Question about E-Machines eMachines Desktop PC
EMachines T3092 MoBo Layout
I'm doing free work on a puter for a family in need. They say the unit was still working but started to smell hot so they shut it off. Two ears on the CPU heatsink/cooling fan bracket broke and let the assembly drop off the CPU and in the moving of the unit the assembly knocked three wire sets off mobo. I replaced the plastic bracket but now unit won't power up and I don't want to start randomly sticking plugs on sockets. The wire sets that are displaced all go to the front panel and are:
1. The wires that go to the cardreader/firewire ports.
2. The wires that go to the mic/earphone ports.
3. The three plugs that go to front panel; H.D.D. LED (RED/WHITE wires), Power LED (GREEN/WHITE wires) and Power Switch (BLACK/WHITE wires).
Does anyone have a layout of mobo or can help me with wire placement on mobo?
Thanks in advance,
Dave
  • craig799 Jan 08, 2009
    I went through the site and did not see how the wires connect to the Motherboard. Any ideas?
  • Leslie May 11, 2010
    did you go to emachine and check there
    President:
  • 2,692 Answers
Here is the website for that particular mother board. This should give you what you need.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T3092
Posted on Dec 21, 2008
HOW DO YOU CHANGE THE STATUS ON T3092 eMACHINES SO IT WONT USE DIALUP METHOD TO CONNECT TO INTERNET
To create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on the tools at the bottom of the drop down list will be internet options.
Click on the connections tab tick in the box never dial a connection.
Hope this helps.
Nov 21, 2012 | E-Machines T3092 PC Desktop
Emachine t3092 - enabling for wifi
Install a wireless card in your machine then configure it in windows.
Jul 08, 2012 | E-Machines T3092 PC Desktop
Need wiring diagram for emachines T3092
I sorry I am a computer tech there is no such thing as a wiring diagram you might need to take it somewhere or have a friend who is into computers fix it I wish it worked that way :)
Feb 29, 2012 | Computers & Internet
I have a Shure mic hooked up to my emachines T3092 through a Behringer mixing board. The board works fine, but I am getting over modulated scratchy voice when I record to cool edit pro. Tried every...
Which particular mic?
Go through the signal chain. Mic to mixer to pc.
All the level changes are suspect, what busses are you using...
e.g.
mic to channel 1 on mixer.
trim on mixer 1
fader on mixer 1
L/R balance
fader on L/R
which output from mixer are you using
Then the windows mixer (start/run "sndvol32.exe")
adjust the volume, WAVE, mic, etc.
My first instinct is the windows mic level.
Dec 03, 2010 | E-Machines T3092 PC Desktop
I need a boot disk for an e-machine t3092
you can find the restore disk here
May 19, 2010 | E-Machines T3092 PC Desktop
Have a problem with my machine T3092. The monitor
Stop using the restore disc, try installing the OS instead and make sure you have your driver software
Dec 18, 2009 | E-Machines eMachines Desktop PC
Emachine t3092, no video, can't find certain desktop files
If they're not on the drive, they're not on the drive. Your only other option is to search the free disk space for the remainder of those files. For that you can use the free trial of O&O Unerase Personal. I hope you get those files, never fun to lose memories over a peculiar computer issue.
Mar 22, 2009 | E-Machines eMachines Desktop PC
Emachine T3958
Hopefully eMachines are consistent with their wiring/layout design, that being the case this diagram for T2898 (by benz18724) should point you in the right direction...
Alternatively compare the abbreviated pin symbols on the header to the motherboard and match them up.
Jan 31, 2009 | Computers & Internet
T2893 desktop did not power on when I hit the power button
If you can find someone that has the same model, that is the best way to make sure it fits. Some other motherboards will fit, but you may have to do some work to get them to fit. The best way would be to try to do some research on your particular motherboard (mobo) on the internet. Sometimes it will have a manufacture’s name and model on it, try googling it and see what type it says it is (ATX, mini-ATX, AT, etc). One problem you may have is the power button connectors may not be compatible with your new motherboard if you get something besides an emachine mobo. If you are good at electronics it will not be much of a problem for you.
Unless you get an exact e-machines mobo, your OS will most likely not work at startup. Windows XP does not like wholesale changes like a mobo. When it sees that a major configuration change has happened it sometimes freaks out. Sometimes it will just ask you to re-activate windows other times it gets stuck in a reboot loop. Hard rive and CD rom should still work, provide you do not get too new of a mobo. Older HDD and CD drives were IDE connectors, newer ones have SATA connectors. Unless your mobo and power supply unit (PSU) have the correct connectors you will not be able to use them.
To the poster who asked if it could be anything else besides bad mobo. Yes it can occasionally be a bad power supply unit (PSU). A bad PSU does not necessarily mean no power, just not enough power to run the computer. You can try swapping it out with another one of equal or greater output watts. You can try removing the power connectors from the drives and then remove the memory and see if it changes the boot up procedure of your machine. More beeps, different beeps, no beeps, etc. Add one component back at a time to test. Make sure you get the same results and not just a one-time fluke start up. If a memory stick is bad, it usually is bad. A power supply or mobo can be flaky and fail some times and not others.
Jan 25, 2009 | E-Machines eMachines T3830 PC Desktop
E-Machines eMachines Desktop PC Logo
299 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
