Home | Nikon | COOLPRINT Thermal Printer | My printer has a par...
Nikon COOLPRINT Thermal Printer
Problem for Nikon COOLPRINT Thermal Printer
My printer has a parallel cable, but my new computer doesn't have any parallel ports. How can I use ....
By Bouncy - usenet poster
My printer has a parallel cable, but my new computer doesn't have any parallel ports. How can I use the printer?
Same Problem
Mar 16, 2009
-   i want driver
-   howlader
Aug 28, 2008
-   my new dell computer and my older dell printer well I can't print anything b\c it says that one is a cable and port of some sort.. Something like that-   Guest
Aug 23, 2008
-   If your computer does not recognize the printer device using the parallel to usb cable, try plugging the cable to mini usb hub then to the computer - it seem to work for me and VISTA immediately recognized the cable and printer.-   Guest
Aug 04, 2008
-   same exact problem. new pc without parallel ports, old printer with serial connector cable-   toddalex4
Mar 07, 2008
-   software
-   Guest
Best Solution
posted on Apr 11, 2007
Very Helpful)
dil143
Rank: Apprentice
Rating: 100%, 3 votes
or you can you use the usb to parallel cable which you can easily find in a radio shake store,
Was this helpful?
Yes
No
Solution #2
posted on Apr 10, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Get a print server with a parallel port and then print through the cat 5 cable.
Solution #3
posted on Sep 20, 2007
Helpful)
punker0204
Rank: Wiz
Rating: 84%, 100 votes
there's another easy way to use your printer even if you dont have a parallel port on your pc. try to look for a print server device named 'SEH' we use this device in our old kodak large format printers like kodak2060, NJ4, 700, 750, 850 etc. this device comes with driver you just have to install it so you can set the desired IP address you want then presto, you can now use your kodak printer as a network printer. note: you will also set the printers SEH IP address in your pc as you install the new printer driver, and same with whatever rip software you are using.
Was this helpful?
Yes
No
Solution #4
posted on Aug 08, 2005
Helpful)
Ryan
Rank: Apprentice
Rating: 0%, 0 votes
What you can use is a parallel card - this is a card that you can put into the computer just like a sound or video card, and it provides a parallel port. I've seen ones that work in ISA or PCI slots, and they should be available at most computer hardware stores, but probably not at consumer electronics stores.
The card should come with a CD with drivers for your operating system. (Drivers tell your computer how to use the new card.) If you're using Windows, once you install the card and start Windows, you should be prompted for the driver, so just insert the CD then, and Windows should be able to find the appropriate driver.
Was this helpful?
Yes
No
Solution #5
posted on Dec 19, 2007
Helpful)
The_Ogre
Rank: Guru
Rating: 86%, 337 votes
You can also get a Parallel-to-USB adapter cable. This let's you use a parallel printer over a USB port. They're available in most computer stores and I've seen them at Staples or Office Depot too. It'll come with a driver disc that you have to install before the computer will see the printer over the USB connection.
Was this helpful?
Yes
No
Solution #6
posted on Jun 15, 2008
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
my printer has no no black and white cartridge
how i get it
Solution #7
posted on Sep 02, 2009
Not Rated)
Narion
Rank: Apprentice
Rating: 75%, 1 votes
Ok all that is good, I have a USB to parallel converter and the printer is connected to my PC (Vista), the problem is when adding the printer, I don't know what port to choose, I've chosen a USB port and it printed a test page and all good, but afterwards any printing order is NOT being executed, not even that test page, what now?
Was this helpful?
Yes
No
Solution #8
posted on Aug 01, 2008
Not Rated)
JackHeath
Rank: Guru
Rating: 85%, 215 votes
If you going to buy new equipment anyway, get a small print server or a jet-direct box. Why support LPT printing which is legacy and only supports a single station, when you can get something that will allow multiple machines to use the printer and uses a port type that all new computers support.
Comments:
Sep 12, 2008
- Parallel Card $52.99, Mini-Print Server $69.99
I still think that this is the better way to go, even if you just run a crossover cable between the computer NIC and the printer ethernet port and set the IP manually.
Was this helpful?
Yes
No
Solution #9
posted on Jul 28, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I use a Jetdirect to fix this problem HP has some grea ones and its a quick fix for sure just going to run you about 150bucks or so
Solution #10
posted on Jul 20, 2008
Not Rated)
mexicalijr
Rank: Apprentice
Rating: 0%, 0 votes
Consumer electronics stores sales a usb parallel converter cable.
Prices from $ 10.00 to $ 40.00 dollars.
Was this helpful?
Yes
No
Solution #11
posted on Jul 14, 2008
Not Rated)
Arius
Rank: Wiz
Rating: 80%, 327 votes
parallel cable are nearly at the end of its life, but you can buy one of those inexpensive adaptors in the market place
this would surely work. ill walk you through the driver installtion if you need help
Was this helpful?
Yes
No
Solution #12
posted on Jul 06, 2008
Not Rated)
TRANSCORP99
Rank: Master
Rating: 83%, 14 votes
4650 "N" indicates that it has a Network connector. (like a big telephone jack) Does your PC too? Much faster than parallel. Find hookup instructions on the internet.
Was this helpful?
Yes
No
Solution #13
posted on Jul 02, 2008
Not Rated)
jglassm
Rank: Apprentice
Rating: 0%, 0 votes
Best solution is to buy a used Jet Direct 300x external kit from a source like eBay - around $20. Connect your printer then via network through jet direct. 100% fix every time.
I repair HP2000C professionally and offer refurbished 2000C available with trade in allowance for your old one. www.glassmoyer.net/HP2000C.
Was this helpful?
