Question about Typhoon Universal Bluetooth Keyboard BK-600 for Smart Phones and PDAs (PDAKBBK600)
How can I pair the bluetooth smart keyboard with windows xp prof
It requires a security code, however i have no information about the security code of the keyboard and could not find the code of it
Snug Bluetooth keyboard The pairing code is typed in, but the keyboard does not pair. I. Have tried resetting both keyboard and ipad with no luck.
Tip & How-To about Miscellaneous
Pairing Bluetooth Devices Posters often ask "How do I pair my Bluetooth ???" Insert whatever device you have at the question marks.
Generally, you need to read the instructions for the camera, headset, speakers or whatever the Bluetooth device is.
Roughly speaking though.
Settings - Bluetooth - Search, on the Android, iPhone, Windows phone whatever.
With camera, speaker, headphones or whatever the Bluetooth device is, you have to press a button on that device to send out the signal. On my Bowers and Wilkins T6 Speakers, there is a button on the top with the Bluetooth symbol on it. This is the part people usually don't do and ask for advice, thinking it will do this automatically.
When the Android device recognises it, click Pair, and if it asks for a code, the Default is '0000', (four zeros, no quotes).
Posted by Andrew... on Nov 19, 2016
Feb 17, 2018 | The Computers & Internet
My Samsung 4 will not pair with my halo ear candy Bluetooth
Bluetooth depends on both hardware and software to work properly. So if your devices can't speak a common Bluetooth language, they won't be able to connect.
In general, Bluetooth is backwards compatible: Bluetooth devices supporting the Bluetooth 4.2 standard, announced last year, should still be able to pair with devices using, say, the ancient Bluetooth 2.1, launched back in 2007.
The exceptions are gadgets that use a low-energy version called Bluetooth Smart, which works on a different protocol than older, or "Classic" Bluetooth devices. Bluetooth Smart devices are not backward compatible and won't recognize (or pair with) older devices that support Classic Bluetooth. (For example, an old Sony Ericsson phone sporting Bluetooth 3.0 won't be able to connect to a Bluetooth Smart device.)
However, if a device supports Bluetooth 4.0, it can potentially recognize both Bluetooth Smart and Classic. If it does, it's officially labelled Bluetooth Smart Ready.
Gadgets that commonly use Bluetooth Smart include personal health gadgets such as fitness bands or heart-rate monitors. These gadgets will only pair with a smartphone or tablet that also uses Bluetooth Smart - or are Bluetooth Smart Ready.
iPhones running iOS 7 and newer should be Bluetooth Smart Ready as should Android phones running 4.3 or newer, Windows Phone 8.1 devices, and all BlackBerry 10 devices. Ensure your phone is running the latest version of its operating system - but if your device isn't new enough to run relatively current software, you may not be able to pair it with that fitness band.
Devices also come with specific Bluetooth profiles. If Bluetooth is the common language connecting devices, you can think of a profile as a dialect associated with a certain use. For example, you probably aren't going to be able to connect a mouse and a camera because a camera doesn't support the Human Interface Device Profile. But if both a mobile phone and a wireless headset support the Hands-Free Profile, you should be able to pair them.
However, if the pairing failure is a matter of user error, there are steps you can take to get your devices happily communicating with each other.
What you can do about pairing failures 1. Make sure Bluetooth is turned on. You should see the little Bluetooth symbol at the top of your phone's screen. If you don't, go into the settings to enable it.
2. Determine which pairing process your device employs. The process for pairing devices can vary. Sometimes, for example, it involves tapping a code into your phone. Other times, you can just physically touch your phone to the device you want to pair it with. Or in the case of the Bose SoundLink, you only have to hold down a button on the speaker to pair it with a phone.
If you're not sure how to pair a device, refer to its user guide; you can usually find one by searching online.
3. Turn on discoverable mode. Let's say you want to pair your phone with your car's infotainment system so you can enjoy hands-free calling, texting and navigation. First, go into your phone's settings and tap on Bluetooth; doing so makes the phone visible to the car. Then depress the buttons on your car's infotainment system, usually on the steering wheel or center stack, to get it looking for the device.
Once it finds your phone, the car may ask for a numeric code you need to confirm or input on your phone. After you do so, the devices should be paired. Keep in mind your phone or your car may only stay in discoverable mode for a few minutes; if you take too long, you'll need to start over.
4. Make sure the two devices are in close enough proximity to one another. While you wouldn't think someone might try to pair an iPad with a keyboard if the two weren't sitting right next to each other, it's probably worth noting that you should make sure any devices you're trying to pair are within five feet of one other.
5. Power the devices off and back on. A soft reset sometimes can resolve an issue. With phones, an easy way to do this is by going into and out of airplane mode.
6. Power down likely interferers. Say that faithful Bluetooth speaker usually connects to your partner's smartphone instead of yours. If you're having trouble pairing your phone with the speaker, it could be because the speaker is trying to activate its usual connection. Some older devices are very simple. They just try to connect with the last thing they paired with. If a Bluetooth device was previously paired with something else, turn off that other gadget.
