Question about Gateway MP8708 Notebook
Mp8708 laptop, 2GB memory slot isn't being listed as source
I'm trying to upload pictures from my camera's memory card. The slot for the card isn't listed as a possible source for places to upload from. Is my laptop not recognizing that slot? I have the memory card in the slot and although the little pink light is on, and the blue light next to that is also lit, nothing happens.
  • river1005 Dec 29, 2008
    The brand of my laptop wasn't listed in my question, so I give you kudos for listing a variety of them in your answers, unfortunately gateway wasn't amongst them. However, it was at a Gateway site that I found the link to this website, so going there would just be going in circles.
  • Anonymous Mar 31, 2014
    I want to upload movies and pictures from my digital cameras memory card. I can't figure out how to get the card reader open on my laptop. There is a piece of plastic blocking it that does not move.
My memory stick pro duo is not read when I stick it into my memory card slot on my laptop. I do not have the USB cable to hook it in otherwise, is there a way to upload my pictures?
you can buy a All in one USB Card reader/Writer and then insert the memory stick pro duo card in it and plug in the USB Card reader/ writer
to the USB port on your laptop and you should find the same listed under removable devices under my computer. good luck
Sep 13, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
No matter what program I use, the fuji memory card that came with the camera, will not upload pictures into my computer. It will only upload pictures stored on the internal memory. But that's only 3...
That memory card isn't great, is it? You already got the 1.01 firmware upgrade to the camera, right? Try a card reader (and soon, a new 8GB SDHC card,) instead of making the camera suffer.
Aug 15, 2011 | Fuji FinePix Z10fd Digital Camera
How do I add pictures onto my computer with the Olympus u tough 3005? I have tried taking the memory card and putting it into this little slot in my printer for digital camera memory cards, and usually...
The cause of this is probably an incompatibility between your memory card and the card reader in your printer. Your camera is fairly new, and you probably have a memory card of 4Gb or more, which is going to be SDHC. Your printer is probably older, and is only compatible with SD (generally cards up to 2Gb).
Your solution is to use only SD cards, which essentially means limiting yourself to 2Gb, or buying a card reader which can support SDHC. I don't know what country you're in, but I bought a SDHC card reader in a dollar store for $2.00 which is half the price of a large latte.
Jan 23, 2011 | Olympus TOUGH3000 Digital Camera
I have a slot in my laptop where i put my memory card, once i do that it, a window usually pops up and asks me if i want to go through to pictures or upload them etc. etc. but lately i've been having to...
You should make sure the memory card slot does not have dust in it and you should also try putting the memory card into another computer,to see if it will work if it do not work the memory card is bad.
Aug 15, 2010 | Computers & Internet
I have a PNY optima sd 2gb memory card and it tells me on my samsung camera card error. What does this mean?
My Sanyo camera says my sd card it full when it absolutely is not. Ive even tried uploading pictures to my computer and it tells me there is an issue. It just suddenly did this one day and I think I've lost about 150 photos from Easter and other things that I can't get back and worse I can't take any pictures with my camera now.
Mar 09, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
Where is the bluetooth-cable connector on the gateway mp8708. Thanks Heinz
I believe he's asking where to add the aftermarket modules: GABU-MP8708-0001 MODULEGACA-MP8708-0038 CABLE
Jan 11, 2010 | Gateway MP8708 Notebook
How do I upload pics from my digital camera memory card onto my laptop via the memory card slot?
the easiest way is get a USB multi-card reader if your laptop does not accept the card. hope this helps
Aug 17, 2009 | Computers & Internet
I have an hp officejet 7310 and use a 2gb sandisk memory card with my canon camera. what slot can i put the memory card in to upload my pictures onto my computer?
It depends if the 2 Gb card is a SD or a XD check the manual of your camera then once you know put it in the one that is labled the same
Jan 23, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Problem with 2GB Kodak memory card
hi if you place the memory card into slot of your pc or laptop and follow the instructions on screen or take to your nearest chemist they will be able to put your pics on to a disk for you when you have saved ther pics to either your pc or disk you can then delete the pics
Jan 09, 2009 | Kodak Easyshare M753 Digital Camera
Nikon Camera/Acer Laptop
Hey kholcombe252,
I'm assuming this means you have formatted the memory card. If this is the case you could purchase a memory card reader that connects to your PC via a USB port, and you should be able to copy and paste your images back to the memory card.
Sincerely,
Allan
Go Ahead. Use Us.
May 07, 2008 | Nikon COOLPIX L3 Digital Camera
Gateway MP8708 Notebook Logo
107 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
