Question about Sansui HDLCD-2600 26 in. LCD Television
Sansui HDLCD2600 I have a sansui hdlcd2600 lcd tv when you turn it on the green light flashes about 5-6 times screen lights up for about 5-6sec.and goes out. This will go through a start up cycle like this about 3 times. It never stays on, what could be wrong with this set ? Any info. would be helpfull. George
  • naomismail Mar 26, 2009
    I have the 26" LCD/DVD combo and it just started doing the same thing. It won't even stay on long enough for us to eject the DVD stuck inside. Did you ever find an answer?
  • Sansui Master
  • 2,101 Answers
Test the power supply voltages for starters, bad capacitors could be causing issues
Posted on Dec 30, 2017
3 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: no audio for my 26" sansui hdlcd
use a cable box and external speakers they sound better anyway.
the circuit for your tv is not available yet.
Posted on Apr 26, 2008
  • 286 Answers
SOURCE: SANSUI HDLCD2600 TV W/DIGITAL TUNER
This is likely your DVD player, not the tv.
First go into the setup menu of your DVD player and make sure "subtitles" are turned off.
Next, put a DVD into the player and when it gets to the menu, go into the audio setup.
If subtitles are turned on, turn them off. If subtitles are turned off, turn them on and exit the menu, then go back into the menu and turn them off again. I've seen this reset this same problem on some DVD players.
Posted on May 07, 2008
Yesterday my sansui was not showing any picture although it was on,the screen was cold. today the power button does not turn on.
Sansui HDLCD3700 -- Turns On, No Picture/Sound - Badcaps Forums ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
May 20, 2013 - 7 posts - ‎3 authors
Sansui HDLCD3700 -- Turns On, No Picture/Sound ... My Country: USA ... not been able to get any sound or video at all (no backlight either).
Sansui hdlcd185w repair - YouTube
? 2:25
https://www.youtube.com/watch?v=qMpiC8YL3SE
May 31, 2013 - Uploaded by After Hours Tv & Pc repair
Thanks so much for posting, saved my kitchen tv from the landfill!... Also the buttons on the side of the tv do not work correctly. ...Any suggestions? .... LG LCD TV REPAIR - NO PICTURESCREEN FIX REVIEW - Duration: 5:29 ...
Jan 08, 2016 | Sansui Televison & Video
My sansui hdlcd1955e i can turn it on but it goes blank it still shows the green light on but it wont let u do anything i try to chagne the chanle but it wont let u
Only a green screen is a bad symptom. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen shots to defective LCD panels are given. You can compare it to that of your TVs'.
May 11, 2014 | Sansui HDLCD1908 19 in. LCD TV
Sansui LCD TV STY0332Flat cable connecting Ti-con board to LCD panel. 35mm x 80mm.
hey i have a sansui sty 0330
hi, the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
Jul 18, 2013 | Televison & Video
My sansui hdlcd1909 19 in. lcd tv won't turn on. the standby red light blinks once, what can i do to turn it on?
sounds like bad capacitors on the power board. Very common problem. I would look at the caps if any appear even slightly rounded on top they are bad. They should be perfectly flat on top any puffing up means replace that cap.
Aug 07, 2012 | Sansui HDLCD1908 19 in. LCD TV
Sansui san3201 green light but not swiching on
if some one have sansui lcd san3201 no power.i can fix for it.I am in melbourne.call 0413015684 frank
Nov 26, 2008 | Sansui HDLCD3210 32 in. LCD TV
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
How to an homethether to the lcd
Sorry, the HDLCD2600 only has a coaxial audio out jack and only works with digital signals from the digital tuner or HDMI jack. There is no analog out.
Nov 02, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Digital audio out jack
That output only works with digital signals (digital tv channels and digital audio from the hdmi in jack).
The HDLCD2600 has no analog out. Sorry.
Aug 14, 2008 | Sansui HDLCD-2600 26 in. LCD Television
May 06, 2008 | Sansui HDLCD-2600 26 in. LCD Television
No audio for my 26" sansui hdlcd
Mar 01, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Sansui HDLCD-2600 26 in. LCD Television Logo
91 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
