Question about HP Photosmart C5180 All-In-One InkJet Printer
Cannot print in black and white when color is out
I have an HP D7400 and I can't print a black and white document because my yellow ink cartridge is out.
How do I do this?
  • 1 more comment
  • Anonymous Dec 30, 2008
    Same thing with me and cannot find anywhere that tells me why.
  • Anonymous Feb 24, 2009
    Am alos looking to print in Blk Only.
    You can go online (actually, you ARE online:)
    and chat with a HP rep. I can't because they don'lt spt Mac OS.
    (they SELL HPs that run on it, but they don;t want to support)
    Anyway, PC folks should be able to at least ask them
  • Anonymous May 12, 2009
    cannot print with black cartridge when color is out hpd7460
SOURCE: HP 5610 Will not print Color documents, only Black and White
Chances are that your print driver is set to print in black and white while the copier side is automatically detecting that your original is in color. To have the printer print in color: Select file print, select your printer and hit preferences. Select the Paper/Quality tab and switch from Black and White to Color.
Henry
Posted on Apr 28, 2008
pagebor
  • 2785 Answers
SOURCE: Won't print with only 1 cartridge empty
sorry you can print unless all your cartridge are having some ink
Posted on Dec 17, 2008
SOURCE: won't print with just black ink cartridge
A part solution is print/properties/maintenance/ink cartridge settings/select black only.
You do initially have to buy another color cartridge but you won'thave to buy another expensive color cartridge again in the future.
I
Posted on Jan 12, 2009
SOURCE: Will not recognize new yellow ink cartridge
I junked it!
Posted on Jan 30, 2009
  • 73 Answers
SOURCE: HP 6940 color cartridge light will not stop blinking
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
I might have an idea why this is happening....The print cartridges might need cleaning...
Follow the steps below to do this....
Step one: Remove the black, photo print cartridge, or the gray photo print cartridge
NOTE:
The black, photo print cartridge, or the gray photo print cartridge is in the right side of the carriage. -Lower the cover of the product.
-If the print cartridge status light flashes, proceed to Step two: Replace the print cartridge.
If the print cartridge status light is off, proceed to Step three: Manually clean the print cartridge.
Step two: Replace the black, photo print cartridge, or the gray photo print cartridge and remove the tri-color print cartridge
- Remove plastic tape from new ink carttridge CAUTION:
Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper electrical contacts.
NOTE:
The tri-color print cartridge is in the left side of the carriage.
-Lower the cover of the product. -If the print cartridge status light stops flashing, proceed to Step three: Manually clean the print cartridge.
If the print cartridge status light still flashes, replace the tri-color print cartridge. If the issue continues, service the product.
1. Gather the following items to clean the print cartridge and carriage:
o Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
o Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
o Sheets of paper or a paper towel to rest the cartridges on during cleaning.
2. Open the product cover, and wait until the carriage stops moving.
3. Remove the print cartridge, and place it on a piece of paper with the nozzle plate facing up.
NOTE:
Clean the contacts quickly so that the print cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
4. Unplug the product.
5. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp.
6. Clean the print cartridge contacts. Do not touch the nozzles.
7. Clean the contacts in the carriage, inside the product.8. Either let the print cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
9. Reinstall the print cartridge.
10. Plug the product back in.
11. Close the product cover.
Good Luck!
If there is anything more I can do for you please let me know if not and the problem is solved please rate it, Thanks, JCE
Posted on Apr 14, 2009
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
The scan of color document gives a black and white product
there some reasons :
1- Are you sure to select the copying color not black and white ?
2- try to reset color ink cartridge ,
3- try to select clean print head
i hope that was help you
Mohamed Hejazi
Afaqnama -Libya
ipg@hplibya.com
Mar 21, 2013 | HP Officejet 4620 e-All-in-One Printer,...
Hp printer 7450 won't print colored text from a word document. test page shows colors on the windows logo flag. changed the ink cartridge....color one that is....no help i will try to print something else...
It may be set for grayscale (black and white) in the print properties. Go into the print properties in Word and look for a color or black and white setting, either under Color Management or Advanced. Set it for color, and then print your color document.
Jun 19, 2010 | HP Photosmart 7450 InkJet Printer
Hp color laserjet 2840 - prints one page in color, next in black & white. Yellow ink cartridge light blinking. Says "replace supply, using black only". Yellow wasn't showing as low previously.
Follow each of these steps until the problem is resolved:
Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
Remove and then reinsert the print cartridge(s) into the printer.
Print the document.
If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
Try printing again. If the problem continues, replace the print cartridges.
http://www.fixya.com/support/t5717191-hp_deskjet_6540_printer_yellow_light
Jun 18, 2010 | HP LaserJet 2840 Printer
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
Only prints in yellow color
The printer must be able print all colors in order to execute the alignment. Part of the alignment process involves scanning printed colored (all colors including yellow) bars. See the web page below for a sample of the printout. I suggest that you clean the carriage and cartridge electrical contacts with a cotton swab moistened with water. If you still fail to get yellow, test the cartridge in another printer. ping me for the make of printer, anyways if it an HP series refer to the website below
http://h20015.www2.hp.com/en/document.jhtml?lc=en&docName=bpu00657
May 01, 2009 | Computers & Internet
Brother DCP-145C Print in black and white..?
As far as i know it will not work for color print unless all the cartridges are full. It will still print in b&w- go to properties of your printing document and change to "greystyle" but this will only work if you don't/have not turned off the machine at the power point. Once the machine is reset it wants to confirm all new cartridges and wont allow a black print until they are all in and full. So you cant use cartridges that have run out to "trick it".
I'm not sure if this is the intent of brother ( my guess is yes) a design oversight or a genuine precaution measure for consistency by not letting the printing heads dry out.
The yellow always runs out first, so stock up on them if you do alot of color printing- but the cartridges only last for 6 months so don't go crazy.
Brother if your reading this- Most of us don't care about color~! We just need a printer for uni and information. Make it work on our price range please!
Apr 29, 2009 | Brother Office Equipment & Supplies
When I print, only the color cartridge is used. I'm printing documents that are all black and white. How do I print with the black cartridge? I have a full black cartridge, but my printer won't let me...
if your document only black and white , the machine only use black ink, no going withdraw the color ink. but you have had to leaved the full color ink in the machine.
Dec 09, 2008 | Lexmark X2600 InkJet Printer
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
154 people viewed this question
Clive
Clive