Yes
No
Solution #14
posted on May 26, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I brought a converter fromparalel to USB, but it doesn't work , I dont know why. Somebody knows why ? RAMON / Caracas
Solution #15
posted on Apr 14, 2008
Not Rated)
aborad
Rank: Apprentice
Rating: 100%, 1 votes
There is a another way also u can buy Serial to Parallel Converter.
Was this helpful?
Yes
No
Solution #16
posted on Mar 16, 2008
Not Rated)
egasz
Rank: Guide
Rating: 85%, 3 votes
Other solution is an USB to Parallel adaptor, You can buy this for $10 in any store
Was this helpful?
Yes
No
Solution #17
posted on Mar 12, 2008
Not Rated)
gsm1956
Rank: Apprentice
Rating: 0%, 0 votes
A quick solution is to purchase a usb to parallel cable, cost about £5 on ebay
Was this helpful?
Yes
No
Solution #18
posted on Mar 06, 2008
Not Rated)
Aidolss
Rank: Master
Rating: 90%, 10 votes
A neater and better solution would be to use a USB to Parellal converter. These can be bought for approx €30. If you need help locating one, let me know.
Aido
Was this helpful?
Yes
No
Solution #19
posted on Feb 19, 2008
Not Rated)
khaliqgmnk
Rank: Apprentice
Rating: 0%, 0 votes
i need drivers for my sony updr150 thermal photo printer ,, if you somebody help me plz
Was this helpful?
Yes
No
Solution #20
posted on Jan 16, 2008
Not Rated)
pageofangels
Rank: Apprentice
Rating: 0%, 0 votes
HP makes a "print server" that plugs into the parallel port and adapts it into a network cable port. It weighs less then a mouse! Downfall is, it's powered so you need another outlet.
Was this helpful?
Yes
No
Solution #21
posted on Dec 11, 2007
Not Rated)
Fct505
Rank: Apprentice
Rating: 95%, 3 votes
you would need something like this
http://www.monoprice.com/products/product.asp?c_id=103&cp_id=10311&cs_id=1031104&p_id=2067&seq=1&format=1#largeimage
i'm having problems with my laminate. Can you show me a pic on how you set yours up?
Was this helpful?
Yes
No
Solution #22
posted on Nov 01, 2007
Not Rated)
Sam4517
Rank: Wiz
Rating: 92%, 121 votes
You are in the CS-2050 section. Is that what you have? The CS-2050 has a network card and a USB port? Use one of those.
If you are listed in the wrong section.
There is a USB to parallel cable you can buy at your friendly computer store.
Was this helpful?
Yes
No
Solution #23
posted on Oct 18, 2007
Not Rated)
duxxyuk
Rank: Wiz
Rating: 89%, 69 votes
It is also possible to buy USB to Parallel adapters that do the same thing.
Was this helpful?
Yes
No
Solution #24
posted on Oct 13, 2007
Not Rated)
gradracer16
Rank: Master
Rating: 90%, 17 votes
You can purshase at radioshack a USB-to+parallel cable for about $20. It works great and even lets the computer auto detect the printer. I highly recommend it and have used it several times for customers
Was this helpful?
Yes
No
Solution #25
posted on Sep 11, 2007
Not Rated)
Jmm4444
Rank: Apprentice
Rating: 0%, 0 votes
Printronix also sells a jet direct crd that can be installed into the printer itself and you can print to it by networking it.
Was this helpful?
Yes
No
Solution #26
posted on Aug 30, 2007
Not Rated)
SMATSMAN
Rank: Wiz
Rating: 80%, 48 votes
Another idea is to use a print server and connect to the printer by setting up a network.
Was this helpful?
Yes
No
Solution #27
posted on Aug 20, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Or just get a usb parallel cable....
Solution #28
posted on Aug 18, 2007
Not Rated)
mrogers
Rank: Wiz
Rating: 83%, 179 votes
An easier way is to simply buy a parallel to usb cable. They are availiable at most consumer electronics stores and probably cheaper too.
I found this one for USD $8.99 :
http://www.newegg.com/Product/Product.as...
Was this helpful?
Yes
No
Solution #29
posted on Aug 10, 2007
Not Rated)
Thecus
Rank: Wiz
Rating: 79%, 55 votes
Esaier solution is to get a USB to parallel adaptor. About $25. It simply plugs into your USB port and plug it into your parallel port in your printer. Follow the instructions from adaptor manufacture for the exact steps to load the driver and to recognise the printer.
Was this helpful?
Yes
No
Solution #30
posted on Mar 11, 2007
Not Rated)
Anon1001
Rank: Apprentice
Rating: 0%, 0 votes
Perhaps you could use a USB cable and a USB-to-parallel port printer adapter, provided your computer has USB port available. This solution may not work with all printers, but it works with some. Sometimes even faster than using a parallel cable, as USB is faster transmitting and receiving data. Good Luck!
Was this helpful?
Yes
No
Popular Solutions for Nikon COOLPRINT Thermal
Questions and Unsolved Problems for Nikon COOLPRINT Thermal
Do you recommend Nikon COOLPRINT Thermal Printer?
Answer
Answer
it says i have to download a high speed usb controller for my wireless usb adapter for it to be... (More)
Answer
On IMac OS 10.4 The printer gave me the choice of printing both sides. On )S 10.6 that choice has... (More)
Answer
Canon PIXMA MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL... (More)
Answer
Canon MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL... (More)
Answer
when i try sending fax it says low memory on display and the fax doesn't go through it stops.-- low... (More)
7 Other Users Have The Same Problem - Continued
Comment by zuka_zuka, posted on Jan 23, 2008
i already have this problem
Comment by bluemoon9064, posted on Dec 10, 2007
My new computer only have the usb 2.0 port for connect to the printer, how can I use ML 1430? Because ML 1430 only have parallel ports.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon COOLPRINT Thermal...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
