Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Replaced lamp, sound but no picture
The lamp was brokn in the WD 52725, replaced lamp, still sound and no picture
  • 41 Answers
Try unplugging the set for 5 minutes and then replug it in, allow 70 seconds for it to boot up (LED stops blinking). See if it works then. If not press the input/device button and menu button at the same time read a 2 digit code (blinking led) flashes first # short pause and the flashes 2nd #. This will be necissary to determine your cause. Most common besides lamp is power supply caps that cause intermittant operation.
Posted on Dec 21, 2008
I have a mitsubishi WD-52725. the red lamp light was on and I replaced the lamp. the red lamp light came back on after replacing with a new lamp. Could there be another problem
Yes the capacvitors on the power board can cause the red lamp light and a 34 error code. The V26 Power repair kit from www.tvrepairworld.com will usually solve that issue. The kit contains the upgraded caps and the CD with instructions for the repair.
Jul 03, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Posted a short while ago but have more information Mitsubishi DLP WD 52725 - sound no picture - blinks 3 short times and 1 long time
have you checked the lamp? with those models they will power up and if the lamp is bad you can hear audio until the tv shuts off. the lamp is located in the front behind the speaker grill assembly. if the "status" light is blinking then you are having a fan failure if the "lamp" light is on then check the lamp like i listed above.
Jan 06, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi model WD-52725 has a fast blinking timer light on constantly and tv will not power up. Tried unplugging and resetting with no success. Now What?
It sounds like you need to replace the lamp for your TV unit. Also don't forget to replace the lamp use hours timer otherwise the TV unit will not recognize a new lamp has been installed. I hope this helps. Good luck.
Sep 17, 2010 | Mitsubishi WD-52725 52". Rear Projection...
I have a Mitsubishi WD-52725 projection TV .I replaced the lamp ,but the red lamp light still flashes and the TV does not turn on
the computer in your tv is bad, but someone can fix your problem , just need replace capacitors 1000 to 16 v
Jan 19, 2010 | Mitsubishi WD-52725 52". Rear Projection...
No display or sound on Mitsubishi WD-52725
This is a DLP They have issues with the color wheel, the winding sound could be from this color wheel. If it stops spinning it will cause the tv to shut down. DLP is a mechanical display process. If you are handy and understand electronics you could replace this yourself. If not i would let a tech handle it.
Sep 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Green diagonal lines across picture on Mitsubishi WD-52725 TV
If the lamp light turns red and the set wont power up put the V26 Power repair kit in and that should take care of it. The kit contains the capacitors and detailed instructions on CD
Jul 22, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Replacement lamp not bright
as i previously posted, my picture was dim, muddy looking after replacing lamp with osram lamp. i fixed mine by taking the screen off and cleaning the small mirror. it had a thick layer of dust on it, cleaned with a microfiber cloth. no water, no glass cleaners. i also used a very fine new small paint brush and dusted the projector lens which also had a dust film. brightness, contrast and clarity returned!
Mar 05, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi wd 52725 lamp troubles
You can use Mitsubishi 915p020010 or Osram E023. Remove the front and clean the lense using only a clean microfiber cloth. dirty lense main cause of dark picture. The lamp could be incorrect wattage.
Mar 05, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
65 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
