Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Dishwasher won't turn on
Unit has no power. Fuse not tripped-did reset. Plug is in receptacle and was tested to have power with disposer.
  • 4 more comments
  • Anonymous Dec 27, 2008
    Unit stopped before all of the water was pumped out. Breaker OK ... plug in the same ourlet as disposal and disposal works. Doesn't seem to be any power at the dishwasher. Is there a fuse in the control panel or a "reset" button? JohnC@chandlersearch.net
  • macott Jan 03, 2009
    our dishwasher completely is not working, nothing. We cannot find a reset button on ours.
  • dawn diehl Jan 19, 2009
    whirlpool will not cut on. was working fine yesterday and went to cut it on last night and will not cut on.
    will not turn on at all. working fine yesterday and will not turn on now. Can't find the reset button
  • gatorlove36 Jan 24, 2009
    I have the same problem with my Whirlpool Dishwasher Gold, the unit has power but will not do anything. The buttons are dead.
    Where is this so called reset button or fuse in the dishwasher ???
  • Anonymous Mar 29, 2014
    the dishwasher fails to operate at all. power to the receptacle
I have the same problem with my whirlpool. The tech. said it was the fuse in the control panel.
Posted on Jan 17, 2009
  • 78 Answers
Theres a reset button,
Posted on Dec 30, 2008
My kitchen aid dishwasher is 1 years old and suddenly today it does not work.checked the breaker it's fine.what may be the problem
Make sure the unit is plugged into the outlet under the sink. sometimes when moving things around under the sink, the plug may have come out of the socket in the wall. If that is ok, then you will need to make sure the D/W is getting power. You can use a multi-meter or small plug-in checker that lights up when inserted into the receptacle or outlet to check for power, or have a qualified electrician check for you. Also, just because a breaker does not look like it is tripped, doesn't mean its not. Sometimes that also has to be checked to verify it still has power. Most have to be fully turned off, then back on to be sure it has reset. One more thing to check would be to see if the dishwasher is connected to a GFCI as that may have tripped.
Dec 12, 2015 | Dishwashers
How do I fix -no power issue on my samsung dmr78ahs dishwasher?
To eliminate a dishwasher problem, run a heavy 3 pronged extension cord from a known working outlet to the dishwasher and plug the dishwasher into the cord. If you still have no power (dishwasher is not showing any signs of life) then it is a dishwasher problem (circuit board, bad connection from dishwasher cord to dishwasher, etc).
If the dishwasher actually shows signs of life, then you may have a tripped breaker. Check the breaker to make sure it is on and that the tab is not either in the center or the off position. Also, try moving the dishwasher cord's plug from the outlet it is currently in to another outlet in the under sink area. There is a chance that the plug got switched from the normal outlet to the outlet that controls the garbage disposal, that outlet should only be hot when the disposal wall switch is flipped to the on position.
Dec 18, 2014 | Samsung DMR78AHS Builtin Dishwasher
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
Dishwasher won't start
1) TEST some fuse blown +c. breaker trip , reset.
2) Test the outlet wall, and reset the c.breaker house.
3) Test the switch door, if there are defective or open the starting relais will not start the main motor see the schematic.
May 10, 2012 | Frigidaire 24 in. FDB1050RE Built-in...
Whirlpool quiet partner 1 won't drain all the way suddenly
Hello.
HERE ARE TOOLS NEEDED AND INSTRUCTIONS ON HOW TO SOLVE THE DRAINING PROBLEM BELOW.
(A) Clean cloth(s)
(B) Wrench (if necessary)
Whirlpool brand dishwashers come in black, brown, stainless steel or white finishes and a variety of sizes as well. Most Whirlpool dishwashers are energy efficient, and many have features such as a sanitizing rinse, enhanced sound effects, large capacity tubs and adjustable shelves and racks. However, none of these features will help users much if the dishwasher is not draining. While this issue may require professional repair, some troubleshooting steps may help determine if there is a relatively simple cause for the problem.
1 Verify that the Whirlpool dishwasher has not lost power due to a power failure or motor overload. Wait a few minutes to see if the motor automatically resets and resumes operation. Reset the circuit breaker or fuse if necessary.
2 Press or select "Start" to resume the cycle if the dishwasher was stopped mid-cycle. Choose a new drain cycle if necessary to remove excess water from the unit.
