Question about SanDisk Sansa e250 MP3 Player
Battery won't hold charge very long
My Sansa e250 mp3 player won't hold a charge for more than about an hour and a half. I installed a new battery, but the same problem occurred. Then, yesterday, it froze. It unfroze when the battery ran out.
Now, I'm charging it again. The battery indicator shows it is charged, but the display says it's "writing".
Can anybody tell me what to do besides toss it?
Thanks for any advice you can give.
  • reverter Dec 30, 2008
    Thanks Mp3 md, but the big problem I have is the battery not holding a charge. I appreciate the advice as to unfreezing the device, but that only happened once, and sort of fixed itself. I need to know if there is a way to get the device to not drain the battery. I like the features of the device and would like to continue using it without having to recharge it every hour and a half.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + (REC button for Sansa e200 series) button, and reconnect the player to the computer while holding the volume + (REC button for Sansa e200 series) button in. Keep holding the volume + (REC button for Sansa e200 series) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 30, 2008
  • Corey Knoettgen
    Corey Knoettgen Dec 31, 2008
    Yeah, the above were the only software fixes. If they failed to resolve, there is a hardware problem with the mp3 player that cannot be resolved even by replacing the battery itself. I'm afraid it is replacement time.
Sansa e250 wont charge when plugged into the computer.
Sounds like the internal battery needs to be replaced.
Hope this helps. Good Luck!
Aug 07, 2009 | SanDisk Sansa e250 MP3 Player
Batter low shutting down
Your battery is low, therefore the player is shutting down.
Recharge the player by plugging it into your computer for 3-4 hours - make sure the hold/lock is not activated, or it will prevent proper charging.
-Tha Mp3 Doctor
Mar 18, 2009 | SanDisk Sansa e250 MP3 Player
Battery will not charge
try to get a new battery out of the manufacturers warranty it might just be a bad battery that cant hold the charge
Oct 26, 2008 | SanDisk Sansa e250 MP3 Player
Yes I have How do I fix it
Dec 18, 2007 | SanDisk Sansa e250 MP3 Player
My sansa e250 mp3 player is not turning on and charging.
i had the same problem.  the solution i used was to unscrew the back and pop the battery out and put it back in.  the only other option is to wait for the battery to die, which can take a while.  it's definitely a flaw with the sansa.  its happened twice within 6 months...  good luck
Oct 20, 2007 | SanDisk Sansa e250 MP3 Player
Problem with charging
try performing recovery mode on the player then after performing recovery mode update the firmware of your player. Recovery mode is > Enable Hold Switch + Press Record Button + Menu Button
Oct 08, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 - Won't power up unless connected via USB
Sounds like the battery may have come loose. Remove the 4 screws on the back, remove and reinsert the battery. Charge the device for a few hours. Best of Luck.
Oct 04, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250
i know i have to charge my sansa for at least 7-8 hours before the battery will show it is full. about your other problem, i believe there is an option under the settings menu to automatically shut your sansa off. If not then you can turn off the backlight and that will save alot of battery life.
Mar 02, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player won't charge anymore
an itrip has different charging rates than an ipod, so you fried something inside of your sandisk.
Jan 08, 2007 | SanDisk Sansa e250 MP3 Player
Help me please! My mp3 player shut off.
press the power button for 15 seconds and let go. leave it plugged in the battery should be charging.
Dec 27, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
57 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
