Question about Dacor Cooktops
Dacor electric stove top EBR33 burner control
One electric burner turns on high only
4 Suggested Answers
Eddie Rentas
  • 59 Answers
SOURCE: GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Posted on Jun 26, 2008
  • 58 Answers
SOURCE: My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Posted on Jan 09, 2009
SOURCE: ge profile electric counter top stove
I did not receive instructions with my G E Profile cook top Model No. 80030750434). There is a build up on the elements which I am having problems removing. Should the top be scraped while the stove is hot or cold? What is the best cleaning product to use?
Posted on Aug 20, 2010
How do i turn the outer ring on for a dacor stove top
Pushing the button for the element will turn on the inner element at level 5. Before adjusting the level (so while the level indicator is still blinking) press the little circle on the right side of the controls for that element. The circle should light up. Now press the UP control for that element, and the level indicator should stop blinking. Now the outer and inner elements are both heating up. Adjust temp level to desired setting.
Jan 30, 2013 | Dacor Millennia ETT304 Electric Cooktop
10-12 year old dacor 4 burner epicure cooktop --left front burner
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 29, 2010 | Dacor Epicure ESG366 Gas Cooktop
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
I am looking for replacement drip trays and intructions for instalation
Hardware store or appliance store that has a parts department.
You have a gas stove? Lift the grate, drop it in. Electric stove? Pull the burner up and away from the plug (look down at the burner, there are two pieces that go probably toward the center of the stove). Same as gas, drop the tray and reinsert the prongs into the plug.
I hope this helps you
a
Oct 02, 2009 | Dacor 48 in. Epicure EG486SCH (Gas)...
How do I unlock the burners?
there should be a key that you have to press and hold to unlock. find it and press till the light is gone let me know how it goes
Jun 12, 2009 | Dacor Millennia ETT304 Electric Cooktop
Stove top ignition doesn't stop ticking
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
Mar 22, 2009 | Creda Colonial 42352 23 in. Electric...
Stove top in lock mode
Hold your finger or thumb on the red light for a few seconds, and you will hear three beeps. This tells you that the lock is off. If the light is not on, do the same and there will be three beeps, and the light will come on, telling you that the lock is back on.
Feb 18, 2009 | Dacor Millennia ETT304 Electric Cooktop
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Gas Stove Top Burners
The burner are fixed only maintenace are to clean burner /clean holes and edge in order flow of gas good performance.At the back if you want make more good performance of your top burner clean the nozzle where the air and gas mix . Clean the nozzle w/fine niddle /sometime if will corrode with rust and dust to struck flow of gas.
Dec 23, 2007 | Dacor Preference SGM466 Gas Cooktop
Cooktops Logo
842 people viewed this question
Top Dacor Cooktops Experts
Mike
Mike
ray gallant
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
