Question about NetGear WGR614 Wireless Router
Trying to play online with my xbox 360 everything else is ok except that it says that my nat type is set to strict, how do i get it to open? i have a netgear wgr614
  • 854 Answers
A. Determine the IP Address and MAC Address of the Xbox.Note: You may find the IP address and MAC address of your Xbox on your Dashboard's Network Settings. Please refer to your Xbox manual for more information on this.B. Reserve the IP address.1. Please open any web browser like Internet Explorer or Netscape Navigator.2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.3. For security reasons, the router has its own user name and password. When prompted, enter admin for the User name and password for the Password, both in lower case letters.Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.4. When the setup page opens, click on LAN IP Setup under Advanced tab.5. Click on Add under Address Reservation. 6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.7. If the computer you want is not on the list, please click on the Refresh button to update the table.8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address, and Device Name of the computer you wish to add. 9. Click the Add button when done.C. Forward the ports.1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced. For older firmware version, click on Port Triggering tab or just click Port Forwarding on Please select the service type. 2. Click Add and another window will pop up. 3. Type Xbox for Name. Set the radio button to Enable. 4. On Outgoing Port Range, set the Start Port and End Port to 3074. 5. On Incoming Port Range, you also have to indicate 3074 for Start Port and End Port. Save the settings by clicking on Apply. 6. Please repeat steps b to e and indicate 88 for Start Port and End Port. Then change the Name to Xbox2. Note: If it still does not work, you may try these other options:D. Lower down the MTU. 1. Access the Setup page of the router (refer to Step 2 above). 2. Click on the WAN Setup under Advanced tab. 3. Lower down the MTU size to 1492, 1400, 1358 or 1300.4. Click on the Apply button.E. Enable UPnP.1. Go to UPnP tab of the router. 2. Enable UPnP and then save the settings by clicking on Apply. Some websites and devices require UPnP or Universal Plug and Play. Just make sure that it is enabled on the router.F. Upgrade the firmware.Note: Follow the steps below if the above troubleshooting still do not allow Xbox to connect using the router.1. Please verify the router version and model either underneath or at its side panel.2. Go to http://kbserver.NETGEAR.com/downloads_support.asp and please select the model of the router.3. Click the appropriate version of the router.4. Select the link of the latest firmware. Click the button Right-click and Save to Download. Save the file to the Desktop.Note: Please perform firmware upgrade with Wired or Ethernet connection only.5. Before upgrading, please write down all current settings since you need to enter them manually.6. Using the computer hardwired on the router, please launch Internet Explorer and access the Setup page of the router (refer to Step 2). 7. Click on Maintenance and then Router Upgrade. 8. Click on Browse and locate the upgraded file in your Desktop. Then click on Upload.9. Please wait for the router to reboot. After a successful firmware upgrade, you need to reset the router. E. Reset the router. 1. Please push the reset button at the back of the router and release after 30 seconds. 2. Unplug the power adapter for 10 seconds and then plug it back in. (this note should go before the step to Reset the router) Note: Resetting the router will erase all the settings so it needs to be reconfigured afterwards. The router can be reconfigured using the setup CD or by manual configuration.
Posted on Jun 15, 2009
How to unmute yourself on xbox 360
Hi there I can sort understand what you mean and I think this is the answer. If you cannot be heard normally in chat when online even though your mic is turned on or you have made sure that in preferences, you went in to audio settings and made sure you were not on mute? My guess is your having issues with your NAT settings as this can affect you chat settings when online. For example, xheck your NAT status and if it is MODERATE or STRICT then this is why. If you NAT is OPEN then it is because the players you are playing with have a NAT issue. MODERATE and STRICT NAT's will limit what you can do online, including chatting.
Hope this answers your question :)
TEEMAN
Nov 01, 2011 | Microsoft Xbox 360 Console
How do I change the NAT type from strict to open so i can play xbox 360 I have a Belkin 3D54 router
There are several things you need to configure in order to change your NAT to open. Here's a link to help you out:
http://support.xbox.com/en-us/pages/xbox-live/troubleshoot/connection-issues/nat-type-strict.aspx
It has steps that can help resolve your issue.
Mar 27, 2011 | Belkin Office Equipment & Supplies
Me and my gf are trying to use quickplay matchmaking but every time we look for other friends online she always get booted i have put her in the same party and tried in viting but it still boots here
This is because her NAT settings are strict, or moderate and not accepting information from other networks. Look into finding out how to open the NAT settings on your router/modem on Google. You must first find what type of router you have, and find out from there.
Mar 09, 2011 | Activision Guitar Hero Warriors of Rock...
Xbox 360 - Thomson Router TG585 v8 Strict Nat limits who you can connect to. As you can imagine this creates a problem when trying to connect to friends. Kindly, devliver a simple step by step on how to...
OK, i too have had this problem and i have solved it via this website. This thompson modem is also referred to as... o2 wireless box II/III the website link is
http://www.unofficialguidetolive.co.uk/faqs/62-my-nat-is-strict-or-moderate
Search for the specific (o2 wireless box II/III) modem and follow tthe simple instructions onscreen.
Jan 01, 2011 | Video Game Consoles & Games
When i play modern warfare 2 online i go to look for other players and it doesent find any
This could be due to your internet connection or NAT type.
When your in the lobby by yourself were it displays your NAT type, if it says moderate or strict then use this link:
http://support.xbox.com/support/en/us/nxe/kb.aspx?id=979000&lcid=1033
If your NAT type is open, it could be your internet connection.
You might want to upgrade your internet package if it is your connection and never try playing online with a dial up or phone line connection.
hope this helped.
Aug 18, 2010 | Microsoft Xbox 360 Console
L can get into xboxlive but it come up your nat type is strict peopleon network with this nat type may not be able to join certain games or hear other people while playing online for the best online...
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
Apr 08, 2010 | Microsoft Xbox 360 Elite Console - Black
XBOX 360 strict NAT problem
Make sure you also open the ports on your router. IF you have all the appropriate ports open and still have strict NAT, it's more than likely your ISP and you should give them a call.
Jan 07, 2010 | Microsoft Xbox 360 Elite Console - Black
Router will not allow me to play onling games through xbox 360
If the problem has something to do with NAT firewall in your router, then you may need to open certain application ports for your XBOX in the router. You may check this link from Microsoft http://support.microsoft.com/kb/908874 that talks about NAT firewall and XBOX live.
Hope this helps!
Nov 09, 2008 | Computers & Internet
Change NAT to open
Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
Mar 24, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
Change NAT to open
I have this router and have just enabled the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again. Worked for me!
Oct 08, 2007 | Zyxel P660HW-D1 Router
NetGear WGR614 Wireless Router Logo
93 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
