Question about Car Audio & Video
I have alot of tire wear on my car on one side what should I do
    Sergeant:
  • 233 Answers
If the wear is on just one side, especially the front tire, you more than likely need to have an alignment done. Most shops will do an alignment check for free.
Posted on Dec 21, 2008
Why is the front tires slanted when I reverse or turn on my 1995 ford f-150
A normal amount of angle is proper for the kind of car or truck you drive. Horizontal angle is called "Toe-In" or "Camber" and Vertical angle is called "Caster." A wheel alignment specialist will be able to tell you quickly whether your car or truck requires the $100 wheel alignment procedure to assure your tires wear evenly on each axle. Front tires always wear more, particularly in front wheel drives vehicles as the tires have two kinds of wear: steering wear from side to side, and increased friction wear from torque application from acceleration. FWD vehicles generally require tire rotations twice as often as RWD vehicles for this reason. Always get a wheel alignment when replacing both front tires with new ones to increase tire life.
Apr 10, 2015 | Ford Cars & Trucks
Tip
Keep your tires in good lasting shape
Did you ever see the statements in the tire dealer shops stating a specific tire model will last approx. 50-75,000 miles/
This will never happen unless you have your tires rotated every 7500 miles, the front tires wear excessively compared to the rear tires in 90% of the cars/trucks.
Why? Because the front tires in most cases are the drive tires(front wheel drive) causing the front tires to ocasionally spin causing excessive wear and also the front tires are the ones that guide your vehicle down the road, when you turn the steering wheel you are turning the front tires to make the car go in the direction you want thus causing more excessive wear to the front tires, in order to get even wear from front to back tires one must move the front tires to the back tires at 7500 mile intervals, making sure the tires only get rotated to the same side of the car each and every time, if you move a right rear tire to a left front position, severe damage may occur so please keep them same side rotations.
Also have your wheel alignment checked at a tire shop each time you bring it in for a wheel/tire rotation as pot holes, hitting curbs,etc all can effect the way the tires wear if the alignment goes out.
on Jun 06, 2010 | Chevrolet Malibu Cars & Trucks
What causes front tire wear on inside & outside edges
Under inflation. When the tire doesn't have enough air pressure, the center tends to be pushed up from the road. Thus causing outer wear on both sides. alignment problems cause wear on one side or the other. Over inflation causes the center of the tire to wear .
Aug 31, 2014 | Cars & Trucks
Front end clunck noise on front left with severe tire wear on the inside of tire.happens going strait and on turns over bumps
ball joint has gone or could even be the wheel bearing. jack up the front with wheel on and hand on wheel 9 to 3 and wiggle and then 12 to 6 do the same if there is alot of movement the bearing has gone. ball joint check all the connectors on that side steering etc if they move side to side easy then the ball joint has gone they should be stiff to move.
Mar 16, 2014 | 2004 Dodge Ram 1500
Alignament rear suspension
I replaced the rear struts, when removing i discovered one was totally bad, they didn't seem bad from testing and recovered quickly when pushing on the bumper, but were bad. after replacing my rear tire wear is even after 5k miles. mine were wearing from inside to outside too.
Apr 21, 2013 | 1999 Honda Civic
Wearing outer edges of front and back left side on 2006 toyota tacoma
tires need to be balanced that will fix vibration. tire wear is a camber problem. get a four wheel alignment
Mar 24, 2013 | 2006 Toyota Tacoma PreRunner
My 2002 f250 pulls from one side to another at random times
are the tires wearing uneven? sounds like a bad tie rod or drag link. jack up left or right side in the front just enough to get wheel off ground. Try to left from right with the wheel(with ur hands at the 3 and 9 clock postion)do you have alot of play?
May 25, 2011 | 2002 Ford F250 Super Duty SuperCab
All four tires are wearing out on sides of tires
If the tires are wearing on both sides and not the centers, instead of just one side per tire then the tires are under-inflated. Inflate to the proper psi.
If the tires are wearing only on one side, ie, left side tires wear on the left side, right side tires wear on the right side or vice versa, then the alignment is off, adjusting the camber may fix the problem.
Feb 28, 2011 | 2006 Chevrolet Silverado 1500 2WD
Front tires wearing faster than should.
uneven wear- on one side of each tire- need front end alignment.
wearing in center- over inflated tires.
If they seem to wear evenly but quicker than they should, rotate with the rear so they all wear at same time.
Dec 23, 2010 | 2002 Mazda Protege
I noticed a louder engine sound at approx 45 mph, like a humming or aceleration sound, I had the driver's side wheel bearing replaced to the tune of approx $300 but the sound still remains (the repair guy...
Chevrolet has a common problem with integral hub and wheel bearings wearing due to exessive use or lack of lubrication, the balls or rollers and races become pitted ,scored or just plain damaged which will infact cause a loud humming or growling noise. I have had some humm at about the same speed but usually they will start to make noise at any speed. I would have to hear the noise to be sure cause there are many things to cause a humming noise like odd tire wear, bad idler pully bearings, e.t.c. the tires should be lifted checked for excessive play in the bearing. Take tire off depress brake piston in just enough secure brake rotor use stethoscope spin hub while listening. maybe he replaced wrong side seen that alot, seen tire noise mistaken for bad bearing to if struts or shocks are worn can cause tires to be choppy. I would recommend taken back 300 dollars is alot of money to not fix your problem.
Jul 15, 2009 | 2005 Chevrolet Equinox
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
