Question about HP and Compaq Pavilion Replacement 200w Micro ATX PS3 Power Supply (PSHPPAVILION) Power Supply
No pwr supply light on Pavillion desktop pc
Plugged in but no power supply light. It turns on and off while putting the plug in. Tried adjusting supplly switch but still nothing.
  • gerrykobel Dec 21, 2008
    I have same problem on a pavillion 300. Power supply light goes on and off and no power
  • chowcury Dec 22, 2008
    this problem with my pavilion 510w occured after a blackout... had this problem once before a few months ago but after playing around with the red supply switch under the power cord plug the light came back on for good.
    Novelist:
  • 206 Answers
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacement from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
Posted on May 13, 2014
fwadley
  • 482 Answers
SOURCE: power supply light has blinking green light
If the power box is bad, The computer will not come on. if you only get a green light, you would need to start with replaceing the power box, if you get a new one and the same thing happens, then the mother board is bad too.
Posted on Nov 27, 2007
WhIzAtIt
  • 136 Answers
SOURCE: Power supply light flashing.
Computer power supplys are modular replacement fixes. Better to replace the whole thing then try to repair.
Posted on Sep 24, 2008
SOURCE: Flashing Green Light on Power BESTEC Power Supply
Hi. NO, *********** board is not fried. I am not sure what the problem is but I do know how to fix it. It is usually casued by power outages (even if you have UPS supply).
1. TAKE OUT THE ELECTRICITY LEAD TO THE COMPUTER. Look inside the computer and find the bunch of wires coming from the power supply unit (the box thing at the top with the fan and all those colouted wires!).
2. Find where these wires run into a plastic connector and plug into the mother board. Unplug it.
3. Now plug the electicity lead back into the computer. The light should now stay ON.
4. Plug in the connector again... and boot up. Leave it run a while to convince it!
5. Repeat this process if it does not work first time.
This should fix your problem . It works for me when I get this problem.
Friend in Spain
Posted on May 09, 2009
efs_perpends
  • 1996 Answers
SOURCE: Pwr supply not getting power to the mobo.
No fuse, but they are relatively inexpensive, about $30.00. You can have yours load tested by a reliable local tech to confirm it has given up the ghost...and they'll probably be happy to supply a new one as well...
Here's a startup troubleshooter that has more info if you're interested in self-testing...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 29, 2009
Testimonial: "best answer, thanks"
  • 452 Answers
SOURCE: Bestec ATX-250-12Z when power lead plugged into
Hi;
you should check the capacitor in the secondry side of the power supply,
Posted on Oct 30, 2010
Dell optiplex gx520 wont turn on
This is most likely the power supply. You may be able to take it to a store like best buy for testing.
Dec 28, 2017 | Dell OptiPlex GX520 PC Desktop
My compaq presario sr2010nx desktop won't turn on. I tried fooling with the off/on switch wiring and it came on for a short time. All was well. I hadn't used it for a week and tried to turn it...
Hi.
Sounds more like a power supply problem. First test the on/off switch by tracing the wires to where it connects to the mother board. The plug is usually marked "pwr sw" . Unplug the wire from the board & short out the 2 pins where the switch was plugged in using a small screw driver or any other conductive material. If the pc still fails to turn on, try replacing the power supply.
Best wishes,
Graemevm
May 10, 2011 | HP Compaq Presario SR2010NX PC Desktop
Hi, my HP Pavillion a1240n won't start up... the wall plugs work and the power supply is plugged in but no lights are showing. I've also been flipping the switch beside the power supply at the back, and...
There are only certain items that will not power up a machine. 1. The power supply itself could be gone. 2. Check your ram. 3. Your hard drive. In most cases it is the power supply. Take out the power supply from the machine and plug it in to a wall socket. If it starts that it is not the power supply. If it doesn't start replace the power supply.
Dec 05, 2010 | HP Pavilion a1240n (EG136AA) PC Desktop
My HP media center desk top will not turn on. I have checked power and switched main plug. My son recently cleaned out the dust and showed me where to plug more power to speed the machine up. Which I...
make sure that this machine does not have switch on the pwr supply on back of pc.some times it is hard to see it. make sure there is pwr to the outlet and try different outlet. do you see any lights on back or front of pc. if not means no pwr is coming to pwr supply.
Dec 12, 2009 | Computers & Internet
System wont turn on and there is a solid green light at the top of the mother board of my gateway 310 pc replaced batt on motherboard and it still wont turn on.
hello, this be caused by several things , i am assuming your are okay with opening up a PC since you have already changed the onboard battery.
here are few things you can try to further troubleshoot:
1: though the ligh on motherboard is on, power supply can still be faulty, so lets test that with a paper clip trick,
follow this link there are pictures and very clear instructions: http://www.ehow.com/how_4732521_test-desktop-power-supply.html
if power supply is bad, well then you know what to do... change it.
if the power supply is good:
2: remove all the RAM (memory) chips from motherboard and plug the power cable back in and observe the response (you may or maynot hear THREE beeps) now plug in memory chip and try powering up and try with one chip at a time...if PC boots up with any of the chips in it you knkow you have a faulty memory.
if that didn't work:
3: with everthing put back together try disconnecting just the hard drive and power it to see if you see BIOS screen.
if not:
4: many time this worked for me with Gateway PCs, reseating CPU in its slot but only do it you feel confident doing it because you can end up with a GIANT door stop if any of the pins on the CPU are/is damaged.
you would need some thermal-paste to go back on between CPU and heatsink.
if that didn't work..i think you are up to buying new PC.
let me know if you need more help or not clear about anything...
good luck
Amar Sondhi
Dec 04, 2009 | Gateway 310S (2900621) PC Desktop
System wont power on unless mb power connector on mb is reset
by mb pwr connector do you mean the swich on the pc case that you press to turn it on or do you mean the large block connector form the power supply ?
If you mean the case switch then you have a faulty one that is sendinga constant signal and locking up the power supply
Jul 17, 2009 | HP Media Center m7060n PC Desktop
No power to E-Machine T1860
hi,
Issue seems with the power IC of the motherboard need to repair.
May 29, 2009 | E-Machines T1860 PC Desktop
Compaq evo d500 does not turn back on
If its powering on, but the screen isnt turning on and the computer starts beeping, try replacing the ram.
Mar 15, 2008 | Compaq Evo D500 PC Desktop
HP and Compaq Pavilion Replacement 200w Micro ATX PS3 Power Supply (PSHPPAVILION) Power Supply Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
