Question about Maytag SDE3606A Electric Dryer
Maytag dryer isnt as hot as normal
It takes two cycles just to dry a load!Is their some cleaning or maintanance I can do to remedy this problem?
  • pistlpete Dec 21, 2008
    Thanks!I'll try this in a few minutes.
  • chattypants Jan 17, 2009
    no heat
    cold air blowing through vent
    clothes were actually frozen solid yesterday morning
    it is -40 celcius here
HI I am not an expert but we had the same problem once. It may be that the tube which air flows through to the vented portion has a blockage, of lint ( a lot of it) enought to clog the airflow which is not allowing the unit to dry your clothes in one load. Check both ends of the coiling and the outside vent. good luck
Posted on Dec 20, 2008
Maytag gas dryer won't heat up!!! It takes 6+ cycles to dry 1 load! What are the most common problems?
The main cause is a plugged exhaust vent in the wall. Try disconnecting the exhaust vent from the wall and run a normal load. If the load dries properly, then you will need to have the exhaust vent professionally cleaned.
Good luck
Sep 25, 2010 | Dryers
My dryer takes hours to dry one load of clothes. Cleaned all lint from it. It's warm, not hot. Flame is on.
you need to either dismantle the venting pipe ductwork inside the dryer and get inside the duct and loosen all dried on lint which is holding moisture in,otherwise the cycling switch for the flame is cutting out tooooo sooooon and your not drying the load properly per selected load setting
Mar 14, 2010 | Maytag Neptune MDG9700A Gas Dryer
Maytag Neptune gas dryer. Lint-free. 4-1/2 years old. Good air flow. Burner only stays on for 5 seconds. Takes forever to dry a normal load and not getting hot. Temp is on normal. Time dry or automatic. Do...
Hi, sounds like a plugged vent. Pull the dryer out from the wall and disconnect the vent.Clean out any lint and make sure you have good airflow to the outside.
Jan 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
NOt drying clothes like it should
Has air flow problem, check to make sure the vent going to the outside is not blocked. If it isnt, you should be able to take off back cover of dryer. Should be a duct that air goes through, take it apart and make sure there is no lint in bottom of it. I had the same problem and that fixed it.
Apr 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Electric drier takes 2 to 3 cycles to dry one normal size load
Have you tried cleaning the actual inside of the drier?
When you use drier sheets the wax on the sheets melts onto your clothes and makes them soft, but the wax often gets stuck in the holes of the drier making it incapable of drying the clothes in one load. Try scrubbing the inside of your drier with some hot water.
Apr 13, 2009 | Roper REX3614KW Electric Dryer
Maytag LDE412 Dryer
the vent that takes the air from the dryer out of the house is clogged. not the part right behind the dryer but from where it goes into the wall to where it leaves the house needs to be cleaned. when the air cant leave the dryer at normal speed it takes for ever to dry a load of clothes
Nov 26, 2007 | Maytag MDG7600AW Gas Dryer
Maytag SDE3606A Electric Dryer Logo
62 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
