so difficult.
you need 3300 mfd/ 10 volt electrolytic capacitors.thes are general purpose capacitors. the 105 t C is temperature tolerance.no big deal 85 c or 105 c is fine. try google search for MCM electronics, or Pacific Coast electronics or anybody that sells electronic parts
Nov 30, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Red lines, green lines, now static!
Uneven colors with multicolored lines in the center of the picture and/or flashing, C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002)
Nov 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen with white snowy circle in the middle of screen
Sounds like bad capacitors
Replacing the C9A37 & C9A38 caps or
problems with some capacitors on the pwd power board, and that it would be good to change them if they were swollen
Oct 20, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
