Question about Panasonic KX-TG2382 Cordless Phone
Panasonic KX-TG2382 is flashing E9
Phones won't link to base. Base blinks all linghts and has the code E9 on it.
leroyal
  • 2120 Answers
SOURCE: How to link 3 same model cordless phones to one base
Only if you have 2 phone lines.
Posted on Nov 06, 2008
  • 4 Answers
SOURCE: Panasonic KX-TG2367 says "No link to base".
This worked for my mother's KX-TG2357:
We tried doing what it said in the manual on page 54. That didn't work! She then decided to just unplug everything. About 3-5 minutes later, plugged everything back in, and lo and behold, everything was working fine!!
Posted on Feb 08, 2009
ynotphone
  • 192 Answers
SOURCE: "no link to base" error message
Sounds like the antenna is not working, and signal is not getting to the cordless sets.
Try unplugging your base station (unplug everything; power and phone cable - the basestation were all the cords are plugged into) and leave it unplugged, pull out all the batteries in the phones, and then start by putting all the batteries back into the phones.
Once the phones are back and powered up, plug in the base station again, and see if that helps.
All this is doing is re-setting the phones and base station and forcing them to re-link to each other.
I hope this helps.
Posted on May 01, 2009
SOURCE: i have problems the no link to base with Panasonic
  • Press and hold the LOCATOR/INTERCOM button for the extension that is displaying "No Link To Base" on the Base until a beep sounds.
  • Press and hold the FLASH/CALL WAIT button on the Handset that is displaying "No Link To Base" until a beep is heard.
  • When registration is complete, a beep sounds from the handset.
  • Wait for 20 seconds after registration is complete to allow the handset to establish communications with the base.
If this doesn't work or it keeps happening, replace the battery in the handset.
Posted on Jul 08, 2009
SOURCE: Panasonic Kx-TG2432 Displays E9
Same here on KX-TG2248:
"Answer on" is flashing rapidly.
"Message/Slow Talk" is flashing rapidly.
"In Use/Charge" is flashing irregularly.
LED displays "E3" (and "set clock" symbol is flashing).
Removing and restoring power, many times,
produced one "spontaneous remission"
(it worked fine for several hours)
but next time moved (having to disconnect power),
it's now quite "committed" to remaining "insane" as above.
Posted on Sep 15, 2010
Yellow light constantly flashes on all handsets
Yellow light constantly blinks on top of all the cordless phones
www.faqqq.com/.../yellow-light-constantly-blinks-on-top-of-all-the-cord...
Question Product: Panasonic KX-TG5432 Digital Dual Cordless Telephone Question Details: Yellow light constantly blinks on top of all the cordless phones The.
Panasonic KX-TGP550 Normal Status Lights
www.statuslights.com/panasonic/panasonic-kx-tgp550.html
Red (Rapidly Flashing), The Base Unit is paging handsets. (KX-TGP-500 only). Amber(Solid), The Base Unit's IP address may conflict with the IP addresses of ..
Jan 16, 2016 | Panasonic KX-TG7641M KX TG7641M KXTG7641M...
Panasonic KX - TG5664
may be the problem is with the speakers check that first
Jun 02, 2008 | Lands Phones
Panasonic kx tg1100bx kxtg1100cx manual
Did you try to register your handset to the base?
If not then do so , and use the default pin code 0000
or *7000
Oct 26, 2013 | Panasonic KX-TG5632 Phone
Jul 28, 2009 | Panasonic KX TG5100M Cordless Phone
An error message is apearing on my handset,maybe a code is needed
Try this method:
Press locator button on base unit for 3 seconds. Now push flash button on handset for 3 seconds.
This MAY reregister phone to base unit. It did not work for me, more tests at http://www.panasonic.com/consumer_electronics/telephones/ts_guide1.asp
Mar 20, 2009 | Panasonic KX TG2258S Cordless Phone
TOO FAR FROM BASE
Hi! This may cure your problem!
Re-registering the handset
If “No link to base. Move closer
to base, try again.
” is displayed
even when the handset is near the base
unit, you may need to re-register the
handset to the base unit.
Important:
LMake sure the base unit is not being
used.
LHave the handset and base unit near
each other when re-registering the
handset.
LKX-TG5422 and KX-TG5423 only:
Confirm the extension number of the
handset which has lost its link to the
base by placing the handset on the base
unit or charger.
If you accidentally assign another
handset’s extension number to it, the
other extension will stop functioning.
1 Handset:
Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Registration” by pressing
4 KX-TG5421 base unit:
Press and hold {HANDSET
LOCATOR
} until the CHARGE
indicator flashes.
KX-TG5422 base unit:
Press and hold the handset locator
button that corresponds to the handset
you want to re-register ({HANDSET
LOCATOR
1} or {HANDSET
LOCATOR
2}) until the CHARGE
indicator flashes.
Below is a link that will take you to the instruction manual for your phone.
http://www.phone-manuals.com/panasonic/KX-TG5422M.shtml
Hope this helps! Hal
Feb 27, 2009 | Panasonic KX-TG5422M Cordless Phone
Ring tone off
Press the Function key (bottom of handset, black button that says Mute but has Function underneath)
In the silver button, in the top middle of the handset, press the down arrow button twice and display shows Ringer setting.
Press the right arrow key, then use arrow up and arrow down to adjust volume level. when you're done, press the right arrow button to SAVE.
Jul 27, 2008 | Panasonic KX-TG2382 Cordless Phone
Panasonic KX-TG2382B
if you have a computer, put the error codes in the browser, sometimes they will come back to tell you, did you unpower it completely, is there a reset on it,Matt
Oct 29, 2017 | Panasonic KX-TG2383 Corded Phone
No link to base Panasonic KX-TG2357
Astoundingly, the KXTG2357 works only with the original handsets it came with! You cannot replace a handset by buying another one (same model, of course) and register it with the base. How ridiculous is that? It's like buying a lamp that works only with the bulb that came with it. Replacement bulbs won't work. Well, Panasonic is one company I won't be dealing with anymore!
So, the solution is to get along with one less handset, or buy a new phone unit!
Jan 05, 2008 | Panasonic KX-TG2357 Cordless Phone
Panasonic KX-TG2382 Cordless Phone Logo
124 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
