Question about Home
Electric shower has suddenly stopped producing hot water.
No other problems with water pressure etc.The water coming out of the shower is just cold.It was working fine earlier today.Unit is a New Team 10.4 model 9.5kw and is about 4 years old.
brainyass
  • 242 Answers
SOURCE: Triton Electric Shower Temperature too hot
You could have mineral deposits on the temperature probe inside of the unit. If you remove the heater and purchase a bottle of lime and scale remover (lime away) to put inside of it. Let the unit sit full of water and chemicals for 24 hours. Flush out the unit to remove any residue. You may see the water is brown if you have a lot of buildup. Reconnect unit and test your settings. If this doesn't work, install a anti-scalding device, available at a plumbing supply store.
Posted on Oct 23, 2008
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Posted on Dec 15, 2008
  • 659 Answers
SOURCE: Just moved house today, have a sirrus shower 1600- cold water
There is something caught in the hot side of the faucet manifold (main faucet body). You have to remove the trim and guts to access it. Use a flash light and look inside. Hopefully you can find the object. Oh by the way, you need to turn the water off to the whole house to do this. If you don't see anything have someone turn on the water slowly with the valve out of the manifold to rinse out the pipe leading to the valve body. Hopefully it will remove whats in there. If what you see is a white looking material that is stiff but brittle, then it's from the water heater and the water heater needs to be replaced. Sometimes there can be small stones that get "washed" into the lines when the main is worked on within the area of your home. But most likey it's from the water heater. Good luck! Don't forget to turn the water off before you remove the faucet guts.
Posted on Mar 21, 2009
  • 297 Answers
SOURCE: No hot water flow from faucet/shower
change the cartridge it is bad or defective.
Posted on Jul 20, 2009
SOURCE: Having troudle getting a spare hand shower holder
I found this product and it's awesome if you have a smoothe surface to suction it onto... Here is the website link. Hope it helps...
( If the link didn't work, copy and paste this into your browser bar www.kidsafeinc.com/product/70456)
Posted on Jan 06, 2010
Uberhaus 75175006 shower column has very low hot water pressure
The shower head may be clogged with debris.
Nov 09, 2013 | Home
Triton thermostatic shower hot water is reaching the shower but not traverling any further only cold water comes out.i've had the whole shower system off the wall and hot water flows out of pipe but when i...
Could be the pressure on the hot water flow is insufficient, you really need a 5/6 feet head of water from the shower head to the bottom of the storage tank for sufficient pressure.
Nov 06, 2017 | Home
I have a problem with low hot water pressure can you help would an elec shower help
1) If possible, it is Best to solve pressure problem before installing new shower.
http://waterheatertimer.org/Low-hot-water-pressure.html
2) If the cold water has good pressure, then Electric shower could fix problem ... but shower would have to be connected to the cold water line and not the hot.
3) Seems the expense of adding a electric shower would be greater than having plumber fix low hot water pressure.
Assuming you have access to plumbing pipes, and this is not apartment building.
Jan 05, 2013 | Water Heaters
Low hot water pressure on Moen Single-Handle Shower Only posi-temp shower control. Cold water pressure is fine. Hot water pressure elsewhere in house is ok. Cold it be the cartrige -- lime buidlup, etc.?
I think you are on the right track. The first thing I would do is change the cartridge. While you have the valve apart examine the inlet ports as good as you can to see if there is any mineral buildup. You can use a short length of a small gauge mallable wire to run into water ports to se if you can break anything loose. Another thing you can do is to turn supply stop on slightly while you have the valve disassembled to wash any particles out. Hope this helps you and thanks.
May 14, 2011 | Moen Posi-Temp Single HandleTub And Shower...
My 2007 Fleetwod ##0 FKDS TT has no hot water delivery, (cold is Fine) No water comes from any faucet (3), or shower(2). When hot water is tried a short squirt of water (Les than 1/2 sec ond) comes out and...
Check for faulty (broken/apart inside) and replace check valve on hot side of tank (top line) between line connection and tank. Stem, spring etc, of new one goes in facing into tank.
Jul 18, 2010 | RTO Atwood Water Heater - 6 Gal LP
Mira mixer cannot balance temp.either scalding hot or freezing cold
I suspect you have gravity fed hot water system and the mixer cannot balance the high pressure of the cold mains against the low pressure of the hot water.
Either install a shower pump. Means installing electrical connections and quite a bit of plumbing
Or a mechanical pressure reduction valve on the cold input pipe to the shower
Apr 02, 2010 | Legacy Home
All of a sudden, our shower only produces cold water. When I turn the knob through it full range, it starts with cold as usual, but as I continue toward what used to produce ever hotter mix, it stays cold,...
I had the same problem. It was my heater/boiler this one runs my home heating and water. There's a 3 way gateway for central heating and hot water for shower etc. Probaly you got a aire bubble in there. Find the 3 way gateway and give it a knock, the bubble will disapear and the hot water will flow again. I'm sorry for my english but i'm Dutch.
dre
Nov 30, 2009 | Chrome Home
No water coming out of my Kohler Forte R10275-4-BN shower valve
This is a pressure balancing valve that needs both cold and hot water pressure to operated. It is an anti-scald safety operation.
Good Luck, Phil
Dec 25, 2008 | Plumbing
Home Logo
78 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
