Water fill proplem to a washing machinre
During the rinse cycles and sometimes during the fill for general wash the water barely trickels into the wash tub. You can hear the water entering the machine however their are no leaks rin the system. i have checked the supply lines and filters and hoses and am at a loss for what to do next. This problem is an intermitant problem so it is hard to pinn down when it will work properly or not.
  • ocrs1101 Dec 21, 2008
    Make is a Whirlpool
    Model LA5500XS
  • 5,911 Answers
Sounds like you have a Water Inlet Valve (also known as a fill valve) going bad. This is where the fill hoses connect. If you've already verified the hoses to be good and not kinked or clogged, more than likely, the water inlet valve needs replaced. If you live in an area that has hard water, or if you use well water, the fill valve can become clogged with sediment over time. You can attempt to clean it by shutting off the water supply and removing the hoses. Look at the sediment screens and use some distilled white vinegar with some cotton swabs to dissolve and break up and deposits in the screens. If you require a replacement valve, please post back with a complete make and model number so I can assist you with locating parts. I hope this helps you. This is a simple repair.
Posted on Dec 20, 2008
  • Jeff Rockwell
    Jeff Rockwell Dec 21, 2008
    I apologize for not getting back to you sooner. It took me a while to find the best price for you. The part number for the valve you need is 285805. The following link offers the best price, with ordering information:
    http://pcappliancerepair.com/cgi-bin/par...
    For exploded view illustrations of your washer, you can use searspartsdirect.com by typing in your model number. I use this site often for identification and location of parts.
    For step-by-step instructions on how to replace the valve, please click on this link:
    http://www.fixya.com/support/r600647-rep...
    This is a very simple repair if you follow the steps provided. If you run into trouble, or require addtional assistance, please post back and let me know. I hope this helps you.
After working well for six months, my washer now expels water at random points during the wash and rinse cycles.
Check inside the fill hose for debris. There is a screen designed to block debris from getting inside the machine valve. If the screen builds up with debris the water slows down. Sounds like the water is filling too slow. Also the unit and/or the load may not be balanced causing it to stop and drain out. If it's okay then see what lights are blinking when these events occur and post here.
Jun 06, 2013 | Haier HLP21E Top Load Washer
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
The washer only fills halfway up during rinse cycle only, even on high water setting. it fill completely during the wash cycle.
Has it always done this or just recently? Some washers have lower rinse fills then spray the water on the clothes as it goes through its cycle.
Sep 24, 2011 | Estate Washing Machines
Water will not fill during rinse cycle. it does fill when i start the machine but not during rinse cycle.
The rinse cycle only takes cold water so I suspect that you have a bad or maybe clogged water valve on the cold side of valve.hope this helps.
May 29, 2011 | General Electric WBSR3140GWW Top Load...
When my machine goes through the rinse cycle it will only fill with hot water. It fills with warm water during the wash cycle.
Your hoses are reversed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 30, 2009 | Washing Machines
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Sep 19, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
220 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
