Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washer doesn't agitate
My Whirlpool Ultimate CareII isn't agitating..it goes through the whole cycle...fill, spin, rins, drain...withou ever agitating. We think the dogears are worn down and are trying to find parts locally. What do you think?
  • jguythi Dec 23, 2008
    What should I do ?
  • frattingerd Jan 10, 2009
    I have the same problem and so I took it apart to see if there was something I could do. There's a set of three "arms" underneath the fabric softener container that when turned, should swing out and grab the ribbed side walls to turn the agitator. I think that ours are worn down because when spun, they swing out but won't grab the wall to spin the agitator. I wasn't able to figure out how to replace them other than to get a whole new agitator unit. I haven't looked online for that part yet but will post a response if I find it.
Here's a parts store where you can buy the "dog ears" or buy the entire agitator unit with dog ears. 30 day money back guarantee.
http://www.partstore.com/Model/Whirlpool/Whirlpool/LSN1000JQ0.aspx
Dave
Posted on Jan 10, 2009
I would like to raplace the damaged part if possible
Posted on Dec 23, 2008
My whirlpool ultimate careII quiet wash washer stopped working in mid cycle. It won't agitate, drain, spin, fill with water, nothing. The washer makes a humming sound and an electrical burning smell.
If your smelling electrical burn.. It's most likely to be the motor is bad.. Or just stuck, new washers made today are DC motors and contain a circuit board in the motor.. And are not serviceable.. Just replace them..
Dec 02, 2016 | Whirlpool Washing Machines
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer stoped after the agitate cycle
If it fills with water, agitates then stops still full of water (even if you manually advance the timer), you have a bad lid switch. This is an inexpensive repair, or even a do it yourself project.
May 19, 2009 | Whirlpool Washing Machines
Whirlpool washer LSQ9549LN0 problem
you have a problem in the transmission of the washer
May 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
237 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
