Question about Dell Dimension 8400 PC Desktop
Trying to reboot to reinstall xp
Screen says selected boot drive not available help
  • radonna Dec 20, 2008
    i hit delete key when rebooting.  i am not sure where i was and i turned  off computer.  i am lost
  • tougerthor May 11, 2010
    are you in the boot sequence? give me a list of your available options in the boot sequence
    President:
  • 1,179 Answers
Try rebooting with the Windows installation cd in the drive.
Posted on Dec 20, 2008
I tried to re-install windows xp to clean my computer (running slow). It aske if I wanted to include web updates and I answer yes. Computer went to a blank screen and no won't load from recovery disc or...
Hi, you will need to reformat your hard drive before installing XP, First boot into BIOS by pressing the F1 key during bootup, change the primary boot drvice to CD rom, save changes. Insert XP cd into drive and reboot PC; select boot from CD when this appears during the initial boot fase. Allow files to be installed. When this finishes, delete partion and then repartion hard drive. Select format hard drive, when this completes your PC will reboot, do not select boot from CD and XP will start to install normally.
Hope this helps, if not come back to me.
Aug 04, 2010 | Computers & Internet
Hi my computer dell gx280 didn't work. It keep show "no boot device available". i try to replace with new hard drive but it still show same thing. Can you help me figure out what is problem with it please?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Try the above solution and let me know how you get on?
Jul 04, 2010 | Dell OptiPlex GX280 PC Desktop
How to reformat a computer?
Hope this helps
Jul 19, 2010 | Microsoft Windows XP Professional
Restore will not work comp goes thru the motions and comes back with unable to restore, it doesn't matter how far back you go
Hi, I believe you need to reinstall your operating system, follow these instruction:
Hope this helps
Jul 15, 2010 | Medion MD-1768 PC Desktop
Problem is (the dist structure is corrupted and unreadable). please help
Hi, looks like you will need to format your hard drive and reinstall windows. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 01, 2010 | Computers & Internet
My laptop had been working fine, then the last
Hi yes try this, if no joy come back to me.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing ESC button, or delete in some machines. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Jul 10, 2010 | IBM ThinkPad A30 Notebook
How to reload O/S from the D: partition?
Hi, not sure what you meen here i.e completely reinstall or repair? But here is to reinstall, let me know if you wish to repair! Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing ESC button, or delete in some machines. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 10, 2010 | HP Pavilion dv6226us Notebook
My sony laptop with windows xp home media center keeps rebooting
When XP gets into the rebooting mode, you will have to run a chkdsk or do an XP repair. You will not lose your data. But you do need your recovery cd or a WinXP cd.
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Type chkdsk C: /R at the prompt in the recovery console.
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
Lastly, your drive can be taken out of the unit and set into an enclosure or adapter. The data can be saved, the your hard drive can be formatted and programs and data reinstalled.
Good Luck,
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 10, 2009 | Sony VAIO VGN-NR120E/S Notebook
Compaq c310 laptop to be booted
To boot from the disc, you need to restart your computer. As soon you see the HP logo screen keep on tapping F12. You should select the option CD/DVD drive or CD drive. Make it sure that your XP cd is inserted.
Please be reminded that if you will reinstall your windows XP everything will be wiped out from your computer, your documents, picture and any other documents.
You may follow up the instruction using the link below.
http://tinyurl.com/gac7w
Keep me posted.
Thanks.
Oct 17, 2008 | Compaq Presario Notebook
New hard drive was installed and will not boot
plz check if your hard drive is detecting,if yes then try to reinstall the OS otherwise your hdd is dead and replace it.
Apr 22, 2008 | Seagate Barracuda 7200.9 500 GB ATA-100...
Dell Dimension 8400 PC Desktop Logo
22 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
