Question about Kenmore 74522 Top Freezer Refrigerator
Refrigerator leaking water out
Our refri all of a sudden started leaking water out onto the floor as well as leak onto the shelves where sometimes it would form a layer of ice. What causes this and what can I do?
  • stefanie johnson Apr 03, 2007
    Thanks :) Will try it
  • Anonymous Mar 15, 2014
    water leaking onto floor
    President:
  • 1,462 Answers
Being in the uk, i don't know this appliance specifically so take this as guidence. there are two places where water can come from. at the rear of the fridge there should be a gully at the bottom of the evaporator wall - the part that frosts up. in the middle of this gully is a drain and this is likely blocked. push something flexible down it and check blockage is cleared by pouring a small amount of water in the gully and see it flows freely away. good idea to occasionly pour a small amount of dilute bleach down it now and again to keep it sweet. the other place for water to come from is if some of the contents of the fridge are touching the back wall. when it defrosts the water tends to divert onto the shelves
Posted on Apr 03, 2007
253.63712300 sears Hoffman estate fridge has small pools off water that sometimes freeze on back of fridge shelf. Sometimes small trickle of water leaks onto floor. the refridgerator and freezer are s
probably dust, hair, lint plugging the drains.
you have pets?
have it serviced by a professional, or you can disassemble all the drain lines and conduit and pans and clean yourself. good luck
call a PROFESSIONAL
Dec 29, 2014 | Estate Refrigerators
Water leaking on freezer shelves no water in ice maker
Good Morning Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS26H5AS, is not making ice and is leaking water onto your freezer shelves. Please make sure that your freezer is cold enough. Your freezer should be set at a temperature of 0 degrees F. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FRS26H5AS Side by Side...
Water leak on floor
Typically on this model the drain hole Under the evaporator cover gets clogged. Remove the cover off the rear of the refrigerator and pour hot water into the drain until it goes down quickly. To remove the cover u will have to remove all the freezer shelves and the icemaker. Remove the covers screw and u should see that at the bottom u will have a block of ice down below. The refer goes onto defrost every couple days and will leak the melted ice onto the floor
Jul 06, 2011 | Amana ABB1927DE Bottom Freezer...
2 times in a period of 24 hrs it leaks water out the bottom of refri
Might should check for water leak in the main line that runs at the bottom of the frig behind the grill in front. If not there check all lines in back and the water solenoid sometimes it will have a hairline crack that will cause this. BB
Dec 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is leaking onto the floor from underneath. i bought a lot of vegetables yesterday and the refrigerator was really full - could that have caused it? what to do? thanks for any suggestions you have!
The reason for your fridge to leak water on floor sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a boaster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear.
Thank you for contacting Fixya.com
Aug 12, 2009 | Frigidaire FRS26H5AS Side by Side...
Side by side refrigerator- water dispenser clogged and now leakin
i'd shut off the water take apart and clean change water filter.
Jun 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Water Leaking all over from Whirlpool Gold Refrigerator
I think that the seals are ruined when the seals are ruined the water will leak outside and inside beacause all of the heat from outside will gather together and will melt the ice and will make the moisture act up and boost the process of it turning to gas matter into liquid matter.
Apr 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaking inside of refrigerator from freezer
IT SEEMS LIKE YOU HAVE A CLOGGED DRAIN . CHECK YOUR CONDECER COILS BEHIND KICK PLATE .. AFTER THAT YOU CAN UNPLUG FRIDGE FOR 24 HRS WITH DOORS OPEN AND SOULD DEFROST ENOUGH TO CLEAR DRAIN . IF NOT . DEPENDING ON MODEL YOU SOULD BE ABLE TO GET THROUGH DRAIN THROUGH MOST FREEZERS .
Feb 03, 2009 | Kenmore Refrigerators
Kenmore 74522 Top Freezer Refrigerator Logo
216 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
