Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washing Machine
The only model and serial number I find are Y-80455-D 6 2712250 White 6 2713130 Bisque these numbers are under the control dial. The washer is making a loud clunking noise all the time even as it is filling with water. Also the front edge of the drum looks like it is rubing on something as it is really rough. We purchased this washer at auction.
    President:
  • Maytag Master
  • 2,651 Answers
Can you reach inside the unit and grab tub and lift it up(as if perhaps the rear shaft has loosened causing more then a 1/4 inch of play in inner drum??? if that s the case sounds as if perhaps you have a bad rear bearing (over $700 in parts alone)
Posted on Dec 21, 2008
I have a maytag neptune seial number 44335433WW and need to know the model number that is not recognizable on the machine?
Serial numbers are unique to each appliance. If you can link a picture I can probably help you. I have sold every model of Neptune that came out until they were discontinued.
Mar 15, 2011 | Maytag Washing Machines
How old is my maytag neptune washer. model # mah3000awa serial # 32156767uy
The two letters at the end the serial number indicates the year and month, respectively, when the machine was manufactured. Refer to the table below.
In the case of your machine, the letters are U(1987/2011) and Y(November). The machine was therefore manufactured on November 1987.
Jan 16, 2011 | Maytag Washing Machines
My maytag neptune top loading washing machine when washing sounds like there are belts squealing and the washer tub seems to hit the sides of the machine when spinning what is going on?
This sounds like a possible Clutch issue. Is the machine model an FAV6800A or FAV9800A?
When the washer is banging around do you take unbalance errors such as dC or uC?
Do you want to DIY the fix or call in a repair service. If you could confirm your machine model number......Rich
May 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Display does not light up at all
If the 120VAC wahser service outlet has power and the machine LED Control Console for the FAV6800AW or LCD screen for the FAV9800AW appeares to have no power then I feel you have a Control Board failure. If you post your model number we can give you and aproxmate cost of the Control Board. The Control Board is under warranty for 5 yr. If you call Maytag customer service at 1-800-688-9900 they will need your Model Number and Serial number located on the rear top right of the console.
The above machine types do not have an internal fuse or circuit breaker to check.
Nov 14, 2009 | Maytag Neptune FAV6800AW Top Load Washer
How do I get my Maytag Neptune TL washer to stop beeping and start washing again ?
Try disconnecting the 120VAC power cord for a few minutes then re-power back up if you haven?t already tried that. If you still have the same issue then you may have a failed Control Board. If it?s the FAV6800AW is there an error code in the LED display? If the machine will not d let you into Service Mode then my next step would be to replace the Control Board a 10 minute job. If you decide to call in a service repair company I would call Maytag for an authorized Maytag repair service in your area. Some parts like the Control Board may still be under warranty (5yr). Warranty info is in the SM link I attached. The number to call is 800-688-9900. Maytag will need your model number and serial number, that info is located on the back right top side of the console. The Service Manual for reference. Sears Parts Direct for reference. Post back if you have questions or want to dig deeper into the issue
Oct 31, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I was wanting to know the year of the maytag neptune washer? model # MAH5500BWW
Try and get the serial number then contact a Maytag agent. The serial number in most cases is a date code.
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Cold water just stopped flowing in,hot works
There are two electronically controlled valves in the back of the machine; one for hot water and the other for cold. It sounds like your cold valve is stuck closed or not getting the electronic signal to open. I recommend going to the following web site or calling 1-800-344-1274 for help from Maytag. They will want to know your model number and serial number so try to have that information handy when you call.
http://www.maytag.com/support/contact_us.jsp
May 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Tub fills with water
replace water valve in the washer. Serial number is needed to find the correct part number. It's likely 22003834, but call any parts supplier with model/serial numbers to verify.
Good luck,
Vlad
First Choice Appliance
Jan 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
I would like to know the age of my machine, whether I should have it repair or buy a new machine. The model #MAH4000 Maytag Neptune. Lydia Dunbar
The age is determined by the SERIAL NUMBER. Please post back with your complete serial number, particularly the last two letter designations. With that info I can tell you month and year the washer was manufactured.
Jul 14, 2008 | Maytag Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
119 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
