Question about Tricity Bendix AW1400W Front Load Washer
How do i fix my bendix washer
Hi the part were you put fabric sofener in the washing machine next to were you but powder/tablets is always filled with water when it have finished washing so i have to take out the draw that its in and empty it so can put soffener in the next was please help thanks jess
not sure if that is the right washer below but it is a bendix and the door is at the front
  • 1 more comment
  • bubblejess Dec 20, 2008
    hi thanks so much for your advise i have had a look and cant find a tube in it dont know if i am looking in the right place but i have tried cleaning
  • bubblejess Dec 21, 2008
    hi thanks again feel really silly but i cant find this tube in the draw i have pulled it out and cleaned but it is still filling up with water is this tube in the draw because i have looked and cant find it dont know if it is the washing machine that i have put down but it is a bendix washer thanks
  • bubblejess Dec 23, 2008
    thanks so much for the help its fixed :-]
  • 566 Answers
Hi fro uk the softener compartment works on a syphon system if you remove compartment it has a vertical tube with a cap on top ? pull off top and ensure the tube is clear ? then refit cap firmly and refit compartment into drawer now the syphon briefly works like a toilet flush syphon ? when conditioner is added to correct level and cycle comes to conditioner mode ? water enters machineand the conditioner compartment ok so far?? then as compartment water level/conditioner rises up to top of tube ? under cap then it flows down tube and syphon's conditioner from compartment ? but the cap on tube must be fitted ? if missing for some reason? syphon will not work hope this is understandable tou you ? on how it operates wish you a merry xmas from uk
Posted on Dec 20, 2008
  • silver top Dec 20, 2008
    hello again and thanks for reply if you read the next post/reply solution that has been sent regarding removing drawer for cleaning follow this advise it is correct and will solve your problem when you remove drawer the cond compartment is also removable too best wishes
    Problem Solver:
  • 16 Answers
Hi! you need to un clip orpull the draw out (easy enough!) then give it a good clean, there will be a little tube in the draw that will be gunged up! a pipe cleaner or ear bud wil clean it through, with lots of hot water!
  • phil ( woody) woodley Dec 24, 2008
    sorry i wa late gettin' back to you! i've been mad busy with christmas! thanks for your comment! have a good holiday! glad your sorted!
How do you use the tub clean?
Read these instructions carefully before
beginning the TUB CLEAN cycle.
Open the door and remove any clothing in
the wash drum.
Open the dispenser drawer.
Add liquid chlorine bleach or tub cleaner.
Some powder or tablet tub cleaners which
are manufactured for this purpose can be
used.
(NOTE : Do not add any laundry detergent
or fabric softener to the drawer when using
TUB CLEAN.)
- If using liquid chlorine bleach
Add liquid chlorine bleach to the bleach
compartment of the drawer.
(NOTE : Do not exceed the maximum
fill line and do not pour undiluted liquid
bleach directly into the wash drum.)
- If using powder cleaner
Remove the liquid detergent cup and
add powder cleaner to the main wash
- If using tablet cleaner
Add tablet cleaner to the wash drum
directly.
(NOTE : Do not add tablet cleaner to the
drawer.)
Close the drawer and washer door.
5
Select TUB CLEAN and press START.
NOTE : It is recommended that TUB CLEAN
should be repeated monthly.
If mildew or musty smell already exists, run TUB
CLEAN for 3 consecutive weeks.
After TUB CLEAN is complete or when the washer
is not used, leave the washer door open for better
ventilation and drying inside of the washer
Jul 05, 2014 | LG WM2701HV Washer
Fabric softener dispenser
You could have something jammed in there
Aug 10, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Dispenser - which tray to use for liquid detergent?
Liquid goes straight into the wash before you put it on, you can get a liquid ball that you fill and put in with the wash, dispenser just for powder which goes in 2 or fabric softner.
Mar 01, 2011 | Hotpoint Ultima WF860 Front Load Washer
I have a Bosch washer. My clothes are not soft when washed. What kind of soap powder shoul I use ???
A couple of things-
It really shouldn't matter which you use, not unless the garments are , for instance, wool and really need doing by hand.
Are you using fabric conditioner/softener at all? If not I would start using it. The only time my wife does not use softener is with towels; they dry you better without it!
Also if your water supply is 'hard' i.e. has lots of calcium in it, definitely ALWAYS use a suitable anticalc powder/tablet in EVERY wash. Regularly clean the machine with the contents of a sachet of proprietary anticalc powder which goes in on its own- without any garments.
Good luck,
John C
Retired Englishman in SW France @ 17:47 Thursday afternoon.
Feb 10, 2011 | Washing Machines
My machine won't take the fabric conditioner. It fills with water in the fabric conditioner tray but will not drain into the machine. checked hoses, cleaned pump, cleaned drawer. Taking washing powder...
my machine won't take the fabric conditioner
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question
Jun 24, 2010 | Tricity Bendix AW1000W Front Load Washer
Samsung Washer,less than year old. Not every load and not every item but periodically something will come out with stains not previously on the item.
This is common, if the machine does predominantly COLD washes.
Over a period of time, there is a build up of soap scum (washing powder/fabric softener etc) inside the machine, caused by using excess soap powder/detergent.
To recitfy this, fill the empty bowl (no clothes) with a solution of HOT water & CITRIC ACID (found in the baking isle of your grocery shop) on HI Water level. Set the machine to wash cycle, then drain.
Fill again with same solution, but leave solution inside the bowl overnight.
Drain next day, then follow with 1 single HOT wash (no clothes) on HI water level again.
The scum should be gone...
The hot flush should be done at least every 6 months, but this can be dramatically reduced if you use less soap powder (Samsung machines do not require as much powder, as do other machines)
"If this has helped you, please rate this solution"
Nov 29, 2009 | Samsung Washing Machines
Tricity bendix is just filling up with a tricle of water
thankyou for the offer of help.i did not even know how to get in the machine,and started getting annoyed with it,so,unfortunatly,i am waiting for an engineer to come up,i think it only needs a washer,but,its gonna cost me about £80.a bit expensive,but,desperation calls.plus costing me a days wage,i would be cheaper buying a new one.but thats life,thankyou anyway for taken the time to get back to me.
Jun 22, 2009 | Tricity Bendix AW1000W Front Load Washer
Washing machine
i had the problem of my brand new washing machine not taking the conditioner and the customer service advisor rightly guessed that i was using concentrated liquid and advised me to dilute it with warm water then put it in the drawer because sometimes the liquid is too thick for the machine to take.try this!!!!! regarding the powder why not put it directly in the machine or buy tablets and do the same with those
Dec 18, 2007 | Hoover PE235 Front Load Washer
Tricity Bendix AW1400W Front Load Washer Logo
178 people viewed this question
Top Tricity Bendix Washing Machines Experts
Bobby G
Bobby G
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
