Question about Evenflo Discovery - Midland Blue
Car seat straps
I was given a car seat from a family member and i didn't get the instruction manual with it. my baby is starting to outgrow the shorter straps and needs it adjusted .I cannot figure out how to fix this problem please help. thank you alicia
  • Anonymous Mar 24, 2008
    I hope some one can help me figure out how to change move the shoulder straps between the 3 slots
  • 944 Answers
Try this link for evenflo discovery FAQ's; https://plweb.evenflo.com/faqs.aspx?catid=22&subcatid=114 If you get no luck from that, then their customer support contact details are accessible at the bottom of the page. on this link; http://www.evenflo.com/Home/tabid/36/Default.aspx They have installation videos etc for your seat. Hope this helps :)
Posted on Apr 03, 2007
In order to change from the toddler seat to the booster for a child over 40 lbs, what do I do?? does the seat just become attached to the car by the seat belt? does it need to be attached by other...
please feel free to call at 1-800-544-1108 and they can send you a manual in case you dont have it.
*To convert the car seat into a booster seat, turn the car seat over and remove the pin that holds the base in place. tHEN REMOVE THE BELTS AND THE BUCKLE.
*To remove you need to bend/twist the keeper until you can push it UP through the seat and remove the belt/strap. It is now a booster seat for use with a lap/shoulder belt in the car. Store all the parts you removed in a ziploc bag for when your child outgrows it so it can be reused
PLEASE RATE MY HELP :)
Sep 17, 2010 | Cosco Alpha Omega Elite 5-Point 22-155
How do I convert my car seat to a boster seat --I have an Eddie Bauer Deluxe 3-in-1 Car Seat
Remove the large bar holding the bottom plate. One side will have a plastic retainer which you just move to the side and pull the barr all the way out from that side. There is a rear leg that you can pull down and back which will make the seat sit more upright. Remove the strap (it is one solid strap) and be sure to save all the parts if you plan on giving it to a needy family when your child outgrows it. The center clip is easy to remove, turn the seat upside down and find the metal retainer and pull it up, turn 90 degrees and feed it through the hole and pull on the other side. Now you should have a strap/clip free seat that will be a "seatbelt positioning booster seat".
Jan 18, 2010 | Eddie Bauer 3-In-1 with Latch
How do you convert it from a car seat to a booster seat?
Take the base off if it has one, either clips, screws, or a metal rod holding it on. Take the belts out. They should slide off the clip at the back of the seat, then unthread belts from buckles. The buckle/strap between the legs usually has a metal keeper below the seat. To remove you need to bend/twist the keeper until you can push it UP through the seat and remove the belt/strap. It is now a booster seat for use with a lap/shoulder belt in the car. Store all the parts you removed in a ziploc bag for when your child outgrows it so it can be reused.
Dec 08, 2009 | Cosco Alpha Omega Elite 5-Point 22-155
Need to adjust restraining straps up to next position cannot get straps through and cannot see how they come out (No instruction Manual when bought) Actual Model not known but on a label has SI 2008 265776
Contact the manufacturer. They ought to email you a manual within minutes. Manuals for car seats are very important, so you'll know when your child outgrows it. In my car seats, the harness is hooked on the back to a metal buckle-looking thing that is attached to a piece of webbing. The webbing goes under the seat and out the front, where you pull on it to adjust the tension. Simply remove the harness straps from the buckle-looking thing, pull out the front, push through the higher harness strap position, and reattach to the buckle-looking thing.
Jun 11, 2009 | Baby Gear
Missing Instruction Manual
go to the web site that the modle nummber said
Nov 05, 2008 | Evenflo Embrace
try the manufacture website at this link
http://www.coscojuvenile.com/instructions/
you will need manufacture date and model number and you can view them online
Aug 04, 2008 | Baby Gear
Manual is available at the manufacturer's website, follow this link:
Feb 22, 2008 | Cosco Alpha Omega Convertible 22-150
Lost manual.
Here's an instruction that could help you...Please go to this link and dont forget to rate me. Thanks
http://www.coscojuvenile.com/instructions.asp
Jan 23, 2008 | Cosco Alpha Omega Elite - Hammer Print
Strap Adjustments
Yes, Im sure you can find it in a department store or online store. Try target.com probably, they are called extension strap like this http://www.babyonthemove.co.nz/shop/Car+Seats/Carseat+Accessories/600mm+Extension+Strap.html?id=akv7atuH
Jan 22, 2008 | Cosco Summit 22260 - Bouncing Sheep
Evenflo Discovery - Midland Blue Logo
500 people viewed this question
Top Evenflo Baby Gear Experts
Colin Stickland
Colin Stickland
Rob Sinbad
Rob Sinbad
Stitch85
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
