Question about Hitachi Cine Master PJ-TX200 Multimedia Projector
Starting up projector starts as normal for the first 5 seconds and then the temp and power light blink and no image is projected - i have fitted a new lamp and filter
  • 3422 Answers
SOURCE: Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Posted on Feb 25, 2008
  • 66 Answers
SOURCE: hitachi projector temp light
This is what your projector's user manual says about a flashing "TEMP" light :
"The cooling fan is not operating. Turn the power OFF and wait approximately 20 minutes. After the main unit has cooled down, please make confirmation that no foreign matter has become caught in the fan, etc. After performing any needed maintenance, turn the power ON again; if the same display is displayed, then please contact a sales store or a service company."
Your user manual is available at the following link :
Posted on May 20, 2008
SOURCE: Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Posted on Oct 02, 2008
SOURCE: No picture from projector after changing lamp
how to change the lamp
Posted on Oct 11, 2008
SOURCE: cleaning the filter/blinking LAMP and TEMP
Goto Advanced menu and select option then lamp Time hold down the reset button on the unit for 3 seconds until a new screen comes up then hit reset. Do the same for resetting the filter time
Posted on Apr 27, 2009
  • 144 Answers
SOURCE: projector says lamp failure and picture has turned Yellow
replace the unit,it sounds like its old,has been used a lot,and needs a complete replacement.
Posted on May 08, 2010
0 characters
1 Points
The projector turns on but won't project any light through the lens.
If this is a NEC VT series projector, Change the lamp. When if it continues to blink amber and not project and image after installing a new lamp check the lamp cover to see if the micro switch tab on the lamp cover broke off. Some models have a built in lens cover. If the cover is not slid over to open completely the light may not turn on.
May 19, 2014 | NEC VT800 LCD Projector
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
Hi. I have a InFocus dp2000x. It has no lamp. I try with a flashlight in the lamp chamber (the flashlight is battery operated) When I turn on the projector with a vga or video input, the power led start...
Projectors are designed to be used with a lamp and will turn off when there isn't one present. You would have to purchase a new lamp to use the projector.
Feb 19, 2011 | ASK Proxima Proxima DP2000X Multimedia...
Projector turns off after 5 seconds
You have a classic temp sensor problem. Its a fail safe on theprojector, basically a fuse that bridges the main power cables. Lookslike a little pot, With a white ceramic head.
Now what it does, Is the white ceramic head rises as the unit getshotter, and thus breaks the power circut. All you need to do is, openup the unit, locate the sensor (its mounted next to the lamp on yourprojector) And push the little white head back down, thus closing thecircut, and restoring power supply.
Here is the full repair schematic to guide you. :)
Jul 12, 2009 | Sanyo PLC-SW30 Multimedia Projector
Blinking Temp and bulb light on HP VP6310
The color wheel sensor is dead. This is a common problem.
Jan 30, 2009 | HP VP6310 Multimedia Projector
Alternating power and lamp status lights
...replace the lamp. The lamp is most likely WAYYYYY past its prime so I suggest starting there. Sometimes even if you had just replaced the lamp the new lamp could've blown. When there is no signal running through the lamp circuit there is no signal to the display sensor, which means no image.
hope this helps!
Jan 28, 2009 | Mitsubishi XD300U Multimedia Projector
PJ-TX200 hitachi projector
Hi George86969
Try checking if all the fans are working when you swich on the unit. Normally a static red temp. light is a faulty fan that will have to be replaced.
May 17, 2008 | Hitachi Cine Master PJ-TX200 Multimedia...
My CP-RS55 Projector Doesn't Work??? No Light?
Hi there
If the unit is brand new , they should replace it under warranty.
This is most probably a faulty Powersupply / Fanboard !
Apr 15, 2008 | Hitachi Performa CP-RS55 Multimedia...
Projector lamp flashes and the temp red led lights.
Purchased our76C in Jan, 2007. It is our second unit now that has had the same symptoms. When the unit starts up, the Power light is steady green as normal for a few minutes, but no image is projected. After a few minutes the lights do as you described. Both times Epson support authorized a new unit to be shipped out immediately. They said they had no known issues about it and didn't indicate what was causing the problem. Apparently it is not just the lamp wither. Also, the lamps both had under 20 hours on them.
Jun 17, 2007 | Epson PowerLite 7500 Multimedia Projector
Hitachi Cine Master PJ-TX200 Multimedia Projector Logo
617 people viewed this question
Top Hitachi Multimedia Projectors Experts
Electro Med Services...
Are you a Hitachi Multimedia Projector Expert? Answer questions, earn points and help others
