Question about Refrigerators
How do you manually defrost lg refridgertor? - Refrigerators
I am not sure for lg but most fridges if you flick the lever for the door 5 times within 5 seconds it goes into defrost mode
Posted on Dec 20, 2008
How do i manually defrost an LG French door, bottom freezer, refrigerator?
same way but use a fan as well to blow the warm air into the freezer
Apr 24, 2017 | LG Refrigerators
My lg fridge is not getting cold only the freezer is getting cold
There may be frost blockage, due to failure of frost timer. You need to call company service person.
Feb 18, 2017 | LG Refrigerators
GE Artica (pss26msrss) both the freezer and the refridgertor will not cool down...
Unplug and manually defrost with a hair drier because that ice you see on back wall of your freezer is a result of frost buildup behind that rear panel. Place all the frozen items in another safe place until the defrost is complete.Here is what your freezer may look like behind that rear panel. Not much cooling in freezer or fresh food section because this frost is blocking airflow.
The replacement parts for your model are the=> WR51X10042 Defrost Heater Assembly
7_12_2012_8_36_56_pm.jpgWR51X10042
And then the defrost thermostat=> WR50X10068 Defrost Thermostat
7_12_2012_8_45_50_pm.jpgWR50X10068 If you would like instructions on how to remove and replace I will be here to answer any questions you may have. How to test these parts can be found on the same page as the replacement parts, Thanks Sea Breeze
Jul 12, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
My LG refrigerator is not cooling (LSC27910) is not keeping items cold. the freezer is functioning properly............the refrigerator is not
THERE IS A SETTING FOR TEMP IN FRIDGE, MAKE SURE IT IS SET TO PROPER TEMP SETTING . NEXT MAKE SURE THE FAN IS WORKING IN THE FREEZER (DOOR OPEN PRESS LITE SWITCH) NO FAN? IT WILL NEED TO BE OILED OR REPLACED.. (FAN YES)TRY MANUALLY DEFROSTING IT, USE A BOX OR SIMILAR BIG FAN AND CLEAN AND WIPE DOWN THE INSIDE OF THE FRIDGE.. TAKES ABOUT A 1.5 HRS TO DEFROST.. YOU MAY HAVE A DEFROST TIMER ISSUE , IF SO YOU WILL NEED TO HAVE IT REPAIRED OR REPEAT THE DEFROST CYCLE MANUALLY, SAY ONCE A MONTH .. IF YOU ARE ON A BUDGET ..BEST OF LUCK ..JAY FLORIDA
Jun 24, 2011 | LG Side By Side Refrigerator w/ LCD VGA...
LG Refridge LFX23961st
LG LFX23961ST Support Manuals Warranty More LG
I just used the link above to get the Manuals on your LG. On page 31, they did the following CYA statements...
The defrost timer will click when the automatic defrost cycle begins and ends. The thermostat control (or refrigerator control, depending on the model) will also click when cycling on and off. Rattling noises may come from the flow of refrigerant, the water line, or items stored on top of the refrigerator .
Your refrigerator is designed to run more efficiently to keep your food items at the desired temperature. The high efficiency compressor may cause your new refrigerator to run longer than your old one, and
you may hear a pulsating or high-pitched sound.
You may hear the evaporator fan motor circulating the air through the refrigerator and freezer compartments.
As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your refrigerator.
Contraction and expansion of the inside walls may cause a popping noise.
Water dripping on the defrost heater during a defrost cycle may cause a sizzling sound.
You may hear air being forced over the condenser by the condenser fan.
You may hear water running into the drain pan during the defrost cycle.
I bolded the statement. Sounds like you are going to have to get used to the sound.
Semper Fi,
Z
Feb 01, 2018 | LG LFX23961ST Stainless Steel Bottom...
LG code ER DH, Defrost Heater or Thermistor?
Check for current flow through the defrost heater. If no current then replace the heater. If heater is OK check thermistor for correct operation. From service manual chart (their words not mine): ER DH is Poor defrosting. Indicates: Even though it is passed 1 hour since then
Defrosting , if Defrosting
sensor is not over 8°
Remarks: Temperature fuse Disconnection,Heater
disconnection, DRAIN Jam,
Poor Relay for Heater
Aug 11, 2009 | LG LFX25960ST Stainless Steel French Door...
My side by side refridgertor is freezing
Depending on model you have a condensate drain pluged up. Unplug and look on the frezzer side bottom and see how to take off the back panel. Possibely 4 to 6 screws. Once you take that off look at the very bottom. You will see a hole and some metal or foil around that hole. this may or may not have ice in it or not. If you have ice in it you can pour hot water on it from the tap. Ice gone, you can get a steamer and put the attachement that has a small end on it and blow steam down the hole. If you dont have a steamer you can carefully pour hot water down the hole and see if it is pluged. Should drain in a few min. Dont pour then 2 cups of water down the drain. You will fill up the condesate pan and have a water mess. Good luck and keep me posted.
Mar 14, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Error Message: Er dH
The error codes are listed in the service manual (p. 32) at the address below:
LFX25960 Service Manual
"Er dH" seems to be a defroster issue.
Aug 14, 2008 | LG LFX25960 Bottom Freezer French Door...
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