7. Charge up both devices you're trying to pair. Some devices have smart power management that may turn off Bluetooth if the battery level is too low. If your phone isn't pairing, make sure it and the device you're trying to pair with have enough juice.
8. Delete a device from a phone and rediscover it. If your phone sees a device but isn't receiving data from it, sometimes it helps to start from scratch. In iOS settings, you can remove a device by tapping on its name and then Forget this Device. In Android settings, tap on a device's name, then Unpair. After removing a device, start at step 1 on this list.
9. Get away from the Wi-Fi router. Another potential obstacle to successful pairing is interference from devices that use the same spectrum, such as your Wi-Fi router. "Wi-Fi has been designed to cope with this, but it might not be a good idea to have your devices directly on top of the router," Powell says.
10. Move away from a USB 3.0 port. "Interference from USB 3.0 is also possible," Powell says. Newer laptops, for example, often have the higher-speed USB 3.0 port, so if the connection isn't happening, try pairing your Bluetooth gadgets away from the computer.
11. Make sure the devices you want to pair are designed to connect with each other. Whether it's a headset, speaker, mouse, keyboard, camera or something else, your device has a specific profile that spells out what it can connect with. If you're not sure, check the user manual.
12. Download a driver. If you're having problems pairing something with your PC, you might be lacking the correct driver. The simplest way to figure this out is to do an online search for the name of the device you're trying to pair along with the word "driver."
13. Update the hardware's firmware. Some automotive audio systems recently wouldn't pair with the iPhone 5, for example, because the Bluetooth drivers in these systems didn't work with Bluetooth 4.0. If you're not sure how to get the latest firmware for your hardware, check with the device manufacturer.
14. Keep in mind that not all wireless devices use Bluetooth. Alternatives include the Wireless Gigabit specification, Wireless HD, ANT+, ZigBee, NFC as well as Wi-Fi Direct. These other technologies typically won't work with your phone, tablet or PC without some kind of additional hardware.
I hope this guide has helped you with your Bluetooth pairing problems.
Jul 26, 2016 | Samsung Radio Communications
Will an onn bluetooth keyboard pair with i pad 2 air?
You shoud have bluetooth enables in setting. If it is enabled, it should pair.
iT SHOULD WORK. If you can't pair, presume bluetooth of your keyboard is defective.
Mar 22, 2015 | Onn Wireless black keyboard with slim line...
How do I get a pairing code for a HYPE Ultra Slim Bluetooth Keyboard?
Pairing code for keyboard is not usually required. The one I have basically has a connect button, then you confirm on the computer. Otherwise the most common pairing code seems to be 0000.
Dec 01, 2014 | Hype Technology Ultra Slim Bluetooth...
How do I pair with Samsung galaxy note 10.1 2014?
1. From a Home screen, touch Apps
2. On the Bluetooth tab, touch the OFF / ON icon
to turn Bluetooth on.
3. Enable the target device's discoverable or visible
4. Touch the Bluetooth tab and then touch Scan. Touch
Stop at any time to stop scanning.
5. From the list of found devices, touch the target device,
then follow the prompts to complete the pairing:
• If the target device requires a PIN, enter a PIN for the target
device and touch OK. When prompted, enter the PIN on the
target device.
• If the device allows automatic or smart pairing, your device
attempts to pair with the device automatically. Follow the
prompts on your device and the target device to complete the
Oct 19, 2014 | Microsoft Wedge Mobile Keyboard
How doI find my bluetooth pin
Bluetooth pairing with a vehicle and a cell phone will depend upon the phone type. Either the phone of the vehicle will tell you the code needed when pairing is in process. Many times, pairing doesn't require a code, especially if the phone is a "feature" phone and not a "smart" phone.
Sep 13, 2014 | Cars & Trucks
Bluetooth pairing mode
For BK022A, discover is FN key + F1.
However I have another question. Windows asks me for the pairing code displayed on my device. But the BK022A doesn't have a screen. What is the pairing code?
May 27, 2013 | Fujitsu Computers & Internet
What is the numeric keycode for pairing bluetooth? Jabra BT2035
As you pair the bluetooth in your computer and a bluetooth device, it gives you a pairing code, only if needed so, like the keyboard. The pairing code is seen in the computer, and is generated by the computer as you click on "create a pairing code". For other devices, a pairing code is NOT required.
Thank you for visiting FixYa!
Apr 25, 2011 | Computers & Internet
I just bought a solidtek ask-3462 bluetooth mini keyboard. Followed all the instructions but cant seem to connect. Please advise I cannot get the Solidtek Bluetook Super Mini keyboard to connect with...
I just went through this 30 minutes ago.
When you are asked for the passkey, click on generate passkey or choose one for me.
a passkey will appear on the computer
enter this passkey on the keyboard then press enter.
they should connect and pair properly.
Apr 12, 2009 | Solidtek Bluetooth Super Mini Keyboard
Computers & Internet Logo
539 people viewed this question
Top Typhoon Computers & Internet Experts
David Payne
David Payne
Are you a Typhoon Computer and Internet Expert? Answer questions, earn points and help others
