My refrigerator is running but has stopped cooling and is thawing out. How do I clean the condenser on a GE monogram ziss420dxss 42" Built-In Side-by-Side Refrigerator with Dispenser
IS THE NOISE SOMETHING HITTING THE FAN BLADE?
CHECK THE FAN ASSEMBLY BY REMOVING THE BACK PANEL IN THE FREEZER COMPARTMENT.
NORMAL NOISES IN THE UNIT ARE A GURGLING NOISE OR THE SOUND OF RUNNING WATER OR HISSING. THIS IS DUE TO THE FREON BEING PUSHED THROUGH THE SYSTEM AS THE COMPRESSOR RUNS. POPPING OR SNAPPING CAN OCCUR WHEN THE COILS IN THE FREEZER MOVE DUE TO A CHANGE OF TEMPERATURE.
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
SOURCE: GE refrigerator freezer water dispenser failure GSH25JFTA
Some have said that if you are fridge is still making ice, then your water line may be frozen. So you need to let it thaw out by leaving the freezer door open. Figure out somewhat to try and keep the cold air in by using plastic sheeting or something, until the line thaws. You can't dispense water with the door open, so reach up press the button that makes it think its closed and try to dispense the water..or just shut the door to test it out. I am going to try this when I get home today, because I am having the same problem on my GE model# GSH25JFTA BB.
SOURCE: ge monogram side by side refrigerator not cooling
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
SOURCE: 48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
