Question about Garden
Blower at times starts to stall during throwing
Airens blower starts to stall during throwing.Not all the time.Is this belt tension or gas problems ,or?Have new gas in blower and was not a problem last year.Blower is two years old and maybe fifth time being used.
  • 959 Answers
Hey Burnside ,
Is it the engine that boggs down? like when you are blowing wet snow?
or is it the auger that starts to stall?
Posted on Dec 20, 2008
2000 jeep keeps throwing the belt hafe way off
That has the big serpentine belt and a tensioner. Check the tensioner and the idler pulley.
Dec 02, 2017 | Jeep Cars & Trucks
Car has multiple problems dashboard does not work,heat panel does not work,fan blows all the time,car starts sometimes then stalls and wont restart until next day,ran diagnostic check came up with p0463...
Use a bottle of yellow HEET dry gas to remove any moisture problem in the fuel.
Check the date code stamp on the battery. If it is close to 48 months old then consider replace.
Check belt tensioner wear indicator arrows/dots, When belt tensioner fail,it will not create enough friction to the alternator pulley.
Clean / replace air filter.
Check ATF at level ground. Top off to MAX level.
Jan 15, 2014 | 2009 Ford Fusion SE
Cub cadet SLT 1554 keeps throwing the drive belt
Double check the routing diagram. Check to make sure your idler pulleys are in good condition. Bearings are good. Lastly the tension spring may be worn. The belt should fit very snug. No more than 1 1/2" of deflection when you push on the belt with your thumb
Oct 15, 2012 | Garden
I have a CCR 3650 Snow Blower ,The engine is racing at idle. How do I adjust?
Try the spring on the governor. sounds like it's not hooked up, or extremely week. I rebuild and sell these all winter. I've had it happen a few times. Runs really good! but, will ruin the motor running over speed like that. There are adjustments- some have the spring on a long flange of metal so it can be bent backwards to add tension- it doesn't take much! If the motor starts to rev up and down and up and down, add a hair more tension. It there is too much tension it will stall out when you hit heavy snow.
Feb 01, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
Timing tensinor replace
The entire front of the engine must be disassembled to replace the timing belt tensioner. Your vehicle is equipped with an "Interference engine" meaning that if the timing belt/tensioner is not installed correctly, or if the timing belt breaks or comes off of the pullies, severe engine damage will result.
Jan 29, 2011 | 2002 Hyundai Accent
Belt squeaking and hesitating when I run
Before beginning this repair: Check to make certain that the drive belt requires adjustment. Check out belt slipping instructions or with the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
Step 1- Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust. Step 2- Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts. Step 3- Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts from Steps 1 and 2 and test your treadmill for slipping. If belt continues to slip, repeat Steps 1, 2, & 3. If a second attempt does not repair the problem, skip to Step 5. Step 4- If your treadmill is not equipped with a bolt as described in Step 3, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described in Step 2. Tighten the bolt from Step 1 and test. If the problem is not corrected, repeat Steps 1, 2, & 4 and retest. If problem persists, skip to Step 5. Step 5- If you have arrived at this step, let's make sure you have a drive belt tension problem. With the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced. Step 6- The belt should be able to be turned by hand at approximately a 90 degree angle from its normal operating position
Jun 02, 2010 | Proform Exercise & Fitness
No start fuel ok spark ok
throttle position sensor,and crankshaft position sensor.
May 03, 2010 | 2004 Chevrolet Aveo
Serpentine belt not staying on.
the only water deflection dodge gave these cars was directly under the pully system if it has this and is still throwing belts check the tensioner
Dec 14, 2009 | 1994 Chrysler LeBaron
Sudden loss of power, Backfiring, starts then stalls
Your timing belt could be broken. You want to have this checked as soon as possible to prevent any further engine problems.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_62314e5b2470e8b5
Nov 27, 2008 | 1991 Honda Civic
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
