Question about Garmin iQue 3600 GPS Receiver
I have a ique 3600 and was working fine until I plugged in the ac adapter to the bottom of the unit. It won't turn on. I did a soft reset and now I get a flashing Palm Software screen. I even tried a reset while simultaneously pressing the power button. Same result. occasionally it asks me if I want to erase all data.
Mine has gone into the looping/flashing Palm Screen and then displays the hard reset do you want to erase everything. I fixed it by pushing the up button when it gave me the chance to delete everything and it fixed it.
Posted on Jan 10, 2009
Garmin ique 3600 not working
Been there. If the unit will not reset with the hole in the back poke you need to disconnect and reconnect the battery. Use a small torx screw driver for the four screws in the corners. Gently split the back case off by the thumbwheel and pivot it around. the battery connector is a small white connector in the lower left hand corner. Be careful of the power switch, ir lamp cover, and plug gasket since when you open the case they sometimes make a break for freedom.
May 08, 2009 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 has a blink screen
if it will not power up, you don't have many options.
unscrew the head of the sylus to access the rest tool
Press the reset at the back with the stylus
This is re-booting, all data safe still here.
Hard reset is last resort...data erased here.
Press the reset button again as above
after you release, press the power button, keep pressing until the message
( all data stored is about to be erased )
to complete the reset press the upper half of the scroll button, on the front,
The digitizer screen appears
pressing any other button here performs a soft reset.
Update it if you get it up and running.
Hope this helps
Ric.
Mar 22, 2009 | Garmin iQue 3600 GPS Receiver
Dark screen on garmin ique 3600 pda
Turn the unit on and try holding the on/off button down for three oe four seconds.
Mar 13, 2009 | Garmin iQue 3600 GPS Receiver
Ique 3600 Hard Reset problem.
Hold POWER button down while doing a RESET. On restarting all should be OK
Sep 12, 2008 | Garmin iQue 3600 GPS Receiver
My Garmin ique 3600 won't come.
Hold POWER button down while pressing RESET button
Aug 04, 2008 | Garmin iQue 3600 GPS Receiver
IQue 3600 Fatal Alert
You'll have to do a hard reset. Push the reset button, then hold the power button until the Palm Power appear and then release the power button. Next it will ask if you want to erase the data. I hate to said this but select yes. No will not work. Then after the inital set up run a HotSync.
Jun 18, 2008 | Garmin iQue 3600 GPS Receiver
Fritzed Unit when antenna up
I have a similar problem but I can't turn the GPS off at all, even when the antenna is down. As far as the power on/off cycle, I found another link on this site that said to turn off WAAS while the GPS is off then when you turn it on the unit will not power cycle continuously. You loose the WAAS feature but the GPS and unit still works.
Jan 24, 2008 | Garmin iQue 3600 GPS Receiver
Screen Display Problem
Do hard reset? See Owners Manual.
Call Garmin they are very helpfull
Garmin USA 1-913-397-8200
Tech support 1-800-800-1020
1-888-442-7646
8am to 5pm Mon -Fri
Garmin Europe 44 1794-519944
Garmin Taiwan 886 2-26429199
Oct 27, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600
Did you try to do ANOTHER hard reset?
Aug 13, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600
'Soft Reset' If that fails 'Hard Reset' while plugged into the mains! You will end up with an empty iQue but a HotSunc will re-intall
Mar 29, 2006 | Garmin iQue 3600 GPS Receiver
Garmin iQue 3600 GPS Receiver Logo
94 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
