Nikon COOLPRINT Thermal Printer
Problem for Nikon COOLPRINT Thermal Printer
Often after clicking Print, I find mistakes (the document was incorrectly spaced or I have ....
By jessie25 - usenet poster
Often after clicking Print, I find mistakes (the document was incorrectly spaced or I have corrections to make) or I change my mind about printing it. How can I stop this print job and save paper and effort?
Best Solution
posted on Aug 08, 2005
Helpful)
Riddle
Rank: Apprentice
Rating: 0%, 0 votes
Stop the print job by clicking on Start, then Settings, then Printers. Choose your printer if there are more than one on the list. Then choose Printer from the menu at the top of the screen and click on Purge Print Documents.
If you see a printer icon on the lower right-hand side of the task bar at the bottom of the screen, you may be able to double-click it for a faster way to bring up the print window where you can purge the print documents.
Was this helpful?
Yes
No
Solution #2
posted on Apr 02, 2007
Not Rated)
dogwalker
Rank: Apprentice
Rating: 0%, 0 votes
The quickest way to stop printing is to snatch all of the blank paper out of the feed tray. (Don't try to stop a page that has already started to feed.) You will get a box that tells you that you have no paper, and you will get a choice of "continue" or "cancel". Cancel cancels the job without any of the clicking and choosing described by Riddle.
Don't fix your document and hit continue -- it will not be fixed in the spooled file that had begun to print. Cancel, fix, and repeat the print command to spool a fresh copy of the document to the printer.
Was this helpful?
Yes
No
Solution #3
posted on Oct 20, 2005
Not Rated)
Chief
Rank: Apprentice
Rating: 0%, 0 votes
On the HP P1000 you can press the red (cancel / no) button on the front right side of the printer. This will cancel the printing process immediately.
It also removes the document from the printer queue.
Was this helpful?
Yes
No
Popular Solutions for Nikon COOLPRINT Thermal
Questions and Unsolved Problems for Nikon COOLPRINT Thermal
Do you recommend Nikon COOLPRINT Thermal Printer?
Answer
Answer
it says i have to download a high speed usb controller for my wireless usb adapter for it to be... (More)
Answer
On IMac OS 10.4 The printer gave me the choice of printing both sides. On )S 10.6 that choice has... (More)
Answer
Canon PIXMA MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL... (More)
Answer
Canon MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL... (More)
Answer
when i try sending fax it says low memory on display and the fax doesn't go through it stops.-- low... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon COOLPRINT Thermal...:
Top Printer Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
