Question about Panasonic SA-HE70 Receiver
Panasonic SA-HE70 Sub Out Problem and Standby
My SA-HE70 has a problem with it's sub out. I have to pull the phono lead to one side on the back of the amp to stop it buzzing, and sometimes it just starts buzzing for no reason. I don't think its the sub (which is a amplified), so I was wondering if anyone knew if it is a problem that can be fixed, or should if I should just get a new one. The other problem is that you can turn the thing off by just tapping the case. Seriously not right!! Thanks for reading and for any replies.
Hi i would try a new lead, try a normal audio phono lead , or at worst a dry joint at the plug on the amp, there are only 2 joints , so easy fix hope this helps. Ray
Posted on Apr 09, 2007
CD function not working on Panasonic SA-HE70 receiver
when you say its not working what do you mean by that?
its got no power.
the tray wont open.
tray trying to open but wont.
or just wont play cd.
if none of the above could you please give me more info please.
Nov 08, 2016 | Panasonic SA-HE70 Receiver
I have a button that allows bass/treble and balance but only balance works regardless of how many times you press it.
Read Page 13 of your owner's manual http://www.manualslib.com/manual/119549/Panasonic-Sa-He70.html?page=13#manual
Jun 06, 2015 | Panasonic SA-HE70 Receiver
Am looking for a manual for an SA-HE70 av control manual
Crutchfield has the manual for the Panasonic SA-HE70 on their product sale page: http://www.crutchfield.com/S-6TiEMal3qmL/p_133SAHE70K/Panasonic-SA-HE70-Black.html . Look at the Details tab. The direct link to the manual is http://www.crutchfield.com.edgesuite.net/pix.crutchfield.com/Manuals/133/133SAHE70K.PDF .
I hope this helps.
(You will need Adobe Reader or a similar program to read or print the manual.)
Apr 19, 2015 | Audio Players & Recorders
Looking for manual for pioneer sw200 powered subwoofer
Most subwoofer have a left and right phono/RCA sockets. The amp should have a sub out phono/RCA plug. The sub should have come with a phono/RCA lead that will connect these - one plug to two plugs.
Apart from the mains plug that's all there is really. You may have to switch the sub socket on the amp on.
Or you can get one of the cables from places like below:
http://www.custom-cable.co.uk/hifi-cables/subwoofer-cables/
Sep 13, 2014 | Pioneer Audio Players & Recorders
How to hook up external amp need to know how to run jacks to the amp and speakers which out put for amp to run the front speakers on a panasonic sa-he70
Manuals help.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SA-HE70K-Receivers-manual/id/312ag701/t/2/
Not knowing anything about your 'external' amp or how you want it to function the only thing you could do is feed it the analog stereo output of the SA-HE70 from one of its OUTs (Tape or VCR). It won't be volumed-controlled by the SA-HE70.
Jun 01, 2011 | Panasonic SA-HE70 Receiver
Panasonic sa-he7,no sound from sub output,im using a samsung subwoofer of impedance 6
Have you looked at the manuals?
If the unspecified sub isn't self-amplified it won't work with this receiver.
If it IS self-amplified you still needt o set up the receiver to run a sub.
http://www.retrevo.com/support/Panasonic-SA-HE7-Receivers-manual/id/312ag700/t/2/
May 10, 2011 | Panasonic SA-HE7 Receiver
My tv has one sub output socket,but my active sub woofer has a red and white input sockets.what lead do i need to connect it up with?
Sounds like the output on the TV is a phono socket or a jack and the inputs on the sub woofer take banana plugs. You need (or should make up) a lead with a phono or jack plug one and and two banana plugs the other end. (phono plug/socket has two connections and banana plugs just one)
If you can provide the model numbers of the two bits of equipment I can check this for you.
Mar 08, 2010 | Audio Players & Recorders
Working the Sony STR-DE475 5.1 Channels Receiver
It has a dedicated sub out. you need a phono connection on one end for the amp and the other end must have a compatable connection to your sub.
You will need a phono connection to the amp from your TV. You can utilise a scart lead that has phono outputs however a TV with audio outs (the red and white leads) is the default option.
Mar 31, 2009 | Sony STR-DE475 Receiver
Panasonic subwoofer
Any active subwooofer. I have an HE70 as well and I am using the SONY active subwoofer.
Nov 12, 2007 | Panasonic SB-WA100 Subwoofer
Using computer speakers with the panasonic sa-he70
I had a similar problem. In order not to mess up the jacks from the speakers I bought some mini jack to stereo rca adapters. I cut off the rca jacks from the end and then is just a matter of figuring out witch ones are left and right channels. For the subwoofer it's best to figure out which one is the sub channel so you don't have to cut off the rca plug from that one.
Dec 13, 2006 | Panasonic SA-HE70 Receiver
Panasonic SA-HE70 Receiver Logo
302 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
