Question about iiyama S 900MT1 (White) 19" CRT Monitor
Problem with display
Hello people im new to this forum stuff so bear with me please. ok let me start, just built a new system Abit kn8 board athlon 3200 (64) cpu radeon 1600 pro pci express ok when i plug monitor(iiyama 19" crt) into card via vga plug i get no signal at it just says "no signal" on BUT when i plug in my old monitor ( compaq 17") every thing works fine ialso have have another pc running a geeforce 3 64mb which will run on my 19" can some one please explain and help thanks
Hello come across this before. Once it was due to a fact i had not setup in the bios what the primary card was to be used in the bios ie bus type. Eg. Onboard, Agp or Pci-E another is to make sure that in the bios you can switch off onboard graphics, on the motherboard. And last one is if the radeon has two DVI ports for out put try switching from one to the other. The only thing left is to say it`s the radeon not sending a sync signal at the right Volts for the monitor to kick into full power up.
Posted on Oct 08, 2007
Some iiyama's have 2 inputs. One DVI and one analog. Also, some of the older ones used BNC connectors. What I'm getting at is make sure you have the right input selected in the monitor's menu. Hope this helps....JF
Posted on May 01, 2007
SOURCE:
My motherboard does not accept my RAM upgrade. 4 Go ( 4 * 1 Go). Compatibility is OK, i works with 2 Go. With 4 Go : i can't boot, continous beeps ! My BIOS is the most recent. What can i do...
Hi, you can see the specifications here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=KN8+Ultra&fMTYPE=Socket+939
Try to download a manual.
My guess is that your cpu does not support that amount of ram.
The ram must also be at an equal size.
Your operating system must be a 64 bit to handle
more than 3 gb of ram.
Aug 27, 2011 | Abit KN8 Motherboard
Why does the keyboard not work when I start up motherboard. all devices and memory are found but then asks to press F1 or DEL but keyboards (usb and ps2) aren't working :( Motherboard is ABIT KN8 Ultra
Hello
Try this.
Unplug usb key board.start pc.plug usb keyboard in.should work.
Try reinstalling usb drivers or chipset drivers for motherboard if above does not work.
Feb 05, 2010 | Abit KN8 Ultra Motherboard
ABIT KN8 Motherboard will not start
Seems like the start-button or the wire connected to it is broken instead of the mobo. Basically when you press the start button you short the 2 cables together. Try replacing any shabby looking parts of these 2 cables, and if here aren't any, try to replace as much of the cables as you can. Just try some basic copper-wire, preferrably insulated, and that should do the trick.
Jul 22, 2009 | Abit KN8 Ultra Motherboard
Can't install windows XP on my KN8 ultra
I believe you are using a sata drive not ide, correct? The problem is that vista has built in drivers to support your boards sata/raid controller, winxp does not. to work around this you need to go here -
http://www.abit.com.tw/page/en/download/download_driver_detail.php?pFILE_TYPE=Driver&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=KN8+Ultra&pSOCKET_TYPE=Socket%20939
Abit website. for your board - socket 939. KN8 ultra file called NVRaid Installation disk. click on picture, it will download the zip file. extract the files to an empty folder (create one). Then run RFDgen.exe program. It will create the floppy you will need. I hope you have a floppy drive, if not try a usb one. If it has a problem creating the floppy, copy the files in the folder floppydisk to your floppy. there is a readme.txt file in that folder as well that should help explain which option you should select when you install windows. So... once you have the floppy start your computer up with xp disk in and as the screen turns blue, you will see at the bottom of the screen a message - press F6 to select additional drivers. Do just that, a couple of times to be sure. then it changes to press F2, just sit back and wait. eventually it will come to a screen asking if you want to specify additional drivers. press S and the next screen will show you the drivers it found on the floppy. select the one for your configuration (can be changed in the bios). and then windows will load fine. this is necessary for all new systems with sata/raid installing xp. take care.
Feb 10, 2009 | Abit KN8 Ultra Motherboard
KN8-SLI newly installed, beeps but no start-up
Sounds like a bad or wrong stick of memory
Dec 21, 2008 | Abit KN8 SLi Motherboard
Abit KN8 ultra chipset coller
Try cleaning with compressed air.But i believe the bearings in rthe fan are bad..replace new.RichardM69
Nov 30, 2008 | Abit KN8 Motherboard
Manual
ABIT = http://www.abit.com.tw/
Sep 19, 2007 | Abit KN8 Ultra Motherboard
iiyama S 900MT1 (White) 19" CRT Monitor Logo
174 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Marvin
Marvin
RS Technology...
RS Technology...
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
