Question about Sony XM-SD22X Car Audio Amplifier
Amplifier won't turn on
I have a SONY XM-SD22X, and it was working fine. The LED light turned off and it did not want to turn on again. I checked the fuses, and they were fine. I read the manual and it said to check the ground. I checked it and it was working fine, but know it doesn't want to turn on again. I already checked the fuses and they are fine. So what is the problem?
    Problem Solver:
  • 13 Answers
Check your power cable as well, and also try to relocate your ground wire to a another place in your car...
Posted on Aug 15, 2007
The red light turns on? how do i make it go off?
The red light is usualy an indicator that the amplifier is going into protection. There could be a number of reasons that this might happen. Here are some: 1. the load that the amplifier is trying to drive is not compatible with the amplifiers specifications. 2. the cables leading from the amp to the speakers/sub woofers are shorting somewhere. 3. the amplifier is heating up above its capability. 4. the amplifier is not recieving the apropriate amount of power. Check if any of these are the reason but if you give me more details such as when does the red light go on and what you have connected to it and how, i will be able to better assist you.
respectfully
dreamsystems
Feb 04, 2011 | Sony XM-SD22X Car Audio Amplifier
Hay im avery and i got 1 of these it is a great amp but my fuze keeps going do you think u no what the problem is
you have a graounding problem(short crcuit
) or power over load. thats protects the amp from. go back and check all the wiring.
Jul 13, 2009 | Sony XM-SD22X Car Audio Amplifier
Car amp has power but will not push subs
output blown on power supply - repair by tech required.
Jan 12, 2009 | Sony XM-SD22X Car Audio Amplifier
I need he;p!!
Width (mm) - approx.
403.0
Height (mm) - approx.
55.0
Depth (mm) - approx.
277.0
Regards,
Martin
Aug 25, 2008 | Sony XM-SD22X Car Audio Amplifier
What size amp is this
  • 1200W max power
  • 200W x 2 RMS into 4 ohms
  • 500W x 1 RMS into 4 ohms
  • Variable 50 - 300 Hz low pass filter
  • 40 Hz EQ boost
It is stable to two ohms.
The amp does not say wat size it is
At 14.4v DC input...
200w RMS x 2 into 4 ohms
250w RMS x 2 into 2 ohms
Let me know if you have any other questions.
I need a solution for my amp
Your XM-SD22X amplifier only has 2 channels. If you want to run 4 speakers then you could parallel 2 speakers on each channel but you need to check that the impedance is not too low. If it is too low then put 2 speakers in series on each channel but this will not be as loud. Regards
Sep 26, 2007 | Sony XM-SD22X Car Audio Amplifier
Installation manual
You can find the manual at the following link: http://esupport.sony.com/US/perl/model-documents.pl?mdl=XMSD22X&LOC=3
Sep 15, 2007 | Sony XM-SD22X Car Audio Amplifier
LED power protection light not turning on
Check the fuse on the amplifier; if it's good, then you need a multimeter or voltmeter for further testing. With the meter's black probe on your amp's ground terminal and the radio turned on, both the power and the remote terminals should test at about 12 volts. If neither terminal shows voltage, you may have a problem with your ground connection; if both do, there's a problem with the amp.
Feb 20, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony XM-SD22X Car Audio Amplifier Logo
50 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
