Question about Kenmore 24032\24036 Top Load Washer
How do I gain access to change lid switch and water valves of kenmore washer #110.24712300
  • 76 Answers
On the top of the washer, where the timer and adjustments for the washer are, the side decrative panels come off, after you remove them back out the screws and tilt the head unit up, you will see aset of wires atached to the case, unclip them, then you will see on each side, on top a brass colored "s" shaped clip connecting the case to the back panel, use a screwdriver(flathead) to remove them(place screwdriver down into clip and push the screwdriver head towards the back of the wash machine and they will pop out. now tilp the case towards you, and pull backwards...the lip switch is underneath the case.
Posted on Jan 01, 2009
How do you open the washer to access the lid switch on a model 22422 Kenmore machine?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Feb 16, 2011 | Kenmore 22422 Top Load Washer
My Kenmore washer will fill with water and oscilate, then nothingf won't spin or drain. I 'm guessing that it is the lid switch , ( relay switch ) ?? Mod # 110.94518201 serial # VLG 1601709 can this...
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11094518201/0582/0153200?pathTaken=
Look at the diagrams for the cabinet and you'll see a list of component parts (Lid Switch) with the Sears part numbers (the manufacturer authorized substitute numbers are Whirlpool) and the Sears price.
Dec 03, 2010 | Washing Machines
Had washer 12 years. Model 110.25862400. Fills and now nothing will happen. Have not changed ffrom cold/cold setting.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11025862400/0582/0153200?pathTaken=
Nov 07, 2010 | Kenmore Washing Machines
Hello--my whirpool washer's lid will not click when it closes, and the load is just sitting there in water not rinsing. What can I do to get the top lid to click? Thank you
I would suspect the lid switch on you washer. I have Kenmore that had the same problem. I was able to gain access to the switch and repair the switch. The repair was done was over a year ago and washer is still working.
Oct 22, 2010 | Whirlpool Washing Machines
Kenmore 80 series fill with water but will not go into wash cycle or or spin out water and make a noise morenovalley1@hotmail.com
Jun 20, 2010 | Kenmore 24032\24036 Top Load Washer
Water draining problem
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20702991&pathTaken=partSearch
Jun 13, 2010 | Kenmore 27632 Top Load Washer
Kenmore washer - water won't drain. It stops
May 12, 2010 | Washing Machines
Our Kenmore wahing Machine just shut down in the mddle of a cycle
May 01, 2010 | Kenmore 24032\24036 Top Load Washer
How do I replace the lid switch on my kenmore series 80 washer?
See the section on the console and cabinet and you'll see where the switch is located.
See the following for how to remove the cabinet to gain access to the Lid Switch.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=61f80e08f3f0ad9fa07bd1a70b21c4cd
Nov 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
67 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
