Question about Hunter Fan Company 5/1/1 Programmable Thermostat
In need of a manual for thermostat model number 43558. could you direct me where i need to go. thank you for your time
  • 833 Answers
Go to hunterfan.com and download it
Posted on Jan 04, 2009
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: https://www.homedepot.com/p/White-Rodgers-Single-Stage-Digital-5-2-Day-Programmable-Thermostat-1F78-151/202771121 . The wiring diagrams are in the Installation manual. The direct link to this manual is https://www.homedepot.com/catalog/pdfimages/f9/f955280d-67a2-4502-bb94-4975cd857c0b.pdf . Emerson Climate also has the wiring diagram here: http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6615.pdf .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at http://climate.emerson.com/en-us/products/thermostats/thermostat-manuals . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
Dec 15, 2017 | White Rodgers Home Security
I need a booklet for directions on how to operated & set this thermostate, as I just purchased the home.
Since you didn't give the furnance/air conditioning model number or the model number of the thermostat controlling them, it is impossible for us to give you good advice or instructions.
Suggest you obtain the make and model number of your thermostat and either google it for the owner manual or come back on the site with it and we will try to help find the owners manual for you.
Sep 15, 2011 | Heating & Cooling
We have a White and Rogers programable thermostat (I think that it is an 80 series) We can not find the instructions and I need to check the program. Where can I find directions? If I set a temp. and...
check this link : Don't Know Your Model Number?
after you verify the model number check our website
put the model number on the White-Rodgers Model Number Search/Cross Reference then click submit this will lead you the way on how to secure a soft copy of the instruction manual. If you having difficulty you can call hometechline 18002842925.
Aug 10, 2010 | White Rodgers White-Rodgers 1F85RF-275...
WE need a copy of the instruction manual. Is there a site where we can download a copy? White and Rogers programmable thermostat - 80 Series. Thanks for your help! Fred Skoglund FSkoglund@aol.com
The unit freezes up then don't work
OK I'm looking over the manual and as long as the model number is correct RS2630SH you may have only one of three things causing this. I needing to go to another website to confirm the type defrost system yours has. I will send you a manual when I return. It appears that you have a higher possibility of a defrost heater or defrost thermostat defective.I am getting mixed answers on a decision of a defrost control board. Just make sure your model number does not have a different number or letter missing. I will send as much as I can find on your model but checking the defrost heater and defrost thermostat would be the first thing to do. Unplug refrigerator and remove contents of the freezer rear wall. we need to use a meter to check continuity through the defrost heater. If one is bad replace both defrost heater part number DA47-00154A and defrost thermostat part number DA47-10160F.
One model came with a defrost control board but I just cannot find one on that model number so the motherboard controls defrost. I will send manual shortly. Thanks, Sea Breeze
Jan 11, 2010 | Samsung RS2630SH Side by Side Refrigerator
How do i change my thermostat from celcious to ferenheight
Go to
myhome.honeywell.com
and search for a manual for your model number thermostat on the right hand side of the page.
Hank
Oct 13, 2009 | Honeywell Programmable Thermostat Heater
I set the tstat manualy for 77 and when we wake up it reads83 what? thanks
You have a pre-programmed thermostat. You'll need to put in settings for each program setting in order to have the thermostat provide you with the heating/cooling temperatures you want at each time period of the day and for each day of the week (in the case of a 7 day programmable model.
Whenever you put in a manual temperature setting, it is only a temporary setting that will get reset at the next pre-programmed temp setting, unless you set the "HOLD TEMP" setting and select the number of days you want it to hold the temp you manually set on the T-stat.
If you can provide the model number, I can help you further with the programming of your T-stat.
Hope this helps and best regards!
Thanks.
Aug 05, 2009 | Honeywell Programmable Thermostat Heater
I can not set my fridge (move the arrow) to "5" model 106.5365230
This tells me that you need a new thermostat part number 297216600
You can get the part from Sears Parts Direct or at he link below; Above your link the model number is Sears number 25338622896
Below enter the part number in the model search feature.
Thanks Sea Breeze
http://servicepartstec.blogspot.com/
May 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Temperture control switch not working
If the temp control works manually then that tells me that the tube that is connected to the thermostat is not telling the refrigerator compressor and fans to come on by sensing the temp change. The part number for the thermostat is 2198202 if the model number is correct above your post. If ED25PQXF is not the model number then we need to possibly change that number. Let me know, Thanks Sea Breeze
May 19, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
118 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
