Question about Whirlpool Duet GHW9150P Front Load Washer
Ghw9150p wont spinr
Had sud error first, removed clean out (just some lent) reset and now wont spin. Drum spins freely by hand. I just put rinse/spin cycle on and now just pump running. Thanks, Scott
  • Anonymous Jan 20, 2009
    on whirlpool deut washer, is the a lint trap to clean like the top loading washers? if yes, where and how to clean lint trap?
    President:
  • Whirlpool Master
  • 2,651 Answers
You cleaned out the filter in the pump assambly??? and did you also check inside the throat of the impellar for possible obstruction?its possible that the pump is not pumping(although its on) and not removing water would result in no spin
Posted on Dec 22, 2008
Le keep coming on
dfgf
dSorry to read about your problem, I hope this helps you out.Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
3 Thumbs - Helpful
Jan 02, 2011 | LG Washing Machines
The drum is not spinning and the machine stops and has LE on display
3 Thumbs - Helpful
3 Thumbs - Helpful
Jan 01, 2011 | LG Washing Machines
What is a le code and how do i fix it thanks cathy
sdfsf
sdfSorry to read about your problem, I hope this helps you out.Is this a new installation?
3 Thumbs - Helpful
3 Thumbs - Helpful
Error code LE
In new installations, this error can sometimes present because of a mis communication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
3 Thumbs - Helpful
3 Thumbs - Helpful
Dec 27, 2010 | LG WM1814CW Front Load Washer
"LE" what's mean?
Thanks for using FixYa - a 4 THUMBS rating is appreciate dof rnaswering your FREE question.
Sep 25, 2010 | Washing Machines
LE errorMashine get only a litle water and the motor make a noise and after this its coming a L E on the display
wmoverloaded.jpg NOTE: Make sure the drum is not overloaded
Sep 10, 2010 | LG WM0642H
How do I fix my washer that only says 'sud' constantly and won't work at all? Whenever I try to start a cycle nothing happens. Whenever I push a button nothing happens. Please Help.
http://whirlpool.custhelp.com/app/answers/detail/a_id/2948
Hi please go to this above link, it is all explained at length what is going on and what to do.
This error code indicates that excessive detergent suds occurred during the cycle.
If a "Sud" or "Sd" error code is displayed, or if you can see excessive suds in the window:
There are too many suds in the washing machine. The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. See the animation below for more information.
  • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
  • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer wont spin during spin cycle everything else appears ok.
Machine not spinning....check]
1..all water gone clean pump trap and check blocked drain
2....somehting stopping drum spin drum freely by hand.
3....too much soap use low suds soap and very little of it.
4....motor brushes wearing out...call for service for this one.
Good luck
T
Aug 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
LG error code is 0E...what would be the problem
Washing machine has an LE error code --> Is this a new installation?
May 18, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washing machine keeps shutting off and has the letters LE in the display. What's going on?
It could also mean the hall sensor is defective and will need to be replaced.
Feb 12, 2010 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
120 people viewed this question
Dan Webster
Dan Webster
Sal De
