Question about Whirlpool LTG6234D Front Load Stacked Washer / Dryer
Stackable Washer will not drain.
It will fill up and agitate and when it gets to the drain cycle it just sits there. There is no noise and it does it on all the different cycles. Please help. My dryer heating element went out last week. I am so tired of these appliances only lasting a few years!!! Thanks!!!!!
  • Angela Lee Apr 03, 2007
    There is no humming noise. There is nothing happening.
    President:
  • 1,462 Answers
Check if there is a low humming noise when on drain. if so there may be a foreign object trapped in pump. otherwise have you checked filter?
Posted on Apr 03, 2007
  • douglas smith Apr 04, 2007
    all you can do now is to get at the pump and check continuity across it and see if impellor turns freely. one way to check is to power pump direct from mains. if you can do this in situ, it will also get rid of the water. be carefull though
My washer will not spin or agitate, but will fill & drain
with it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Feb 08, 2014 | Washing Machines
My hotpoint washer wont agitate spin or drain. it makes a clunking noise when you try to change the cycles manually
The draining problem could be something stuck in the pump. A easy fix just take it apart and get whatever is in it out of there. The agitator sits atop an agitator drive block. The spline on these tends to strip out. Yank off the agitator (it just snaps on) and replace the drive block.
SERVICE MANUAL
My page shows more HERE
Sep 24, 2012 | Hotpoint VVSR1070D Top Load Washer
I have a Kenmore model# 417 44142400 stackable washer and dryer the washer will not agitate or spin. The belt is fine; I can turn the belt and motor by hand. All it will do is fill, and then sit there with...
If it will not agitate or spin the Door switch has failed. Listen for a CLICK as you just open or just CLOSE the Door. No click is most likely bad Door switch PN 131763202. Shop around if you tdetermin the doo switch has failed... This part can cost $40 - $72.00 depending up on the source.
Thanks for choosing FixYa,
Kelly
Jun 30, 2011 | Kenmore Washing Machines
Stackable w/d will not drain or spin
You will need to replace the switch I am afraid. If I had your Model # I could get you the part # . If you would like to order a swtich, I can give you my web site address
I would appreciate if you would rate my prfomance here because I am new to this site. Any feed back on how I am doing would be helpful.
Thanks
Vic
May 09, 2009 | Kenmore 88752 Top Load Stacked Washer /...
Kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Apr 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
My washer fills , sits, does not agitate, empties and spins.
I had the same problem. Take the agitator off by pulling on it extremely hard - use allen wrenches in the slots on the sides to help. This exposes the "air bell coupler" - take the 7/16" bolt out and slide it off. Chances are the spline is stripped out inside. The part is 5 bucks online
Feb 01, 2009 | GE WJRR4170E Top Load Washer
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool LTG6234D Front Load Stacked Washer / Dryer Logo
395 people viewed this question
Dan Webster
Dan Webster
Sal De
