Question about HP OfficeJet J4580 All-In-One Laser Printer
Need a users guide
I ddo not know how to use my j4580 printer to fax or scan my documents can you help. I also need to down load the manual
    Problem Solver:
  • 11 Answers
Here is the users guide: http://h10032.www1.hp.com/ctg/Manual/c01368573.pdf
and the Setup Guide: http://h10032.www1.hp.com/ctg/Manual/c01368521.pdf
Please go through the setup manual first to get everything working. Good luck.
Posted on Dec 20, 2008
How can I send and receive a fax from Lexmark x4270.?
You can send faxes via the operator panel, the All-In-One Center, or the fax driver.
Using the Operator Panel:
  1. Make sure your All-In-One is switched on.
  2. Load up to 30 sheets of your original document face down in the ADF (Automatic Document Feeder). Note: When you load small paper sizes, place your document in the center of the tray and adjust the paper guides to the edges of the paper.
  3. On the operator panel, press Fax.
Using the keypad you can:
  • Enter the fax number, and then press Black or Color.
  • Press Speed Dial, and then:
- Use the arrow keys to scroll through the list to find the number you want, and then press Black or Color. - Use the keypad to enter a two-digit number (viewable in the upper left of the display), and then press Black or Color.
The All-In-One scans your document and sends your fax to the number you entered.
Using the All-In-One Center:
  1. Make sure your All-In-One is attached to a computer.
  3. From your desktop, double-click the Lexmark 4200 Series All-In-One Center icon. The All-In-One Main Page appears.
  4. Under Productivity Tools, click Fax an image or document.
  5. Follow the instructions on your screen to complete the task.
For a more comprehensive guide on how to send and receive faxes using your Lexmark X4270 printer, please refer to the Lexmark X4270 User's Guide.
Aug 17, 2011 | Lexmark X4270 All-In-One InkJet Printer
I haVE ONE NEVER MADE A FAX CAN YOU GIVE ME THE STEPS ON HOW TO MAKE ONE QUICK MY DAD JUST PAST AND I NEED TO SEND FAX AND I DONT NO HOW MY DAD DID IT ALL THE TIME PLEASE HELP
How to fax: 1. Load your original document face down in the ADF. Adjust the paper guides to the edges of the paper. printtech_49.jpg
2. On the control panel, press Fax. 3. Use the keypad. Enter the fax number and then press Black or Color. The All-In-One scans your document and sends your fax to the number you entered.
For more information, you can also refer the the Lexmark X4200 Series User's Guide. I hope this information has been helpful. Thanks.
Jan 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
ANyone else having this problem? My j4580 has
Clean adf ,connect directly with wall jack or Change automatic document feeder,
Jul 28, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do i scan a document?
Visit to the given link and download the manual. The detail procedure is given in the manual... http://www.retrevo.com/support/HP-J4580-Multifunction-Printers-manual/id/20067ag014/t/2/
Hope this has helped you.. Please rate the answer.. Thanks...
Jun 25, 2010 | HP OfficeJet J4580 All-In-One Laser...
How to scan with an HP J4580
Do you have the full-feature software installed? What OS is on your computer? Assuming you have the full-feature software installed (installed before connecting the printer to the computer) and a direct USB connection (with a good cable and functioning USB port), you have two choices.
Start the scan from the computer (have the document face down on the glass or face up in the ADF (for models with the document feed) and the all-in-one ready. For this, with Windows, launch the HP Solution Center (Start > All Programs > HP > HP Solution Center), then click either the Scan Photo or Scan Document button in the program. Set the desired scan settings (this should come up if it wasn't turned off) then click Scan.
Alternatively, you can start the scan from the button (it's the one closest to the button with an X (cancel) on the all-in-one and that will launch the HP Solution Center (assuming HP Digital Imaging Monitor is running). The scan menu will also come up on the printer screen with requests for more setting information (destination etc.)
With Win7 and Vista, Paint will acquire scans (Import from Camera or Scanner). Some versions of Vista and most of Win7 also include Windows Fax and Scan which will also handle new scans.
I hope this helps.
May 01, 2010 | HP OfficeJet J4580 All-In-One Laser...
I got the manual for my J3680 all in one printer, BUT
Hello
It sounds like the scanner/fax is not seeing the original document that you want to scan or fax.
Per Page 20 of the User Manual, the original needs to be placed face down in the document feeder. (The document feeder is on the top of the printer, behind the display.)
When you insert the original, make sure the leading edge is sliding into the top of the printer (towards the front of the printer).
Per the user manual, you should hear a beep and/or see a message on the display stating the loaded pages were detected.
If you are not hearing the beep or seeing the message, your original is not loaded correctly - try sliding it further into the printer.
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Apr 30, 2010 | HP J3680 Officejet All In One Printer
HOW TO SET UP MY FAX MACHINE ON MY LEXMARK X 3500-4500 SERIAL# 08339128730 2007/08 MY E-MAIL ADDRESSIS wworkman@2triad.rr.com CAN NOT FIND INSTRUCTIONS IN MY MANUAL PLEASE HELP WILLIAM
There is no Fax built in to the Lexmark X3500-X4500 printer. You can use the Lexmark Imaging Studio software to scan documents and send them with fax.
See page 68 of the 3500-4500 Series User's Guide.
1 Load an original document facedown on the scanner glass.
2 From the desktop, double-click the Lexmark Imaging Studio icon.
3 From the left pane of the Welcome screen, click Fax.
4 Select the Document option.
5 Click Start.
Mar 01, 2010 | Lexmark P4350 All-In-One InkJet Printer
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
I cannot get my fax to work, how do I send and receive faxes ,I am not sure how to connect the phone lines, which line goes where? bewildered not so much a computer whiz
Do you have the user's guide? That usually has all the information you need to install and set up the unit. If you don't, you can always go to the website and download a copy. Then follow the instructions.
Mar 10, 2009 | Dell 810 All-In-One InkJet Printer
I do not know how to scan a picture to my computer. Can you tell me the steps to take to scan a picture and save it to my computer?
i bought a new j4580 ann in one printer . was it because i did not get a users guide or manual how will know what to do.
Dec 16, 2008 | HP OfficeJet J4580 All-In-One Laser...
HP OfficeJet J4580 All-In-One Laser Printer Logo
142 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
