Question about Kenmore 27032
Kenmore elite oasis, lid-lock mechanism
Please help me figure out how to work around the "lid-lock" on this machine! I need to open the lid during the agitation cycle to add dye solution, anti-allergen rinse and to make sure the fabric in the machine isn't getting tangled up during the cycle. I tried calling Sears but was told that technicians have a "code" to do this but it is "secret" and I can't have it. If I want to open the lid during operation for self-repair diagnosis--too bad. I have to pay Sears techs to do it... Please help.
  • 1 more comment
  • m k brown Apr 03, 2007
    Wow! Thank you so much! Positioning the magnet seems to require the precision of a laparoscopic surgeon but I did get it to work at least once so I'm encouraged. I'll put a little more effort into getting this to work consistently before attempting the "second way"... Thanks again!
  • JLLE Feb 19, 2008
    The little plastic piece that acually locks the door broke off. Can I somehow still wash without it? If not, how do I replace the part. It can be ordered, just not sure how to get to it. Thanks
    Julia
  • Anonymous Jan 23, 2009
    Can you tell me approximately where to place the magnet? Also I am assuming something broke and that is why it won't lock. Can a replacement part be purchased?
    President:
  • 878 Answers
Mk, there is two ways to work around the lid. The lid lock works by magnet. If you have a large magnet laying around you can fool the mechanism and run the washer without it locking. You will have to find the spot near the center front and experiment until you get the right spot. The second way is to lift the whole top assy. About 3 or 4 inches in from each end where the top seperates from the bottom there will be a clip that you can push in on and lift the whole top. Now these clips are real strong so you need a good putty knife. Pull up on the top as you are pushing in. This way you can add your stuff while doing a normal wash. The codes are for diagnosis, testing different functions of the machine, it wouldn't do you any good for what you are trying to do. Catriver..post back
Posted on Apr 03, 2007
Pictrus resolution is notbetter
Posted on Apr 30, 2008
How to by pass the lid lock switch on a Kenmore elite Oasis HE washmachine
Not a real good idea except under emergency situations, as the lid lock is a safety switch to prevent access to the washer during spin cycles when the drum is operating at high speed and you don't want foreign objects (like hands) coming into contact with a high speed rotating drum or its contents. If you have the unit open enough to cut the wires, you had enough access to replace the switch, which you can get at SearsPartsDirect.com or any Sears Service Center in your area. If you are hell-bent on operating the machine in an unsafe condition, just connect the bare ends of the wires with a wire nut, which will perform the same circuit connection as the closed switch. Tape the connected wires away from any moving parts, don't let any bare wire come in contact with any metal and keep the lid closed during all parts of the wash, rinse and spin cycles.
Jul 25, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE Washer #27087. Doing a load of wash & wash & lock lid were flashing. Could not unlock lid & panel kept flashing. Unplugged cord for 30 minutes. When I plugged back in...
I would think the lid would unlock once you unplugged the machine. Check your owner's manual for any kind of "emergency reset" procedure. Perhaps the lock mechanism is jammed. Have you tried pressing on the lid or tapping it to see if that frees the lock?
Nov 18, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis HE model number: 110.27072603 washing machine shows LID error code. It wont work at all.... went half way through cycle... help.
Greetings,
this washer has a lid switch problem...or possible main board failure, but lid does concentrate on the lid safety switch. If you remember when you open the lid it stops..well, its a safety feature and prevents tub from spinning with lid open...this one is more difficult to service if your not use to working on washers...try unplugging machine and leaving off for awhile...does the door lock? check switch for lid fault
Nov 25, 2010 | Kenmore Oasis HE 27082 Top Load Washer
KENMORE ELITE OASIS- comes up with a code: DL ( REPEATEDLY - CHECKED THE LOAD- BECAUSE IT STOPS- WON'T RESTART.
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Hello, I have a Kenmore Elite Oasis washer model
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Door won't lock on top loading kenmore elite oasis washing machine
1. Disconnect the electrical cord from the wall.
2. Move the washer forward about 12 inches.
3. Lift the lid and grasp the front of the washer top with both hands.
4. Place your knee on the front of the cabinet and pull the washer top forward and up.
The lid lock mechanism is secured to the bottom of the washer top with two screws. Remove those screws and the wiring will be exposed. Unplug the harness from the old mechanism and connect to the new one.
Secure the new mechanism to the washer top and let the top down.
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Oasis Elite HE washer. I keep
Sep 11, 2009 | Kenmore Washing Machines
My kenmore elite oasis washer has the code dl on it the lid wont lock and we cant fix it
Jun 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis 27062, the lid lock broke
Simply attach both wires from the switch to jumper.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 27032 Logo
1,881 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
