Question about General Filters 1042-LH Humidifier
Knocking nosie when water enters humidfier
When the furnace turns on and the water enters the humidifier it often clicks and knocks until the furnace turns on. I am not sure what the cause of this may be. If anyone knows or has any ideas, I would greatly appreciate it. Thanks.
  • dlee33 Dec 23, 2008
    Do I need to change this valve?? The knocking is not just minor clicking it is extremely loud and didn't make this noise the 1st two years we had it installed. Any help would be greatly appreciated. Thanks!
  • redrick2456 Jan 25, 2009
    I have changed the solenoid 3 times and still have the same problem, a very loud rattleing form the solenoid but not all the time sometine not for days them 4 0r 5 times the next day any help with this , first year no problems, unit is 3 years old could there be air in the pipes which causes this problem ,
  • 69 Answers
That would the the 24volt soleniod valve that the water line attaches to. Steve
Posted on Dec 21, 2008
  • Stephen Evans Dec 23, 2008
    If your sure that is exactly where the sound is coming from yes. you can put a screwdriver up to it and put the handle to your ear then turn it on. this will act like a stethescope of sorts. all the soleniod valves for there humidifiers are universal.
Fan and water does not work
What brand and model do you have for starts. Sounds like a low voltage power issue.
Feb 24, 2015 | Aprilaire 700 Humidifier
My homedic s humidifier is leaking.I turn it on in the evening and next morning I see it in a puddle of water.Happens every time.
Chances are it is just condensation not leakage if it's only wet when its running. Nothing you can do except put a towel under it.
Dec 01, 2014 | Homedics Cool Mist Humidfier - Uhe-oc1 -
I bought a hunter humidfier about 2 years ago and now i am using it for the first time. I took all the plastic off around it and opened up the top to make sure the filters and everything is in place. I...
Hunter carefree humidifiers use a reusable and washable wick this method of humidifying does not produce a fine mist like many centrifugal (cool misting)humidifiers. The fact that it is producing cold air seems to indicate it is working. However it would not hurt to check the water intake for blockages it also a good idea to run these models on high for several mins when starting this ensures that water is being pumped up.
Mar 07, 2011 | Hunter CareFree Plus 33222 Humidifier
Water coming into humidifier has recently begun to leak out from connection to the discharge tube.
THE WATER CONNECTION TO THE INPUT OF THE HUMIDIFIER IS LEAKING? - -IF THIS IS THE CASE, SHUT OF THE WATER SUPPLY TO THE HUMIDFIER, UN-SCREW THE INPUT CONNECTION, USING SOME PLUMBING WHITE CONNECTION TAPE, WRAP A COUPLE OF TURNS UNTO THE THREADS, RE-CONNECT AND TURN ON THE WATER SUPPLY. IT SHOULD STOP LEAKING.
IF ITS THE OUTPUT OF THE HUMIDIFIER OR DISCHARGE TUBE, THIS IS NOT UNDER ANY WATER PRESSURE LIKE THE INPUT IS, AND IT IS POSSIBLE THAT THE HOSE MAY BEJUST LOOSE OR CRACKED AT THE HUMIDIFIER. CUT OFF THE HOSE AND RE-ATTACHING WILL WORK OR MAY EVEN NEED A NEW HOSE.
Feb 20, 2011 | Aprilaire 700 Humidifier
I have a Honeywell humidfier HE 220A with a KIP U147112 pump. A lot of water bypasses the humidifer and I use 5 gal. in 24 hours. is there an adjustment on the pump to reduce the flow, or some other...
I have a Honeywell humidfier HE 220A with a KIP U147112 valve. Will turning the large screw head on the valve decrease the volume of water flow through the humidifier. Too much water is being wasted.
Dec 20, 2010 | Honeywell HE220A1019 Whole House...
Dry house with furnace mounted humdifier
Is the furnace fan set on auto or on. You will get better humidity if you keep the fan on. It won't add much to your electric bill because many of the newer furnaces operate the fan on DC voltage. Try it!
Jan 16, 2010 | Aprilaire 700 Humidifier
No water going to furnace humidifier
The furnace should be equipped with a #50 relay to turn the Humidifier on and off when only when the furnace blower is on. You should have a test mode on your humidistat. Do you have water coming up to the solenoid valve? Make sure that the saddle valve is turned on to supply the water to the humidifier. Is your humidistat set high enough to turn the humidifier on? Is it plugged in?
Good luch
HVAC Teacher
Mar 04, 2009 | AutoFlo 400BP Humidifier
No water flow to the humidifier
Turn that pin to the left and that will open the valve to allow water to flow through it. If it starts to leak the all you need to do is tighten the nut that were the water is coming out with a wrench, be carefull it wont take much to tighten.
Dec 02, 2008 | Aprilaire 600 Humidifier
Honeywell 360a humidifier
yes water should turn off solinoid is bad
Oct 24, 2008 | Honeywell HE360A1027 Whole House...
General Filters 1042-LH Humidifier Logo
399 people viewed this question
Top General Filters Humidifiers Experts
Paul Carew
Dennis
Marvin
Marvin
Are you a General Filters Humidifier Expert? Answer questions, earn points and help others
