Question about Frigidaire Affinity ATF7000ES Front Load Washer
I'm trying to access the site listed for solving the E20 error code problem: http://www.fixya.com/support/t615626-error_code_e20 but the link is bad...
  • 3 Answers
Go to Frigidaire.com - click customer service - product manuals - downloads - put in model number - tech info.
Posted on Jan 01, 2009
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
Frigidaire front load washer (LTF600ES1) Error E20
this is an error that indicates the tub is clogged or draining slowly
to fix this you have to go under the washer and pull the tub hose off and clean all obstructing stuff in the hose and thru the hole on the tub
Oct 18, 2008 | Frigidaire ATF6000ES Front Load Washer
E20 error, but isn't spinning
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Frigidaire Affinity ATF7000ES Front Load...
I have a LTF7000ES0 frigidaire washer, getting error code E20. I have taken off the hoses from the water pump and cleaned them, there is a tube coming from the tub of the washer, in it is a device that...
E20 Water not pumping out fast enough. To get the front panel off,
as follows-----
Take out soap tray.
2 screws on back of top- and slide back.
5 screws & 3 clips on console, and fold out of way.
pull spring clip off boot and release boot.
8 screws ro loosen front panel
2 screws on door latch- and a clip to release wires.
---------- for detailed instruction click this link and check out other solution who solved this problem by themselves http://www.fixya.com/support/t178452-frigidaire_front_load_washer_ltf600es1 thanks.
Jul 11, 2009 | Frigidaire Washing Machines
When i am washing a load of laundry it gets part way through the cycle and then it starts flashing e20
Check this answer:
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 04, 2008 | Frigidaire Washing Machines
Frigidaire Affinity E20 error code
This issue is a clogged drain. It usually requires cleaning out the Drain filter underneath the drum assembly in your washer. If you are not handy, don't try this yourself, it will require some skill.
Joe the Plumber
Mid-Hudson Heating & Plumbing
Woodstock, NY
845 679-9158
Oct 04, 2008 | Frigidaire Affinity ATF7000ES Front Load...
E20 error code
Check this answer:
Cheers!
IrishDruid
Oct 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Error code E20 for ATF700ES1
This problem is due to a clogged drain issue, E20 is the code for this. It is usually coins or lint build-up in the drain screen assembly. If you are not handy, I don't recommend that you try to fix this yourself. I being a plumber found it to be quite hard getting at the hoses and filter under the unit drum. It will take you a good Hour and a Half to do the job if you do decide to fix it yourself. I hope that this will help in your quest to finding out what is wrong with your washing machine.
Joe The Plumber
Woodstock, NY
845 679-9158
May 24, 2008 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Washing Machines Logo
134 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