3 Turn off the dishwasher and unplug it from power. Examine the connection between the dishwasher and the garbage disposer, usually located underneath the kitchen sink. Make sure the disposer knockout plug was taken out between the two.
4 Run the garbage disposer in the kitchen sink to remove potential blockages.
5 Remove objects that may be blocking the drain on the dishwasher. Clean out the drain hose at the rear of the dishwasher.
Thanks.
Nov 06, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My Ionic Breeze Model S1637 just stopped working and I don't know what to do. Is there a solution for this. It appears as if the unit is not getting any power?
Test the outlet that it's plugged into, to make sure it's still functioning properly. There may be a loose connection at the receptacle or the circuit breaker in your home's circuit breaker panel, for that receptacle may have been tripped. If it is, before resetting it, make sure the air purifier is not plugged in to it. Then plug the unit in and turn it ON. If the circuit breaker trips again, there's a wiring short in the air purifier. Contact Sharper Image for possible repair or replacement.
Apr 04, 2011 | Sharper Image Ionic Breeze 3.0 Air...
My disposal only works when the dishwasher is
You say that the disposal only rotates when the dishwasher is running? Are you saying if you turn the disposal on it will not work unless the dishwasher is also on and then it rotates? If you have an on/off switch for the disposal it should at least try to turn when you turn it on. On the bottom of the disposal is a red reset button. If the disposal will not come on push that reset button to reset the breaker. This may solve your problem once you get the disposal running and clean it out. If it trips again something is lodged in the unit and you must clear it out. Turn the power off at the service panel before attempting this. It may also be getting power from a GFCI receptacle. Check the ones in the kitchen to see if they have tripped. Reset them by pushing the red button, and see if that fixes the problem. The drain line from the disposal may also be clogged. Get a bucket and remove the drain line from the disposal and check for a clog in the line and inside the disposal. If you find none then move to the trap under the sink. You may find one of these clogged. Use ice to sharpen the disposal blades and keep the unit fresh at least once every 3 months. Just put ice cubes in the unit and turn it on for about 15 seconds.
Jan 05, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
No power is there a reset button?
Check your circuit breaker or fuse box.
Also, check under the sink. Some models plug in and some are wired in. The plug might have been knocked out. Also, someone may have plugged it into the disposal plug. Try turning the switch on for the disposal and see if the dishwasher comes on.
No, there is not a reset button on a diskwasher.
Are you sure you have no power to the dishwasher?
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Oct 24, 2009 | Roper RUD3000H Dishwasher
The dishwasher doesnt turn on
1) Be sure the power is on, the door is latched, and the control is turned on. If absolutely nothing happens--in other words, nothing on the control panel is lit and there are no signs of life-- the appliance may not be receiving power. If the dishwasher's cord is plugged into a receptacle, check to see if it is a GFCI receptacle with a reset button. 20090521162623_gfci-receptacle.gifIf it is, push the reset. If it isn't or if the dishwasher's cord is wired directly to the electrical box, look for any other receptacles in the kitchen that have a reset and and try resetting them. (This is a longshot but it's easy to do and may solve the problem if the dishwasher is on the same circuit.) To test a receptacle for power, you can also just plug a hand-held appliance into it.
2) If that doesn't work, check the electrical panel for a tripped circuit breaker or blown fuse. If you find one, switch the breaker to "Off" and then back to "On" or replace the fuse.
3) If electrical power is available to the dishwasher but the appliance doesn't run, the problem is likely to be a defective door switch, timer, or selector switch. To solve a door switch problem, you may be able to adjust the door latch’s strike slightly, using a screwdriver (turn off the power to the dishwasher at the electrical panel when working on it). Regards Fixya..
Mar 24, 2009 | Whirlpool Gold GB2SHDXPS Stainless Steel
Switch will not turn on disposal
under the sink you will probably find an electrical outlet with the disposal cord plugged in. If so, plug another item into the outlet like a blow dryer to be sure you have power to the outlet. If you have no power the problem is a tripped breaker or a blown fuse. First check all of the plugs in the kitchen area including under the sink to determine if you have a ground fault circuit interrupter outlet. If you do, it may be tripped. If it is tripped simply reset it.
If you know you have power to the disposal then check to be sure no spoon or other hard object isn't in the disposal preventing it from operating. Use a flash light to check this. If there is no obstruction look on the case of the disposal for a reset button. good luck.
Jan 19, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
807 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
