Question about Hampton Bay Sidewinder 04890 Ceiling Fan
Broken fan wire
Can someone tell me what the white insulated wire that runs from the top of the fan into the fan motor is. It has a thin wire in the center of the insulation. Mine is torn. Can I easily replace this? Is it fixable? If it runs the remote, can I wire cap it off? I would appreiciate any help. Thanks Tom
    Sniper:
  • 52 Answers
That is your nuetral wire. It will be attached to your white housing wire. You shouldn't splice it unless the splice will be in ceiling junction box.
If you found any of my suggestions to be helpfull, please rate my solution. Thanks D. Lange
Posted on Apr 24, 2009
Black wire, white wire, and tan wire coming from ceiling. New fan has blue, black, white wire and green wire on the bracket how does it hook up
1. Have on hand either wire connectors or electrical tape
2. Look at the wires coming from your ceiling fan. The black wire from the ceiling fan is the hot wire that runs the motor and turns the fan blades. The white wire is neutral and completes the fan circuit. The blue wire is the hot wire for the ceiling fan light fixture. The ceiling fan motor does not have a ground wire.
3. Find the short green wire or the green ground screw on your ceiling fan hanging bracket. Attach the bare copper wire from your electrical box to the short green wire by twisting and orange wire connector to the two wires. If you only have a green ground screw, wrap the bare copper wire around this screw and tighten the screw against the bracket to secure the wire.
4. Match the end of the white insulated wire from the ceiling fan to the end of the white wire from your electrical box. Twist a wire connector onto the two wires to complete the neutral circuit.
5. Connect the black insulated wire from the ceiling fan to the black insulated wire from the electrical box. If you do not have a separate toggle switch on the wall to operate the ceiling fan and light separately, grab the blue wire and place it with the black wire from the fan motor and the black insulated wire from the electrical box. Twist a wire connector to all three wires. If you have the additional toggle switch, connect the two black wires together with an orange wire connector, and then match the blue wire and the red wire together. Twist another orange wire connector on the red and blue wires
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jamie_580d75bd3bb6d659
Nov 11, 2017 | Dryers
Tip
Casablanca Table Fan, DOA
If your Casablanca Fan (1928D) Table Fan has stopped working completely, or stopped in the middle of oscillating, it might be the internal AC wire that runs up the middle of the fan base, that is broken internally. First, make sure the fan is not plugged in. You have to take the whole fan apart from the front. Check for continuity on the white and black wires that run to the motor. You may have to pierce the black and white wires with a pin to check them, because they are wired directly into the motor. These two wires have a black jacket covering them that can be pulled off if you find an open wire. Either one of these wires can break internally because of the back and forth movement. Cut the wires close as necessary to the motor to make the splice. Solder and use heat shrink insulation and route the new wire back down through the base and splice them where the original wires were. I used a piece of electrical cord with white and black conductors that was cut off an appliance that was dead. It was the same size as the original so it fit well. Please note, this repair requires electrical and mechanical knowledge. You have to take the whole fan apart to do this repair.
on Apr 21, 2014 | Casablanca Fan (1928D) Table
Garage door open and closes by itself bighornenterprises@live.com
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Jun 19, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door open and close by itself why?
Anytime a door opens and/or closes by itself I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door.
The test is to disconnect the push button wires at the power unit. If the self operation stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
May 24, 2010 | liftmaster Chamberlain Garage Door Opener...
Communication to the opener fails. The little green light on the door opener goes out. It eventually returns and then the door will work again.
HOPE THIS HELPS
Aug 02, 2009 | Liftmaster, Chamberlain, Sears Door...
Put ceiling fan up, blades are not on yet.
No. As you were assembling the wire from the fan motor to the house wiring, there should have been two wires labled. One would have been labeled "FAN" and the other "LIGHT". To properly attach the wires, (be sure the power is off) twist the thin labeled black (FAN) and blue (LIGHT) wires together. Now attach those two twisted wires to the black house wiring with one of the supplied wiring cap. Finally attach the thin white wire to the white house wire with supplied wiring cap. Your fan is now ready for operation. If you had performed all these steps when you first assembled the fan, then the thin black wire going to the fan has come loose. Should your ceiling fan still not run after all that, then it's time to return it where you bought it because either the pull chain switch is defective or the manufacturer produced a defective piece of merchandise. If you found any of my suggestions to be helpfull, please rate my solution. Thanks D. Lange
Apr 24, 2009 | Oasis Hunter 54' Ceiling Fan
Sidewinder Fan Works but not the Light
Apr 19, 2009 | Hampton Bay Sidewinder 04890 Ceiling Fan
I need to change the code on a 03 opener, someone in the community keeps opening my garage door with theirs.
(THIS CAN BE HIDDEN IN THE WALL)
HOPE THIS HELPS
Apr 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman model 139.53754 garage door opener ramdomly opens on its own.
HOPE THIS HELPS
Nov 11, 2008 | LG CHOCOLATE VX8500 Cellular Phone
We close our garage door when we leave and we will come back home and it is open. Sometimes the time frame is a long time, other times it is a short period of time. We want to change the codes but there...
HOPE THIS HELPS
Sep 02, 2008 | Sears Craftsman LiftMaster Chamberlain...
Hampton Bay Sidewinder 04890 Ceiling Fan Logo
67 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
