Question about Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with PuR Filtered Ice and Water
How do I change the Whirlpool ED25DQXDW04 water filter?
My ice and water taste bad and I guess I need to change the filter. Where is i located in this model? Whirlpool ED25DQXDW04
  • 1073 Answers
SOURCE: Ice from Ice maker smells
if the ice has been in the freezer ice bin for a couple of weeks or if you added any food to the freezer that is not totaly frozen before adding then the ice will absorbe the odor of the food added, also the defrost of the evaperator will also add to bad ice taste
a new filter for the ice maker is maybe needed, depending on how long it has been since it was changed
if it has been changed, youcan try this whirlpool tip
put a small pie pan in the freezer and one in the fresh food section
add 1/2 inch of fresh coffee not coffee grounds to each pan
leave in for 24 hrs
dump out coffee in the sink drain
repeat the process
dump coffee in 24 hrs
odor GONE
Posted on Apr 17, 2008
change water line into refrigerator Alge will start to grow, also flush line into refrigeratorwith a little bleach to kill any alge in the line. It will take a while to get bleach
Posted on Sep 26, 2008
  • 750 Answers
SOURCE: Bad water & ice cube taste
Hello redwood City
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
Please remember to leave a rating.
Posted on Oct 12, 2008
  • 446 Answers
SOURCE: Ice tastes bad even after I changed the filter?
allow your ice maker to dispose old water that is still stucked on its hoses, just throw those unpleasant ices's and water would simply replenishes with a a fres and good supply
Posted on Nov 27, 2008
  • 50 Answers
SOURCE: Ice tastes funny all of a sudden.
you need to throw out the ice. ice gets stale after a couple of weeks , so toss the old ice. also is there something like garlic or another food that has a strong oder uncovered in your refrigerator section? air flow covers all of the unit, both refrigerator and freezer sections. if your refrigerator is not smelly , put an open box of arm hammer baking soda on a shelf in both sections of the refrigerater. if water and ice still taste funny shut off water supply and check the filter at the rear in the lower part of the unit. take off connecter and visibly check the strainer in the water valve,clean it out by removing it and rinsing it under the sink faucet. make sure that water from other faucets taste ok . the only thing left is to flush out the water tank by filling up glasses of water until the water gets room temperature . that's about all you can do short of replacing the water line leading to the refrigerator, although i have never had to do that before. good luck
Posted on Jan 23, 2009
Whirlpool ER2CHMXPL ice tastes bad
If I were you id replace the ice filter or get an ice mold and put water in it and stick it in the freezer
Jan 16, 2012 | Whirlpool Refrigerators
Nasty tasting ice cubes
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Jul 13, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Whirlpool model # ED25DQXDW04 - Everything freezes in the back of the refrigerator and it stopped making ice cubes - no water comes into the freezer side to make ice cubes. We're throwing away a lot of...
This may not be the problem now but by the sound of the malfunctioning ice maker, it could be in the future. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at
Jun 07, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool ED25RF Does ice maker have a filter? My ice taste funny and sometimes its dirty
The ice maker doesn't have a filter , the problem could be the ice maker itself that the tray ,which is made out of aluminum is losing particles.Look at the conditions of the ice maker tray ,if you see like white spots replace the ice maker.
Aug 30, 2009 | Whirlpool Refrigerators
Smell & bad taste of water from refrigerator dispenser
depending on the brand and the style, locate the filter and change it out. Please note that you must empty out the remaining water from the refrigerator cause if you don't, when you change out the filter you might get the same taste for a while until all the remaining water is replaced by freash water.
Jun 23, 2009 | Refrigerators
Ice tastes bad from ice maker
Sometimes filters have issues like this even being new , it is located at the bottom kickplate [round] , pick up a new filter -part number 4396841 - install the filter , dump remaining ice in bin out , purge the water through the new filter through water in door for a few minutes and you should be good.
Apr 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool water dispenser ...metalic taste
Hi!!! you seem to have a bad water valve in your refrigerator.change your water filter and the water valve on the back on the frig..
Jan 03, 2009 | Whirlpool GD2SHGX Refrigerator
My new Whirlpool Refrigerator the water and ice still stink
Dec 19, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with PuR Filtered Ice and Water Logo
404 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
