Question about Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
Drive ejects disc without attempting to read them
Sony Drive in Dell inspiron 700m. Drive ejects disc without attempting to read them. It makes a short noise, which I believe is the release mechanism on the drive door. It does not attempt to spin up the drive as far as I can tell. Thus I doubt the laser is the problem, since it does not appear to try to use it. If I hold the door closed so that it cannot eject, it eventually stops trying. It will eject via a right-click in "My Computer" I have tried updating the firmware without any luck. This actually happened about a year ago, and I stopped using the drive because I can't afford to buy a replacement. I noticed that it started working again about 2 months ago. Then it suddenly went back to ejecting without reading. Is it possible that there is some dirt on a sensor or in some way the drive is tricked into thinking that it is open or closed -- i.e. is there anything mechanical that I might be able to fix? Thanks, -Pete
4 Suggested Answers
  • 8 Answers
SOURCE: My new DVD-burner keeps ejecting
Try to solve the problem by looking into your PC. What all softwares have you installed? Are you having the problem when you are using some CD/Audio Players ( Does that program crash/hang usually ) ? Only install softwares that you think are useful. It can also be some maicious software. Always update you anti-virus AND anti-spyware. Uninstall all the unwanted softwares. If these dont help solve the problem,... I may help you if you could do the following steps. * When the problem occurs, open Windows Task Manager by pressing Ctrl, Shift, Esc together. * Under processes, note down the names of all the processes along with username and maybe memory usage. * Give all the particlars about your PC and post it to me ( Try "everest" from to prepare a report ). I shall look into the problem and try to help you.
Posted on Aug 05, 2007
  • 45 Answers
SOURCE: device stopped to read any disc
for EnzoMolinari
u r drive is having an hardware problem just contact nearby service center
Posted on Jul 28, 2008
  • 669 Answers
SOURCE: I have SONY CRX320A CD-Drive and I tried to update
Click start, click control panel, double click system, choose hardware tab, select device manager, click plus sign next to DVD/CD ROM drives, right click on your CD if there, choose properties, select driver tab, select rool back driver. If your CD is not shown try this link to sony for download of drivers.
Posted on Aug 14, 2009
  • 27725 Answers
SOURCE: I have a Dell Inspiron
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Sep 18, 2011
0 characters
1 Points
My 1977098v-d6 will not eject
Possiblky the disc has moved even though on a spindle. When you say it will not eject is this using the software asking it to eject if so it will send the instruction to eject but when it finds a problem with the disc the tray will not open. So, get a pin or needle, in the front ogfthe drive will be a tiny hole behind which is the manual release. Stick the needle in the hole and push the manual release the tray should then unclick and you should be able to remove the disc.
Feb 29, 2012 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
Dell inspiron 1525 blank dvd r not regognized
You will need to use a different brand of blank DVD-R disc, some DVD-R disc will not work with some optical drives. Try using a Sony or Phillips DVD-R discs, these two brands work best.
Feb 13, 2011 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Ejects cd from my dell inspiron 6400 and will not play or read
remove the CDROM (turn notebook around, remove the drive and reinsert after 1 minute.. perhaps it requires reseating.
if this fails, then accoding to Dell support Discs burned with this drive may not be compatible with some existing drives and players ; using DVD+R media provides maximum compatibility , if you have the 8x DVD/CD Burner (DVD+/-RW)
Jan 11, 2011 | LG GSA-T10N DVD RW Dual Layer Burner
Won' read discs, won't eject manually or through Eject under DVD drives.
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 14, 2010 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
I have a dell inspiron 1319 laptop. This just happened randomly: When I pushed my DVD into the DVD drive on the side, I hear these two short sounds before it completely ejects my DVD back out. I'm really...
The drive has locked up and if you remove it, you may be able to free it up,Try to use a regular audio cd and see if you have the same problem,if so the drive is locked up and needs replaced or freed up.
Aug 01, 2010 | Dell (Y4081) CD-RW/DVD-ROM (Combo) Burner
At boot up , my vostro sends and error message "System in the modular bay not recognized" , and the Dvd/cd doesnt seem to work. It doesnt appear at MyPc and neither does it read any disc.
It may be due to the loose contact of the cables connected to the drive, if the tray ejects that means it receives power, tightining the cables should resolve the issue
Jul 28, 2010 | Dell Vostro 1400 / Inspiron 1420 - 24X...
I m not able to eject the tray of my cod rom.i have tried with paper clip,that works but that is temporary my drive defective?can u plz guide me how to repair it?plz help
at the edge of a tray or on one of its sides is a tiny hole. if you press it using something with sharp tip like pen it will ose override mechanism and mechanically open the tray for you.
Dec 03, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Dell Inspiron-1520 unable to read RW DVD's.
you have a faulty disk inserted in the drive. Restart the computer and continuously press eject while the pc is booting, it should eject then.
Oct 11, 2008 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Reads and writes cds,reads dvds but does not burn dvds,
This drive is normally supplied with a couple of Dells.
(because of compatibility) Inspiron 700m,710m
If you have another machine for testing?
check the disk for contents to see if the data burn happened,
this will explain a few things in your processes.
Uninstall/Reinstall the drive and reboot then try again.
Have you tried a full system reinstall yet?
Did it fix your problem?Please let me know thanks
Jul 15, 2008 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
Sony CRX830E CD-RW/DVD-ROM (Combo) Burner Logo
288 people viewed this question
Top Sony CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Shahzad  Waseem...
Shahzad Waseem...
Are you a Sony CD and DVD Burner Expert? Answer questions, earn points and help others
