Question about Kenmore 21.9 cu. ft. Side-By-Side Refrigerator
15 month fridge acting up
On friday I noticed an off and on buzzing noise coming from our "new" fridge. On sunday morning when we opened the freezer the food was all defrosted. Both the freezer section and the fridge section were not cooling effectively. My husband unplugged the fridge and left it off over night. He plugged it in this morning and it is working again. The thermomator reads -10 degrees for the freezer. When we called the repair coompany for our kenmore fridge, they wanted to charge $219 for them to come out and fix it and give us a 12 month warranty. I mentioned it was working again and they said it could have been an electrical issue and unplugging it could have corrected the problem. Similar to turning your computer on and off. I do not want to spend $219 for them to tell me that it was an electrical problem that was corrected by unplugging it for 12 hours. Do you think this will be a recurring problem and is it worth getting fixed? Any suggestions? Thanks in advance.
  • 944 Answers
From what you describe, it sounds like the buzzing noise was caused by the compressor trying to start up, but not managing due to either a fault in the electrical supply, which may now be fine, or the compressor itself sticking. If the compressor was sticking, then there are three possible causes; - the fridge is either low on refrigerant gas (this contains the lubricant for the compressor too), if this is the case then $219 is not a bad price, shop around though - any fridge repair guy can do it, doesnt have to be sears/kenmore guys, but the warranty sounds useful. - just that the compressor was being temperamental. (sometimes happens but is fairly rare). If it doesnt happen again in the near future then your fridge may be fine. Third possibility is that the starter capacitor/condenser for the compressor is failing - this is a small part, quick to swap and cheap, although usually these either work, or they dont work - not much in between. I would recommend leaving it for a few days or so, and keep a record of the temperature every now and again - if it keeps getting warmer noticeably, or colder noticeably (i know it sounds odd but getting extra cold is a classic symptom of low refrigerant). Listen a bit, and see if you think the fridge compressor is running more often than normal if you can remember how it was, and if it keeps getting more frequent. If so - get it fixed. if everything stays about the same - temperature/amount of time running/noise then you probably can just hope for the best and leave it running, the moment anything changes, post again and we can probably advise you if it needs fixing or not. If you can spare the $219 then with the warranty attached it may be better to get it done anyway, but if it lasts a week with no change then it is probably fine for now. Hope this helps :)
Posted on Apr 02, 2007
Amana fridge stopped working for 2 days
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 03, 2012 | Amana AFF2534FE Bottom Freezer French...
Yesterday morning I noticed that the unit was buzzing. The refrigerator door had been left open and the temperature inside was 70 degrees. The freezer temperature was 20 degrees. This morning, 24 hours...
Hi
You have condesation built up in your freezer whereby the evaporator fan or the vents are most likely blocked off.
Turn fridge off. Empty freezer and either put a pot of boiling water inside freezer or with the aid of a hair dryer try to defrost the freezer. If you are able to remove the back panel on the freezer that would be ideal as you can directly target the frost.
Good luck
Ash
Sep 06, 2011 | Refrigerators
I have a Kenmore Coldspot, side by side, Model # 106.44553401. This past Friday morning I got up at 3:30 AM to let the dog out, and upon entering the kitchen I heard a new noise. I walked over to the...
there is a sensor that turns the fan on when it detect a high degree of warm air flow or if the door is open is job is to inject cold air into the fridge compartment allowing the food to stay at cool temp as to why it ran for so long is probably collapsed sensor or faulty door switch / magnet as to it wearing its self out not to worry fans can run for months non stop with no harm the ,ain point now is ! is the fan still running it should come on when you open the door the fan is a crucial part of the fridge and must be working correctly
Oct 17, 2010 | Refrigerators
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Feb 19, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
Freezer losing temp... intermittent buzzing sound
Either the start device for the compressor is bad or the compressor has died. The easiest way to tell is to replace the start device. It cost around 30-40 bucks and the part number for it is 218721119. In most of these cases its just a bad start device. The start device is located on the side of the compressor in the bottom back of the unit. It will have a capacitor attached to it that you will want to keep and stick on the new one. If you need anymore help just let me know. Good Luck!
Nov 02, 2008 | Frigidaire FRS26RLECS Side by Side...
BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Apr 08, 2008 | Refrigerators
FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
Refrigerator is at80 degress
This unit uses the cold air from the freezer to cool the fridge, you will find that the air duct has frozen up, completly defrost overnight with the doors open, this should rectify fault. Regards Advisor
Mar 06, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 21.9 cu. ft. Side-By-Side Refrigerator Logo
94 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
